HF Work Bench On Sale
Review by SPHinTampa posted 10-03-2011 09:41 PM 10179 views 0 times favorited 14 comments Add to Favorites Watch
HF Work Bench On Sale No-picture-s No-picture-s Click the pictures to enlarge them
My homemade workbench top (my first big project) gave up a few weeks ago. I saw an advertizement for this and had a coupon for 20% off so net price for the work bench came out to $129 …. not a bad price.
Pros:
- Assembly is solid .. .I was worried it would be flimsy and it is not
- Vice quality is acceptable
Cons:
- 1/2” bench dog holes that are spaced inconvienently far apart
- Either I am bad at assembly or the mounting hardware is slightly off … i had trouble keeping assembly square.
- Oddly complicated drawer slide system … compounded with the out of square assembly makes for difficult to open drawers
Overall, I think that solid and stable are the two most important characteristics of a workbench. And this unit is both of those things. The out of square underside assembly did not translate to an out of square surface or wobbly legs.
From a convenience of use perspective, I am going to add some after market holes and look at expanding to 3/4” size. No room for a front mounted vise. I will probably try to fiddle with the assembly to see if I can get the drawers to work better.
Net of it … I think if you did a lot of handtool work, this would not be a good option. As a resting place for my powertools and a place to glue up projects, it works just fine.
-- Shawn, I ask in order to learn
View SPHinTampa's profile
SPHinTampa
567 posts in 3770 days
14 comments so far
View thedude50's profile
thedude50
3603 posts in 2562 days
#1 posted 10-03-2011 10:27 PM
could it take a better vise and could you drill it for more dogs ? if you add weight to the shelf it should be more stable. I just got and am reviewing the plans for my new bench it is called the 21st century its going to be a big job for me a bit heavy but i am going to build it the same time i do norms router table since the bench will have so much drying time etc. I know it will take me a couple of weeks to finish at my new slower pace or my new faster pace depending on how you look a it.
-- Please check out my new stores http://woodratnest.com and http://woodshopstore.com
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3200 days
#2 posted 10-03-2011 10:37 PM
thank´s for the rewiew
bad with the ½ holes go for 3/4 as you say
the shelf can be used for sandbags to add weight
I know you proppebly did get it for the drawers too
but skip the two to the left and there is plenty of room
for a wice :-)
if you do that it will be a good beginner bench for one that just ain´t knowing
what he/she will do in woodworking a few years from now
Dennis
View Howie's profile
Howie
2656 posts in 3007 days
#3 posted 10-04-2011 12:33 AM
SPH,I live near Tampa too.
Good luck on the drawers I couldn’t get mine square either. Otherwise I’m satisfied with it.
-- Life is good.
View SST's profile
SST
790 posts in 4279 days
#4 posted 10-04-2011 05:10 AM
I’ve seen the bench at our local HF store. For that kind of money, I think you can’t go far wrong. As discussed, there are things you can cheaply do to improve it…add weight, customize it, etc. Thanks for the review; not everyone has a HF store close enough to see it up close. -SST
-- Accuracy is not in your power tool, it's in you
View bizbead's profile
bizbead
3 posts in 2511 days
#5 posted 10-04-2011 05:28 AM
I purchased and assembled the workbench last week. Had the same problem a lot of people seem to be having with the drawers. If this is such a common problem why don’t they do something about it? Can anyone offer some ideas what I might be doing wrong? The drawers are in but they are really hard to pull in and out.
View kshipp's profile
kshipp
179 posts in 3863 days
#6 posted 10-04-2011 06:01 AM
I have this same bench but I don’t have a problem with the drawers sliding. My only problem with them is that they are only half extension. Full extension would be nice.
I solved the “weight” problem by screwing it to my floor. I realize this may not be an option for everyone but just the other day I was planing some board that were in the vise and there was no movement of the bench.
As they said earlier, for the price you can get this on sale you really cannot go wrong.
-- Kyle Shipp, http://battleshipp.blogspot.com
View rance's profile
rance
4260 posts in 3245 days
#7 posted 10-04-2011 08:50 AM
>“why don’t they do something about it?”
That’s a funny one. LOL! This is HF we are talking about. :)
I bought one thinking the top was thicker, it was only 3/4”. Only the edge is beefed up.
A friend of mine has 4 now. They are mysteriously about 1/8” lower than his Saw Stop and they work great for outfeed tables. On the last 3 he assembled, he backed the dog holes from the bottom with 2×4s. Then drilled the dog holes to 3/4”. This helped tremendously and was a very easy mod. On all 4 units, he replaced the drawer slides with ‘real’ ones, and full ext. It made a world of difference. Sill have the problem of the drawers interfering with hold downs. For the money, the benches can be very useful.
SPHinTampa
#8 posted 10-04-2011 03:42 PM
Thanks for the improvement suggestions. I think I will restack the boxes down one side, reinforce and expand dog holes and add a front vise.
Dennisgrosen
#9 posted 10-04-2011 03:54 PM
lets see a blog about you improvement of the bench when you do it :-)
Dennis
View bobasaurus's profile
bobasaurus
3525 posts in 3268 days
#10 posted 10-06-2011 12:49 AM
I have the same bench, and I managed to install a front vice in a very roundabout manner. I cut the blocking drawer into two parts, then joined them with a lower support allowing clearance for the vice jaws. It looks a little funny, but works well and retains the use of the drawer (though only about 1/2 of it, since the vice mounting setup takes up the rest). I plan on drilling 3/4” holes and making or buying dogs for it, too.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View b2rtch's profile
b2rtch
4862 posts in 3133 days
#11 posted 10-06-2011 01:37 AM
I used this bench for several years until I built my own. I was very satisfied with it except for the drawers which opened by themselves.
Excellent bench for the price
-- Bert
bizbead
#12 posted 10-06-2011 04:59 AM
That’s a funny one. LOL! This is HF we are talking about. :)]
Sorry – that was a moment of temporary insanity I guess. – ha. I did get the drawers figured out. They are fine now and I am very satisfied with the bench otherwise.
bobasaurus
#13 posted 10-09-2011 02:59 AM
Here’s a picture showing how I mounted the front vice to my bench:
It’s not ideal, but it’s about the only spot that would work given the leg and drawer placements. The two halves of the top drawer are joined with some plywood stretchers.
View Alexdi's profile
Alexdi
21 posts in 2493 days
#14 posted 10-22-2011 11:49 PM
I bought this bench a few weeks ago. A couple notes:
- It’s not oak as advertised. It’s rubberwood. No big deal.
- Drawer hardware looks cheap. All four drawers in the display model were broken. However, with mine, the drawer tolerances were perfect and they move smoothly and easily. The only problem is that the runners aren’t two-stage, so the drawers only come out halfway. Makes it hard to know what’s in the back.
- Very solid overall. Vice was a little tight. A handful of non-structural screws go into composite wood pieces that strip easily. Instructions have useless pictures and very little exposition. Assembly takes about 90 minutes.
- It’s two or three inches shorter than I’d like. I’m 6’1’.
For a basic work table, you’d do better (not cheaper, but a larger work surface built to your specifications) doing it yourself. Factor in the drawers, though, the accessory hardware pieces (vice, metal and wood stops for the holes on top), and the finish, and this becomes a great deal.
