Rikon Drill Press and Orion Mortising Attachment
Review by shaun posted 633 days ago 4186 views 0 times favorited 7 comments Add to Favorites Watch
Rikon Drill Press and Orion Mortising Attachment No-picture-s No-picture-s Click the pictures to enlarge them
I went to the March Madness sale at Woodcraft today and came home with a new benchtop drill press and I grabbed up an Orion mortising attachment while I was there. I caught the eary bird part of the sale so I got an additional 5% off. The drill press retails at Woodcraft for $249.99. For the eary bird deal they take the additional 5% off after they apply the 10% discount so it ended up costing me about $214 before sales tax.
It’s a 13” drill press with a 1/2 hp motor. Pretty much all the benchtop drill presses I’ve been looking at had 1/3 hp motors and I have to say that the bigger motor definitely drew me to this one. They also had a smaller Rikon (I think it was 12” with a 1/3 hp).
It went together smooth as silk, there wasn’t much work to the assembly at all. Just bolt the column to the base, slide the head on the column, attach the hand wheel, install the belts, slide the chuck on the arbor and drive it home with a mallet.
It’s got 16 speed settings ranging from 220 rpm – 3600 rpm. Changing speeds is a pretty standard belt/pulley type adjustment. The base and the table are cast iron with a steel column. It is definitely sturdy and runs vibration free with a very quiet motor.
Table height adjustment is smooth and requires very little effort but the worm gear is a little sloppy. The table rotates 360 degrees around the cloumn without a problem and has a 45 degree tilt left and right.
In order to adjust the tilt you have to get up under the table with a wrench and the locking nut is not the easiest to get at but it works and holds the table securely.
On the down side. The hand wheel is cool to look at but it doesn’t give you a lot of leverage, you almost feel like you need to put two hands on it.
The on/off switch is right out in front of you and easy to get at but as far as controls go, thats the only one that’s easy to get at. It’s got a clutch type depth stop that is set with a thumb screw on the hand wheel.
Using it will be a challenge if you’ve got big hands.
It does have a tension adjustment handle for the belts wth locking knobs so tension adjustments are easy and can be done without wrenches. But the tension adjuster is mounted right behind and painfully close to the handwheel.
It’s a knuckle buster for certain.
I also learned that it’s got an odd sized quill which makes installing the Orion mortisng attachment a bit dicey. Mortising attachments seem to be sized for quill diameters of 2 5/8” with adapters to fit 2”, 1 7/8”, and1 1/2”. The quill on this press is 2 3/16”.
The Orion mortising attachment retails for $119, after the sale it cost me a little over $100.
You can make it work on this press if you use the 2” adapter and get up on the spindle just above the quill but then you’re only clamping down on the bottom half of the adapter and you don’t really have enough room at the chuck, especially if you’re using smaller diameter mortising bits. I’m going to solve this problem with a visit to the machine shop to have a custom adapter made.
I was able to get the 1/2” mortising bit in it and run a couple of test mortises.
The funky handwheel on the drill press gets in the way of the clamping lever on the mortising attachment so you have to angle it slightly to make things a little easier.
I really like the fence on the Orion. The supports and hold downs are sturdy and easy to use. The fence attaches to the drill press column and has a gear driven depth adjustment. They call it a micro adjust but I think that’s being a bit generous. It was very sloppy when I first assembled it but there are adusting screws that let you dial it in. After I did that it was tight and smooth.
The Orion comes with 1/4”, 5/16”, 3/8”, and 1/2” chisel and bit assemblies. The ones that come with it are ok but I can see myself picking up a set of CMT’s at some point in the future.
Here’s a test mortise.
All in all I think the Rikon is a good drill press for the money and Orion mortising attachment is definitely a keeper.
No regrets here.
-- I've cut that board three times and it's still too short!
View shaun's profile
shaun
360 posts in 801 days
7 comments so far
View juniorjock's profile
juniorjock
790 posts in 661 days
posted 633 days ago
I’ve seen a lot of mixed reviews on the mortising attachments for drill presses. I’m glad you found one that works for you. Overall, it sounds like you got a couple of good deals.
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
teenagewoodworker
2481 posts in 664 days
posted 633 days ago
nice review. it seems like a good drill press. speaking of bench top drill presses Craftsman has one that has 2/3 hp with 3+ inch stroke (good reviews also) on sale every once in a while for 149.99 dollars.
View motthunter's profile
motthunter
2079 posts in 694 days
posted 633 days ago
good luck with your new toy.. I hit the madness and got a bunch of stuff I needed too.
-- making sawdust....
shaun
posted 632 days ago
I’ve gotten a mixed bag of reviews on mortising attachments too junior and I was on the fence about buying it. I originally set out to buy a mortiser but my drill press desparately needed replacing. I picked it up from a buddy about 10 years ago, he had it for about 5 years and originally scavaned it from a machine shop that was closing it’s doors and god knows how long they had it. The motor was starting to smell burnt if I ran it too long and because the motor was a goofy frame size a replacement would have cost me $150 so I decided to retire it.
All the mortisers that I was looking at had 1/2 hp motors and since this press had the same size motor I decided to give it a shot and see if I could kill 2 birds with one stone. I have to say that there is a phenominal difference between the amount of leverage you get with the handle on a mortiser vs. what you get with this press though and I still haven’t had a chance to really run it through the paces because of the adapter issue, so I may still be dissapointed with my decision.
View Tim Pursell's profile
Tim Pursell
389 posts in 678 days
posted 632 days ago
Good deal! Don’t run out & buy the CMT bits till you give the original bits a good sharpening. See Karson’s post: http://lumberjocks.com/reviews/product/259. I bought some high $ bits only to find out after sharpening the originals that they work just fine in qswo.
-- http://www.grandprairiewoodworks.com http://www.etsy.com/shop.php?user_id=6453794
juniorjock
posted 632 days ago
Keep us updated shaun. I’ve been looking at both but there’s just something about spending that much cash on a machine that does only job. I took some time to look at your projects you’ve posted and I wanted to tell you that I think you’re doing some great work. And loved your writing about the air compressor. That’s a victory for us woodworkers….... Thanks for the reply.
View jaxx's profile
jaxx
38 posts in 413 days
posted 409 days ago
Your Mortise attachment looks good. I bought one a few months ago and just have had hell with it as the arbor kept rattling out , after applying a heavy pressdown to tighten it in i broke the table clamp, all fixed and welded. it works ok now. So my thoughts are if you have lots of mortises to do then a dedicated mortiser is better however your set up looks strong .
