| Review by cajunpen | posted 560 days ago | 2366 views | 3 times favorited | 18 comments | ![]() |
- Stanley 31188 Outdoor remote control.
- Brand: Stanley | Category: Other
Found this remote on Amazon.com while looking for a solution to outdoor Christmas lights, as the season is quickly approaching.
This unit is under $20 and comes with 2 controllable outlets – the remote control has two separate switches for each of the 2 controllers. I have 2 dust collectors in my shop – a 1 hp Delta and the small one from Rockler that hangs on the wall. I plugged them into the 2 controllers and Wallah!!! Works like a charm.
I HIGHLY recommend this as an economical solution to adding R/C to your dust collection.
18 comments so far
Alongiron
home | projects | blog
330 posts in 861 days
#1 posted 560 days ago
Thanks Bill
I have been looking to try one and I think this will work.
I am going to order one tonite!
-- Measure twice and cut once.....
Bigrock
163 posts in 1130 days
#2 posted 560 days ago
Hi:
I just looked at this item. Please be warmed that the wiring is 14 Gage, which they are only good to 15 Amps including starting motor surge.
I liked them until I saw that.
Sorry
JJohnston
1394 posts in 1459 days
#3 posted 560 days ago
These do work pretty well. Clearvue packages one with their DC. It’s a different brand (Carlon – available at Ace Hardware). To get around the amperage issue, they use theirs to power a relay wired into the 220V for the motor.
-- My broker promised me he would treat my money as if it were his own. Trouble is, he did.
jack1
1803 posts in 2195 days
#4 posted 560 days ago
I like it!
87068 posts in 1745 days
#5 posted 560 days ago
Thanks Bill I use very similar units on my dust collectors they work great.
Greg The Cajun Box Sculptor
3769 posts in 1476 days
#6 posted 560 days ago
That seems like a good idea Bill. I have a 220v dust collector but these would be perfect for the air cleaners I built from some ols squirrel cage blowers.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
dpop24
112 posts in 737 days
#7 posted 559 days ago
Hmm, no good for the 2 hp Harbor Freight DC as it sports a 20 amp motor…. boo! I was hoping to get away with a cheap secret! Great deal though, I may have to pick it up for some other toys.
-- If it ain't broke, take it apart and find out why
Gene Howe
3190 posts in 1596 days
#8 posted 559 days ago
dpop,
I’ve had one similar (rated at 15 amps) on my HF DC for a couple years. Works great. An amp probe disclosed that my DC never peaked above 14 amp. YMMV, though.
Chris
1850 posts in 2159 days
#9 posted 559 days ago
Great tip Bill!
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
Mountain View Woodworks
109 posts in 1009 days
#10 posted 559 days ago
I too bought this set up for my dust collector. The problem that I had is that my Harbor freight 2hp dust collector is rated for 14 amps and this switch is only good for 8 amps. Take a look at the link below about the forum discussion we just had concerning this unit. It’s a great unit just make sure that you are not starving your equipment of power.
http://lumberjocks.com/topics/31531
-- Ty, Up in Washington
will delaney
306 posts in 803 days
#11 posted 558 days ago
Just picked up a remote control switch at HD. It’s 16 gauge,13 amp for $9.97. I have the HF 1hp 7 amp dust collector so it will work well. Thanks for the post Bill.
jcwalleye
267 posts in 1241 days
#12 posted 558 days ago
Here is a link to a 20Amp X10 outlet and a remote control unit. Total cost around $45. I’ve been using it on the HF 2hp collector for about a year now. Another plus to this remote is that it saves wear and tear on the HF switch which some have reported as failing.
The only caution I would add is to be sure to turn off the power switch at the collector before leaving the shop. I’ve had it turn on by itself and wouldn’t want that to happen when no one was around.
-- Trees, a wonderful gift --Joe--
aturnis
6 posts in 701 days
#13 posted 557 days ago
Why not just install one of these hardwired remote controlled outlets? If all you need is 110V 20A, you’ve got it and you’re safe…also on Amazon(link), and just a few bucks more at $23.95
cajunpen
11472 posts in 2234 days
#14 posted 556 days ago
Just want to add that I’ve been using this remote system for several weeks, every day, and have had absolutely NO problems with it. I guess most of you have a lot more powerful dust collectors than I do – but this works for me.
TopamaxSurvivor
13192 posts in 1844 days
#15 posted 548 days ago
I just took a look. It description says “8 Amps /125Volt /1000Watt 60Hz Tung.”
A 1 hp DC should draw about 16 amps running; starting, higher. Don’t be surprised if it goes away fairly quickly.
View all comments »
showing 1 through 15 of 18 comments
