simply amazing!
Review by slickSqueegie posted 10-26-2011 03:33 PM 4858 views 1 time favorited 9 comments Add to Favorites Watch
simply amazing! No-picture-s No-picture-s Click the pictures to enlarge them
The good:
I do believe this Miter gauge to be the best on the market! It is unbelievable accurate and very well built! The bar itself is completely adjustable for any miter slot. I get no wiggle or play at any point with this gem. after using it I am extremely confident with the positive stops. It has a ruler built into the miter gauge fence and a micro adjustable stop for repeating cuts for accuracy. It also has a stop built in at the very end of the telescoping fence for even more versatility.
The bad:
Its heavy! no handle. I actually lucked out and found a small pipe bender screw in handle that fits it perfectly so I have that problem fixed. I would imagine that if I didn’t have this I could get a dowel or turn a dowel to make a handle for it.
final verdict
WOW this miter gauge is the best I have used! and I do not know what would make it any better! maybe lighter? that would be my only concern but I will admit the heftiness of this unit makes it very very solid!
-- Come check out more of my projects at http://www.mdwoodart.com
View slickSqueegie's profile
slickSqueegie
94 posts in 2450 days
9 comments so far
View Ken90712's profile
Ken90712
17563 posts in 3217 days
#1 posted 10-26-2011 03:37 PM
Interesting review. Sounds like a solid miter guage. I use the Incra 1000 and love that one as well.
Enjoy!
View PurpLev's profile
PurpLev
8536 posts in 3677 days
#2 posted 10-26-2011 04:59 PM
interesting. at first look this seems like the non-digital version of the Ridgid miter gauge:
http://lumberjocks.com/reviews/2402
slickSqueegie
#3 posted 10-26-2011 05:06 PM
Purplev, It does look similar, but I see no posative stops, and this actually looks plastic? and besides that when Im working with miters I do not trust digital. But it does look a hell of a lot better than the stock one they sent me with mny table saw
PurpLev
#4 posted 10-26-2011 05:12 PM
I would choose manual over digital every time myself as well. not a big fan of battery operated tools.
View DLCW's profile
DLCW
530 posts in 2683 days
#5 posted 10-27-2011 02:10 AM
I can vouch for this miter gauge. I’ve had one for about 8 years, use it daily in a production shop and it has worked extremely well. I’ve never had a problem with it. Super accurate and easily adjustable. Highly recommended.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View GaryL's profile
GaryL
1099 posts in 2859 days
#6 posted 10-27-2011 12:57 PM
This looks nearly identical to the miter gauge that came with my PM2000. Except that my aluminum extrusion is black and it does have a handle for the lock down. It has worked well for me with solid detents.
Do you have to pull and spin the knob on the back to change angles? That is the only annoying thing about mine. Can’t just pull and move, have to spin the little knob to change the angle.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View richgreer's profile
richgreer
4541 posts in 3103 days
#7 posted 10-27-2011 02:52 PM
I consider the lack of a handle (or the need to improvise your own handle) to be a significant negative so I don’t understand why the 5 star rating. To me, 5 stars means virtually perfect with no significant negatives.
I’d be interested in a head-to-head comparison of this miter with the Osborne EB-3, heavy and dead-on accurate and it comes with a handle.
Regarding the attribute “heavy”. I accept that for a good, accurate and large miter has to have some beef to it, but, in general, I do not consider heavy to be a good attribute. I like my Osborne a lot, but I would like it even more if it were just as accurate and a little bit lighter.
slickSqueegie
#8 posted 10-27-2011 02:59 PM
rich. It does have an option for a hold-down for the workpiece which acts as a handle as well.. It doesn’t necessarily “need” a handle. The handle makes it easier to carry from machine to machine.
so I do not consider it to be a negative.
I have used the Osborn, and I like it, but I still stick to my guns and say
“This is the best miter gauge on the market”
and still give it 5 stars! again. I see no room for improvement!
I read a lot of reviews, and I think shop notes did a review of a bunch of miter gauges including Kreg, osborn, incra, and the JDS Accu-miter and they classified this one to be the best out there as well. however it is the most pricey as well… so if you can justify the money then get this one!
slickSqueegie
#9 posted 10-27-2011 03:11 PM
Gary, This gauge has a tapered spring loaded pin that I have to pull out no twisting required. I will also add that the positive stop holes (on the gauge itself) are tapered as well. so there is no second guessing.
