| Review by KevinD | posted 631 days ago | 2431 views | 1 time favorited | 17 comments | ![]() |
- Performax 10-20 Plus Drum Sander
- Brand: Performax | Category: Sanders
Specs (from the manual):
Max Width – 20” (2 passes)
Min. Length – 2 1/4”
Max Thickness – 3”
Min thickness – 1/32”
Drum – 5” X 10” Extruded Aluminum
Drum Speed – 1700 RPM
Dust chute – 4”
Conveyor Motor – 43 in-lb. Torque, Direct Drive DC
Conveyor Feed Rate – 0 – 12 FPM Infinately Variable
Motor (TEFC) – 1HP, 1Ph, 115V only
Net Weight – 96 lbs.
My review:
I purchased one of these a week ago. First thing I’ll say is that this thing was a LOT heavier than I had anticipated. Putting it together was a breeze, basically all that you have to do is install the drum height adjustment handle. It comes equipped with a very coarse grit sandpaper (36 or 60 grit, I’m not quite sure which). Set-up took a little bit of time. I’ve read several reviews about “problems” with the tracking. It took me about 20 minutes to adjust the tracking but the conveyor now tracks perfectly. For test purposes, I ran about 10 bd. ft. of maple through it as it’s a hard wood and I figured I’d give it a challenge right off the bat. I initially stalled the drum several times running the wood through it. Basically I was either feeding it too fast or taking too deep of a pass. Once I learned the proper feed rate and depth it performed flawlessly.
So, my initial impressions give it 4 stars.
Minuses: The tracking is somewhat tricky to get right which is about the only negative I have to say about it.
Pluses: I really like the fact that the feed conveyor has its own motor, the infinitely variable speed for feed will come in immensely handy and the machine is very solidly built. The drum is driven by a 1 HP motor which easily sanded maple with the coarse grit. I was able to tweak the thickness of my wood by 1/64” and it perfectly flattened the boards removing the snipe from my planer. I found zero snipe from the machine as set up by the factory. This will save me a lot of lumber in that in the past I just allowed for an extra 6” or wood as scrap due to planer snipe. I will no longer have to worry about that.
Summary- I can easily see this becoming a workhorse in the shop. I ordered some 120 and 180 grit sandpaper from Amazon as they had those on sale so I’ll have more to add about the ease (or lack thereof) of changing sanding grits. At this point, I wouldn’t hesitate recommending this sander to anyone in the market for a benchtop sized drum sander.
Kevin
17 comments so far
rikkor
home | projects | blog
11338 posts in 767 days
posted 631 days ago
I couldn’t live without my Performax 22-44!
cajunpen
5970 posts in 958 days
posted 630 days ago
I agree, I have the Performax 16-32 and use on it almost every project.
GaryK
9521 posts in 881 days
posted 630 days ago
22/44 here, and I couldn’t agree more.
motthunter
2079 posts in 691 days
posted 630 days ago
eventually I will own one.
-- making sawdust....
Bill
2562 posts in 1054 days
posted 630 days ago
Nice review Kevin.
How does the Performax compare with the Jet? I have seen both advertised and they look like the same machine except for the name.
Gary, it sounds like you went for the large one. Do you like it better than the 16/32? That was the size I was thinking of.
Splinters
168 posts in 1075 days
posted 630 days ago
I want one!!!!
-- Splinters - Living and Loving life in the Rockies - http://www.splinterswoodworks.com/ - http://www.etsy.com/shop.php?user_id=5220040
GaryK
posted 630 days ago
Bill – I figured that if I was going to spend the money I would get the biggest I could.
I have never used the 16/32.
Be aware that the 22/44 weights about 300 pounds.
KevinD
31 posts in 816 days
posted 630 days ago
Bill,
I think they’re the same machine. I asked for the Jet 10-20 and this is what they had (Woodcraft) so I’m assuming that they just changed the name on it. I’m enjoying having this in my shop more every day.
Kevin
Brad_Nailor
1214 posts in 850 days
posted 630 days ago
This on my list..but I want the 22-44
KevinD
posted 630 days ago
I too would’ve preferred the 22-44 (or even better a Woodmaster 50”) but I’m running out of space in my workshop.
Kevin
Bob_B
28 posts in 939 days
posted 627 days ago
These units seem VERY useful and I’ve almost pulled the trigger on one of these about 5 times, but most of the reviews I’ve read say that there is some deflection in the head that makes for some uneven sandings. Have any of you “Owners” had this experience? Do you think that one model is better than another?
One of the ones I looked at was the Grizzly G0458 18/36” sander. It has a stationary head and the table moves up and down. Seems like a more sturdy approach.
What do you guys think?
-- Bob B - Warwick, Rhode Island
Brad_Nailor
posted 627 days ago
oh, sorry…great review too! I neglected to say that in my earlier post!
SPalm
944 posts in 774 days
posted 627 days ago
Thanks for the review.
I have a 16-32 and love it. I have not noticed any deflection, even though it is a cantileavered machine.
Performax was bought by Jet, which is really owned by WMH Tool Group. They also own Powermatic. My Jet 16-32 came with a Performax video. The Performax name will completely go away and become the Jet name. It is the same machine.
Bill
posted 627 days ago
Thanks for the news Steve. Maybe there will be some bargains later as retails try to clear out their Performax models before stocking the new Jet ones.
Jon3
439 posts in 998 days
posted 114 days ago
Kevin,
A year into the unit, I wonder if you have anything to add, or any updates to your review?
KevinD
posted 114 days ago
Jon,
I use the unit nearly daily. I struggled early getting the hang of wrapping the belts but now that’s a snap as well. I’m glad I bought mine when I did as the price jumped nearly $300 since I bought mine.
Kevin
16598 posts in 470 days
posted 114 days ago
super review
