| Review by Karson | posted 633 days ago | 1193 views | 2 times favorited | 12 comments | ![]() |
- Rockler Mortise Chisel Sharpening set
- Brand: Rockler | Category: Hollow-Chisel Mortisers
Rockler and others have this tool to sharpen your mortise chisels. Trust me they don’t come sharpl
Lee Vally has just the sharpening cones for $7.95 a better buy than Rockler.
It’s a cone with diamond sharpening grits on the edge. The picture doesn’t show but it does come with 2 grit sizes, course and fine. I placed the diamond cone in my drill press and lightly brought it into the inside of the mortise chisel Ligntly do that until you get all edges of the chisel sharpened. the go to the fine and do the same. I hold the chisel in my hand, resting the shank of it on the table surface. Once you have done that then use some fine sharpening stone, sandpaper to lightly flatten the burs that will probably be on the outside edge of the chisel. The reviews that I’ve seen state that you don’t need to get the same kind of edge that you put on our chisels and planes.
It does make a difference and it might only need to be done once or twice in your lifetime depending on how much you use them.
Well recomended.
12 comments so far
home | projects | blog
20668 posts in 717 days
posted 633 days ago
Thanks Karson,
I have been looking at one of these and wondered how well they worked. I don’t use my mortiser that often but I like the chisels to be sharp. If I am not mistaken I believe I have put this on my wish list at Rockler and I have some rewards dollars to burn. Sounds like a purchase is in order to me.
Dick, & Barb Cain
7036 posts in 1194 days
posted 633 days ago
My mortising chisel were extra sharp when I bought them, & I haven’t had the need to sharpen them yet.
Thanks Karson, I’ll keep this in mind though.
tenontim
1319 posts in 639 days
posted 633 days ago
These are really handy if you use your mortising chisel much. It’s always good to keep a good edge on them. I would recommend checking out Lee Valley. The world of the internet will save you a lot of money. Lee Valley sells the sharpening cones for almost a 3rd of Rockler. Rockler and Woodcraft will bust your bank account in a hurry. I have to depend on buying on the internet, because there’s nothing close. If you look up No Where, Texas, I’m right in the middle of it :]
-- Tim -- http://tmuli.com
25801 posts in 1295 days
posted 633 days ago
You are right Lee Valley has the sharpening cones for 7.95
Thanks for the info
Updated with some new price info.
Dick, & Barb Cain
posted 632 days ago
These companies are going to start looking at LJ’s to compare prices.
posted 632 days ago
I hope you are right Dick. We do have a formattable base of buying power here.
14922 posts in 746 days
posted 632 days ago
Nothing like a bit of competition.
motthunter
2079 posts in 694 days
posted 632 days ago
for waht it is, 7.95 is not a bad deal. Thanks for the tip
-- making sawdust....
14159 posts in 1055 days
posted 632 days ago
companies are silly if they aren’t following the LumberJocks discussions—lots of ideas and concerns posted here
John Gray
1753 posts in 780 days
posted 632 days ago
Thanks for the tips.
3710 posts in 874 days
posted 631 days ago
I’ve bought several sets of mortising chisels, and I can tell you there is a big difference between brands.
What I can’t tell you is the company I finally got very good chisels from. All I remember is they were much more money, but proved to be well worth it.
posted 631 days ago
Lee and others Woodworking magazine Issue 7 had a review of mortising chisels. Back issues are available and also electric copies.
