Joinery Wisdom from 1920!!
Review by MsDebbieP posted 10-18-2011 05:05 PM 2971 views 0 times favorited 8 comments Add to Favorites Watch
Joinery Wisdom from 1920!! No-picture-s No-picture-s Click the pictures to enlarge them
This book review is from the October 2011 issue of our LumberJocks’ eMag
Gary Roberts (Toolemera.com) is donating a book for a free draw! (See below for details)
Woodwork Joints by William Fairham 1920
1920, you say? Yes, oh yes. I have a wee bit of an addiction to books and to have in my hands wisdom that was written almost a century ago is better than having some Swiss chocolate for a treat.
The sub-title of the book found on the inside pages does a great job of describing the contents: Woodwork Joints: How they are set out, how made and where used, with four hundred illustrations and index.
Included in the list of joints are the typical names, from “glued” to “mortise and tenon” to “scarf”, “dovetail grooving”, and “mitred”. There is also a chapter on “curved work”, “miscellaneous joints” and, perhaps my favourite – “Puzzle joints” – not that you will ever see me attempt to make one.
Flipping through the pages (no, I haven’t read the entire book) I did take a closer look at the “glued joint” as this is what I’d say is my level of woodworking. But, alas, I found that gluing two pieces of wood together is not as simple as it sounds. To create a good glue joint I apparently need a jack plane, a wooden trying plane, a try square, winding laths, and a straight edge! And the process itself, well – I thought it was simply lining the wood up, gluing and clamping it together. But there is wood movement to consider as well as the grain line, because, as stated in the book “nothing looks worse than a dressing chest end or similar piece of work in which the grains run haphazard.”
This should give you an idea of the thoroughness and the high standards within the pages of this book. If you are a book lover, a book addict, or a practical woodworker who wants to improve his joinery skills, then this book is a must for your library and woodworking resources!
Now, I have to go back and flip through the pages some more—what other intriguing tidbit will catch my attention?! I can’t wait to find out. Better than chocolate, I tell you!
WIN A FREE BOOK
One random draw winner will receive a copy of this book.
To enter your name in the draw, click here and answer the two easy questions.
Deadline: November 10, 2011
A big thank-you to Gary for the donation of “Woodwork Joints” for a free draw here at LumberJocks.com.
18615 posts in 4066 days
8 comments so far
View Dennisgrosen's profile
Dennisgrosen
10877 posts in 3020 days
#1 posted 10-18-2011 06:07 PM
thank you Ms Deppie :-)
Dennis
View empeg9000's profile
empeg9000
86 posts in 2331 days
#2 posted 10-19-2011 01:09 PM
thanks! Done.
View B0b's profile
B0b
104 posts in 2595 days
#3 posted 10-19-2011 04:03 PM
Definitely want to improve my joinery skills.
-- Time to get started
#4 posted 10-19-2011 07:06 PM
mostly what I wrote above in the review
I also noted that different joints serve different purposes—with different joinery techniques being best used for certain situations.
I also was reminded how precious hand-tools are .. oh .. and that almost 100 years later, woodworking basics are woodworking basics.
View Gary Roberts's profile
Gary Roberts
140 posts in 2927 days
#5 posted 10-20-2011 01:35 AM
William Fairham wrote Woodwork Joints for Evans Bros. Charles Hayward then edited and rewrote parts around 20 years later for Evans Bros. This, the original version, was written by a woodworker who was trained in the 19th Century hand tools methods by practicing woodworkers who also knew how to use machinery.
-- Gary Roberts, http://toolemera.com
Gary Roberts
#6 posted 10-20-2011 04:16 AM
View yrob's profile
yrob
340 posts in 3557 days
#7 posted 10-20-2011 05:08 AM
Yes its a great book. I own a copy of it. Its even available for free download on kindle.
-- Yves
Gary Roberts
#8 posted 10-20-2011 05:50 AM
Just so you know, the Kindle version is not mine. Amazon lists it under my title but it’s offered by a different party.
