| Review by Karson | posted 1937 days ago | 2383 views | 2 times favorited | 7 comments | ![]() |
- Foredom 5200 Deluxe Woodcarving Kit
- Brand: Foredom | Category: Chisels and Carving Tools
When I was asked to make a frame for Mark’s Memorial I wanted to do an inlay and I bought a router base that is used in the string instrument industry. It uses a Dremel of a Fordem as the power source. I select the Foredom option. That required the purchase of another new tool. So thats not all bad.
I bought the #5200 model
It contains two hand pieces, but neither of them would fit on the router base i selected, so I had to purchase a hand piece that fit the router base. The Router base MFG sells the Foredom hand piece.
The power head is 1/6hp and runs with speeds up to 18,000 rpt. It comes with a heavy duty foot speed control. It sticks to the floor and doesn’t move around.
It also comes with 3 DVD’s with master carver Frank Russell (a $29.95 retail value).
on power carving, but I haven’t looked at them yet.
The tool is very nice and has lots of accessories, available for purchase.
7 comments so far
home | projects | blog
17955 posts in 2049 days
#1 posted 1937 days ago
Thats a great looking tool Karson. Are there any particular safety concerns?.
Richard Williams
160 posts in 1990 days
#2 posted 1936 days ago
I haven’t the foggiest idea of what it is and what it does but good luck with it buddy. Post a picture for me to see what it can do. I’m better with metal than I am with wood. Spent a lifetime installing metallic conduits and other electrical raceways. Bye for now Karson.
-- Rich, Nevada,
rikkor
11296 posts in 2072 days
#3 posted 1936 days ago
Karson, I have the StewMac base set up for a Dremmel. The Dremmel seems to have a sloppy bearing or something, and the bit ‘flops around’ a little. Is the Fordem pretty solid?
Dadoo
1763 posts in 2188 days
#4 posted 1936 days ago
I’ve been wondering about this one since I posted my review of my Craftsman. Looks like a good carving tool. Thanx for the review.
Dick, & Barb Cain
8682 posts in 2497 days
#5 posted 1936 days ago
Nice tool, you should be able able to do some great stuff with it.
The Dove inlays were terrific.
34396 posts in 2598 days
#6 posted 1936 days ago
Rikkor. You have a flexible shaft and so what you are holding is a hand piece with a 3/8” shaft (like a speedometer cable) So you don’t have all of the weight in your hand. like with a Dremell. I think that Dremell also sells a flexible shaft.
If you look at the picture of the #5200 model it might give you an idea. And you basically use dental type drills in the hand piece.
The only safety concerns that I’m aware of Grumpy would be a bit spinning at 18,000 rpm a few inches from your hands. You use Dental type drills for carving, There may be hundreds of different kinds.
jsylvan
1 post in 1466 days
#7 posted 1466 days ago
RIKKOR
I’m not sure if you are referring to the flexible shaft or the actual Dremel body itself, but I may be able to help and/or enlighten ;-}
Yes, the bearing in the Dremel is notoriously sloppy right out of the box. It’s not the actual bearings but the housing that is not tight enough within the body of the tool. It’s an easy fix though. Simply crack the body (just a few screws – easy to do.) then take a thin piece of plastic or even a piece of paper and give it a wrap around the bearing housing. A small piece of scotch tape holds it in place. Put it back together. It should fit nice and snug, but you shouldn’t have to force it back together. Screw it all back together and it should work like a dream with absolutely no slop at all. IF there is still some play, just repeat the process with a thicker shim of paper/plastic or give it another wrap (or 1/2 a wrap) with the material you have already used the first go around.
I believe a Google search will even locate step by step instructions of the process with pictures and everything. I have done this with every Dremel I have ever owned and NEVER had any problems. I know that it has been done by countless other folks as well and I have never heard of anyone having trouble with the fix. All you are doing is tightening up the fit. Nothing that rotates or heats up ever touches the shim. (So don’t worry about it bursting into flames or anything ;-) Hope this helps
