Close Enough for Woodworking
Review by DylanC posted 10-14-2011 03:46 AM 2961 views 2 times favorited 7 comments Add to Favorites Watch
Close Enough for Woodworking No-picture-s No-picture-s Click the pictures to enlarge them
I picked this up at a local Woodcraft (Item #148454) for ~$32. Got it mostly to speed up set-ups on the router and table saw. As soon as I got it, I measured each block with my digital caliper. Each block measured within half a thousandth of spec, except for the 1/2” and the 1-2-3 block. The half inch block measures 0.502” by 0.506” and the 3” side of the 1-2-3 measures a few thousandths over, also. Maybe that’s too much for high precision machining, but it’s more than adequate for woodworking. Also, for $32 you’d be hard pressed to find a more accurate set.
Whats in the box: 1-2-3 block, 0.0625” (1/16”), 0.125” (1/8”), 0.25” (1/4”), 0.5” (1/2”) and 0.75” (3/4”) gauge blocks. Plastic case.
-- Dylan C ...Seems like all ever I make is sawdust...
View DylanC's profile
204 posts in 2606 days
7 comments so far
View jumbojack's profile
1673 posts in 2555 days
#1 posted 10-15-2011 12:11 AM
I can live with .003 but anything over that makes me a little skeptical. Gaps in Miters start showing up at about .004 at .006 you do have a gap. Just sayin.
View maljr1980's profile
171 posts in 2387 days
#2 posted 10-15-2011 06:23 AM
ive never seen someone use set up blocks to cut a miter…vids please lol
View Moron's profile
5032 posts in 3825 days
#3 posted 10-15-2011 07:12 AM
“close enough for woodworking”
surely, you are new at it ? : ))
it shows in yr projects ?
View Scott Oldre's profile
Scott Oldre
1026 posts in 3362 days
#4 posted 10-15-2011 02:11 PM
Put those blocks in the freezer for a few days then measure them ;) What’s a few thousandths anyway, wood moves.
-- Scott, Irmo SC
View MartyShapiro's profile
10 posts in 2347 days
#5 posted 10-15-2011 02:50 PM
I have used sheets of paper to simulate a gage block. The idea is to measure and cut a block ‘close’ to what you need, then shim with uniform pieces of paper or tape. I have 3×5” note paper, 4 pcs = 1/64”. So I can accurately do 1/64 = 0.015 625 /4 = 0.0039” I have used this method for tapered sliding dovetails where tolerance is critical.
As it slides home, it gets tighter. By using the paper shims on the router fence I can control the taper very easily.
View jim C's profile
jim C
1472 posts in 3030 days
#6 posted 10-17-2011 12:28 AM
Even though those blocks are sold at Woodcraft, they are manufactured mainly for machinists, tool makers, etc. (the metal trades)
The idea is they are purposely oversize so they can be tuned in on a surface grinder to whatever tolerance the individual feels is necessary.
Some will grind them square, and parallel to within .0001 accuracy.
It takes time and would increase the cost considerably to attain these dimensions and would not benefit those that don’t need that kind of tolerance.
Hence the answer why they’re oversize.
jim C
#7 posted 10-17-2011 12:34 AM
Moron, Majr1980
Both of you need to find a forum that spews wise ass remarks and vitriol.
Don’t do it here genius’s
I flagged both of you.
Go somewhere else.
