Great saw, upgrade fence ASAP!
Review by slickSqueegie posted 10-26-2011 02:45 PM 7197 views 0 times favorited 8 comments Add to Favorites Watch
Great saw, upgrade fence ASAP! Great saw, upgrade fence ASAP! Great saw, upgrade fence ASAP! Click the pictures to enlarge them
ok, So I researched Table saws for a while before I settled on this one.
The only problem I have with this saw is the fence. It is a two piece system and I hate trying to align it. They should offer a small tube of Loc-tite for this to keep them from loosening! Or just simply make a one piece rail system!! It is garbage.
In its defense I will say that i am used to the uni-fence and that may cause a little hate towards this unit.
Ok now that i got that out of the way, all in all I do recommend this saw. This is more saw than any weekend woodworker/hobbyist will ever need! It has no problem accepting my frued 8” stack-able dado set. It is very very easy to adjust the trunnion to square. The miter gauge that came with it had .015” slop in the slot. They quickly sent out a replacement with adjustment set screws in the bar!
The saw has plenty of power. It did struggle when I ripped 8/4 Walnut but it didn’t leave any burn marks and cut very very smooth. besides that it is walnut!
Anyway. If you are thinking of purchasing this saw I give you the green light. It a great value and plenty of power! just be forewarned about the miter gauge and the fence system!
Oh yeah, as with any saw, upgrade your blade ASAP as well!!!
-- Come check out more of my projects at http://www.mdwoodart.com
View slickSqueegie's profile
slickSqueegie
94 posts in 2291 days
8 comments so far
View AUBrian's profile
AUBrian
86 posts in 2540 days
#1 posted 10-26-2011 06:49 PM
I looked at one of these a while back, and seems like a few people mentioned that because of how the trunnion is mounted, it tended to lost its square when the height of the blade is adjusted. Have you experienced that?
slickSqueegie
#2 posted 10-26-2011 08:16 PM
No, not at all. out of the factory the trunnion was off. After initial adjustment, I have had no problems with it.
as a matter of fact I made this piece with it.
notice the the joints on the wallnut frame. I didnt change the blade bevel, I flipped the piece on edge, changed the miter angle and raised the blade for all the cuts. Everything lined up perfectly. I have no gaps and after the frame glue up, the frame sat completely flat.
View jeff's profile
jeff
1061 posts in 3334 days
#3 posted 10-28-2011 09:26 AM
blade to miter slot was off on my rigid 4512 and adjusting the trunnions were harder for me…i followed a review by Furnitude on the rigid 4512 and had to use a clamp also…it did work and has stayed true…i did have to align the fence to blade afterwards…one thing i recently noticed is when you adjust the height of the blade and re-tighten the nob,if you tighten it to tight the back of the blade moves towards the fence…i’m just now careful not to overtighten this…anybody else notice this?...for my very first saw it has been lots of fun and i just finished building the Weekend Workbench from Woodsmith and all cuts and ripping have been square…
-- Jeff,Tucson,Az.
slickSqueegie
#4 posted 10-28-2011 02:28 PM
blade to slot was off on mine as well.. I had no problems squaring the trunnion. I found it extremely easy. After you align the blade to slot everything else needs alignment as well. I found the fence to be an extreme pain in the bum to align. any part of it was a pain in the bum! They had to send me a new fence as well as front rails! The fence is absolute $HlT. aside from the fence being garbage this saw has my vote. I have no problems with it going out of square (that i have noticed) with any elevation of the blade.
How was your luck with the miter gauge?
Mine had a ton of play in the slot! they had to send me a R4511 gauge with adjustment set screws. but I dont even use that one! The saw has good power! and runs smooth and true! just get rid of that damned fence system! Hate it!
View jeff's profile
jeff
#5 posted 10-28-2011 05:47 PM
my miter gauge was fine…i did adjust it square to the blade…the two piece rails worked out okay except were the front fence moves over the area were the rails come together,it clicks,which other rigid 4512 users have reported.i basically filed that area smooth as i could and now the clicking sound is just about gone.again this is my first table saw and i spent some time aligning and rechecking everything which helped me get to know the saw.it appears to be performing well with repeated accurate cuts and i can’t wait until i start my next project.
-- Jeff,Tucson,Az.
View americancanuck's profile
americancanuck
365 posts in 2479 days
#6 posted 11-02-2011 11:23 AM
having recently upgraded from my first ts a Ryobi to the rigid I feel like I have gone to heaven. All of my work has improved and is much easier to do. I do have the same problems everyone else seems to have with the fence. also i just don’t seem to be able to get the rieving knife to work properly.
-- Retired and lovin it
View RandyH's profile
RandyH
18 posts in 2227 days
#7 posted 12-12-2011 07:28 AM
I just bought one of these a couple of days ago ! I am still setting it up (garage is very cold). So far it seems impressive for the money. I am sure it is going to be a big step up from my old, rickety, vibrating Craftsman !
-- There is no greater love than this, that a man lay down his life for his friends.
slickSqueegie
#8 posted 12-12-2011 02:24 PM
yeah It is quite nice to use. Upgrade your blade right away! and I mean right away.! but make a cut with some stock before you remove it so you will know what im talking about after you replace it with a real blade!
HD has the diablo rip blades on sale right now for 29 bucks.
