| Review by pintodeluxe | posted 581 days ago | 2393 views | 0 times favorited | 26 comments | ![]() |
- Freud Diablo thin kerf 10" 24 tooth ripping blade
- Brand: Freud | Category: Tablesaw Accessories
Had blade marks after ripping 1.5” white oak. Even after taking a skim cut with featherboard and zero clearance insert with thin kerf splitter I still had blade marks. Not burning, just the sort of cut that reveals its imperfections when you hold it up to the light. My industrial full kerf combination blade sure makes glassy smooth cuts compared to this one. In fact I had to switch back to the Freud combination blade to make skim cuts on all boards. Too much work. This one is going back in excahnge for an industrial thin kerf blade.
26 comments so far
dbhost
home | projects | blog
4748 posts in 1402 days
#1 posted 581 days ago
Which model specifically? I have had excellent results with Freud’s Diablo blades…
DYankee
2781 posts in 732 days
#2 posted 581 days ago
Same question. Thanks for the review.
-- Shameless - Winner of two Stumpy Nubs Awards
Routerisstillmyname
591 posts in 1679 days
#3 posted 581 days ago
Wow, Freud makes the BEST saw blades and router bits bar none.
I’ve used Diablo 80 T the past two years with no issue even though the diablo line is their lower end blades.
-- Router è ancora il mio nome.
pintodeluxe
1749 posts in 983 days
#4 posted 581 days ago
This is the D1024X model. I think I’ll take it back and try the Freud thin kerf industrial blade, or maybe the new fusion blade.
ChrisForthofer
153 posts in 1237 days
#5 posted 581 days ago
What saw are you running it on? I found on my contractor saw that thin kerf blades performed poorly, put a full kerf on it and its beautiful.
-- -Director of slipshod craftsmanship and attention deficit woodworking
Dusty56
10515 posts in 1858 days
#6 posted 581 days ago
You’re likely to find that this is more for ripping framing than 1.5” hardwoods. What kind of saw are you using this on ?
I had similar issues using one on a bench top Delta model. Put the same blade on my JET and no problems : )
Did you use a blade stabilizer with it ?
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
PurpLev
7755 posts in 1818 days
#7 posted 581 days ago
just to add some context – this is a ripping blade and is meant to speed up the ripping process when compared to a combination blade. this is not a glueline blade and is not meant to produce mirror finishes on lumber.
the question is – does it rip faster than your combination blade – that is it’s purpose in life.
MoshupTrail
268 posts in 651 days
#8 posted 581 days ago
Generally, the Diablo blades are more run-of-the-mill, big box store blades. The better Freuds are the “Industrial” series. How many teeth on your Industrial? That 24T Diablo might be a bit rough.
-- Some problems are best solved with an optimistic approach. Optimism shines a light on alternatives that are otherwise not visible.
maljr1980
171 posts in 626 days
#9 posted 581 days ago
then kerf blades are made for underpowered saws, the vibrate and flex way to much. the thicker the kerf the better the cut. i wouldnt use a thin kerf on anything other than a portable saw
TopamaxSurvivor
13192 posts in 1846 days
#10 posted 581 days ago
PurpLev Thanks for pointing that out. A newbie wannabe like me would have never caught that it is a rip blade.
StumpyNubs
5040 posts in 970 days
#11 posted 580 days ago
I feel like if the “downside” of a $40 rip blade is that it leaves blade marks you can see when you hold it up to the light- it’s not a bad deal! I think these blades should be judged for what they are, mid/low priced blades. As such they preform better than expected (I’d give them 4 stars at least). If you are comparing them to a high end, full kerf, glue line blade, of course they only deserve two stars…
-- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com
pintodeluxe
#12 posted 580 days ago
I use a Jet 1.5 h.p. contractors saw. The diablo ripping blade is $28, and the industrial thin kerf ripping blade is $38, so pricepoint isn’t an issue. Also Freuds glue line rip blade is only designed to rip stock up to 1” thick. I need to cut 8/4 stock for chair and table parts. Freuds industrial 24 tooth ripping blade got 5 stars on Amazon, compared to the Diablos 3 stars. I took it back and ordered the industrial blade.
That said, I do like the Diablo 7-1/4” blades for cutting plywood- nice splinter-free cuts.
My only reason for posting this review is to save fellow woodworkers some hassle. If all you want is fast ripping cuts and you are not concerned with blade marks then you will be happy with the Diablo blade. I’ll let you know how the new blade works.
Cheers
David Craig
2127 posts in 1279 days
#13 posted 579 days ago
As PurpLev already noted, this blade is more designed for reducing the bog that comes on an underpowered saw in which a full kerf might lead to burning when ripping a thicker hardwood board. Less teeth, more gullets, easier stock removal, less smooth a surface. Thinner kerf, more vibration on the arbor, less smooth a surface. What is the payoff? Less strain on the saw motor when working with thicker stock and it is much easier to finish plane/sand small saw marks than blade burns. Not having the funds (nor the machine) to see major beneifts from using the more expensive WWII style blades, I have been very happy with all of the Freud blades in my shop. I rarely use any other.
David
dusty2
281 posts in 1599 days
#14 posted 579 days ago
Are blade marks necessarily a bad thing? Only if you have paid the price to get a mirror finish smooth glue line cut. A $40 investment usually doesn’t do that.
I think you probably got what you paid for.
-- Making Sawdust Safely
pintodeluxe
#15 posted 578 days ago
David – I have been happy with all my other Freud blades as well, but I don’t recommend the Diablo rip blade.
Dusty – Yes, blade marks are a bad thing. My Freud combination blade doesn’t leave blade marks. I have heard very good things about the Freud industrial 24 tooth ripping blade. I ordered it (less than $40) so we will see.
View all comments »
showing 1 through 15 of 26 comments
