| Review by Kelen | posted 587 days ago | 1778 views | 0 times favorited | 11 comments | ![]() |
- Kreg Jig Mini
- Brand: Kreg | Category: Other
I’m sure some may argue, but this has got to be one of the coolest little gadgets I have in my shop. I opted for the mini version 1) for the attractive price tag compared to their pricier systems, and 2) I never really thought I would use that many pocket holes in my projects. Several hundred pocket holes later, I find myself wishing I had paid the extra amount and purchased their more complete system that retails for around $99. The Kreg-Jig mini will do the same job just as good as its more expensive counterpart, the only negative being you can only drill one pocket hole at a time with the mini version. In most applications/joints, not all, it’s usually necessary to drill more than 1 I’ve found. The larger version gives you the option to drill 2 or 3 while not having to reposition the jig on the board you’re drilling.
The Kreg jig system is simple to use and produces a strong joint. Although the company says you do not need to use glue, personally I like to error on the side of using glue (depending on the project) to give the joint some added strength. I know it won’t produce the strength and sometimes the aesthetic look of a mortise and tenon and other types of joints, the speed with which one can join two boards together is quick and easy.
The key to the entire system is the proper setup. When setup properly, the jig will guide the drill bit at the appropriate angle to ensure the pocket hole screw exits the board directly in the center. I use the jig primarily for ¾” stock which based on the instructions that came with it, you line up the end of board flush with the end of the jig. Once your drill bit stop collar is measured to the appropriate distance, simply clamp the jig down to the board and drill a hole. I generally use a simple set of 11” Swivel Pad lock grip pliers from Harbor Freight (around $5) and it does the job just fine. Kreg sells their own sets of locking pliers that complement their systems. Maybe they’re of better quality, but for me, the price was a little too inflated for the purpose. I’ve also had no problems using a basic 6” Irwin quick-grip clamp to hold the jig down while drilling.
Overall, this is a great little tool that for certain applications, I can’t live without. Some projects I opt to fill in the pocket holes (they sell the pocket hole plugs you can glue down and sand down flush) and others I leave them visible. It won’t replace any form of joinery, but it certainly adds another option when building.
11 comments so far
rda327
home | projects | blog
26 posts in 840 days
#1 posted 587 days ago
Thanks for the review. About a year ago I purchased the Kreg system and now use it for most all my projects. I am always finding that i could use the single hole jig. I think you have made up my mind to purchase one. thanks
-- Roger, Jasper Tn.
pintodeluxe
1843 posts in 1010 days
#2 posted 587 days ago
Of the three kits available, I like the Kreg Jr. kit. It is the middle size jig that has three holes in it, but still allows you to secure your workpiece flat on a workbench for drilling. The large version has you position the workpiece on edge – something I usually try to avoid.
Whenever someone asks me what kind if joinery I use, I say I use it all.
Dados, rabbits, mortise and tenon, dovetails, biscuits, and pocket hole screws. It just depends on the look and application you are after.
Cheers
Ripthorn
506 posts in 1182 days
#3 posted 587 days ago
I used mine for the first time this last week building a little 3 drawer tool chest for my bench top. I loved it. The joints aren’t perfect, as my wood deicded to do some funny things, but it turned out pretty darned nice. I used it both for the outer casing and for the drawer frames. I like it.
jeff
442 posts in 1662 days
#4 posted 587 days ago
i have one and its simple to use and has provided good results with my newbie woodworking skills…
-- Jeff,Tucson,Az.
Bradford
1424 posts in 2020 days
#5 posted 586 days ago
If you look at my last post, you will see the project that I used the Kreg jig on. I loved using it. It was so simple and was as tight as glue could hold. I would recommend it it to new woodworkers to get them up and running fast. Then they can build upon their skill base as time progresses.
-- so much wood, so little time. Bradford. Wood-a-holics unanimous president
ed220
584 posts in 1590 days
#6 posted 586 days ago
I’ve used mine on furniture repairs also and it can’t be beat. Makes for a great repair. Have built a couple of tool carts with it ask. Like its strength even without the glue.
richgreer
4472 posts in 1271 days
#7 posted 586 days ago
I’m a big fan of Kreg’s Pocket Hole system. However, I seldom use it where the holes will be visible on the final project.
I also use it for construction, as opposed to toe-nailing studs. It is almost as quick and it’s easier to keep the stud in place while you “put the screws to it”. It is also reversible. Yes, you can remove a stud that has been toe-nailed in place, but it is messy.
knotscott
4288 posts in 1572 days
#8 posted 585 days ago
Thanks for a well written review. I’m also a fan of pocket holes, and love the Kreg system. They’re sort of “life changing”...in the shop anyway. They literally change my joinery choices. Easy and effective. I started with a small double holed Kreg “Rocket”, and was later given a K-Pro3. The Pro system is nice, but most of the time I just use the portable double jig from the Rocket. For anyone who’s not sure about pocket holes but wants to give them a try, the basic $20 jig is a great choice IMO.
hafassartist
41 posts in 584 days
#9 posted 583 days ago
I would not use it to build a fine heirloom piece of furniture but i do use it to build my face frames for kitchen cabinets it is fast and strong.
John Franklin
321 posts in 1995 days
#10 posted 518 days ago
good review; thanks!
i bought this little kit as a supplement to the full K3 system because it was just a couple bucks more than the drillbit by itself – now i have two bits and this little jig which comes in handy for holes i decide to drill (i.e. forgot to drill) during assembly.
-- John Franklin - Central PA - http://affyx.wordpress.com
bmwrider1
13 posts in 689 days
#11 posted 496 days ago
You guys just helped me make up my mind on this one. Right now they are @ 20% off and a $15 rebate what a good price that is.
