Delta - 14-651 (Rating: 3)
When I first got this it was the best thing since fancy cut pickles. Since then (5 tables, 8 chairs and and an entertainment center later), I have had the chisel stuck in my workpiece more times than I can count. I can tell you why… it has no roller wheels or clamps to hold the workpiece tight against the fence. Thus when you try to remove the bit, it rocks the workpiece and binds the bit.
Problem #2 : The hold down clamp rod does flex quite a bit. I think this could be solved with roller wheels mentioned above.
Problem#3 : Poor quality castings of the hub and handle gear assembly. I specifically bought this because it was made in China. That's where all the qulity pot metal comes from right?
This assembly broke on me twice. $50-60 in parts each time.
Problem #4 : Power switch failed. More parts to buy.
Problem # 5 : Plastic knobs stripped out. More parts.
Problem #6 : You can only fit a 4-1/4" wide board under the 1/2" chisel. Riser block is a joke. If Delta had made the head assembly a couple inches taller, I could mortise a 6" wide board.
_
The following problems are common to all mortisers I have seen…
Problem #7 : No squaring index on the bit!!! Unbelievable. My electric toothbrush has that feature.
Are you listening Delta, Jet, Powermatic, Steel City? We want self squaring bits! Were not frickin' cutting diamonds here, we are cutting squares!
Problem #8 : The bit holder faces the bits business-end up. This is dangerous, and it should come with caps or a folding lid.
Problem #9 : Not much stock support. It looks like the Steel City / Woodriver mortiser has solved that issue with integrated slide-out work supports.
What do I like about it? Other than when it binds, the motor seems to have adequate power. The fence is rack and pinion which is a nice touch. However, when you install the riser block it bypasses the rack and pinion, and binds the fence rail in a tight groove making fence adjustment nearly impossible.
Good access to the chuck. I would have given it 2-1/2 stars if that were an option.
_
