A Router for Inlays
Review by Karson posted 634 days ago 704 views 2 times favorited 14 comments Add to Favorites Watch
A Router for Inlays A Router for Inlays A Router for Inlays Click the pictures to enlarge them
When i was asked to make the frame for mark’s Memorial I wanted to do an inlay. I’d seen a couple of small routers on the web and I’d seen what mark DeCou does for cutting the outlines on his letter carving.
This router came from Steward-MacDonald. They make tools for the construction and repair of string instruments. This is their router being used for an inlay in a guitar.
I bought the router as a kit which contains an air pump and an edge guide. The edge guide is for inlaying on the edge of instruments.
The router was built to use a Dremel as the power source. But, I’d heard that the Dremel is underpowered. The make a hand piece that works with a Foredom power head. I ordered the Modified Foredom head and it’s shown in the second picture. The third picture is the tool in use. I was using a 1/32” router bit, and I found that it works better if you cut the middle of the inlay out first and then work to the edges.
Here are the inlays in place.
It works great and is highly recommended.
25802 posts in 1296 days
14 comments so far
View TomK 's profile
TomK
504 posts in 770 days
posted 634 days ago
That looks perfect for delicate inlays, Karson. What is the largest diameter bit it will accept?
-- If you think healthcare is expensive now, wait until it's free! PJ O'Rourke
posted 634 days ago
The handpiece will only accept 1/8” shank bits. I didn’t see any bits larger than that in 1/8” shank. Foredom has other handpieces that accept up to 1/4” shanks, but not the handpiece for the router base.
This set of bits is 1/32, 1/16, 3/32, and 1/8”
Douglas Bordner
3424 posts in 959 days
posted 634 days ago
I have the Dremel tool version of this fine little set-up. Although it isn’t a plunger, it is precise and well made. I bought the edge guide as well, and there is an additional fixture designed to cut the channel for the binding or purfling of guitar and violin bodies. Cool tool.
posted 634 days ago
Your right it’s not a true plunge other thasn you turn the screw and it will go up and down.. I guess you can control the depth by 1000 of an inch. I don’t know what the thread pitch is but its fine.
posted 634 days ago
Tom. I see that Stew-mac also has a 1/8” shank and 5/32 bit for cutting bandings on guitars.
TomK
posted 634 days ago
Thanks, I just saw that on their site too. I want to build a Stratocaster style electric for my daughter, and wanted something that had finer control than I can get with my palm router.
14926 posts in 747 days
posted 634 days ago
I like it Karson, great looking tool.
View rikkor's profile
rikkor
11335 posts in 770 days
posted 634 days ago
I have one I’ve used for guitar inlay and purfling. It is a precision tool. More precise than the Dremmel I use it with.
View RickH's profile
RickH
18 posts in 644 days
posted 634 days ago
Nice review – thanks! I have been thinking of getting into inlay work, and your review really helps. Appreciate the details and all the photos.
-- Rick - OC, CA
View roman's profile
roman
1121 posts in 789 days
posted 634 days ago
thats nice
another for my wish list
3710 posts in 875 days
posted 632 days ago
Thanks for the review Karson.
I’ve looked at these several times, but my hands were already full. Sooner or later I’ll order one.
They appear to be high quality.
View tenontim's profile
tenontim
1319 posts in 640 days
posted 629 days ago
Thanks for the review. I’ve been looking at this and the dremmel, and couldn’t make up my mind.
-- Tim -- http://tmuli.com
View Toumar's profile
Toumar
3 posts in 78 days
posted 78 days ago
Hi there ! I probably acquire the stewmac router, but I am still wondering what to use as a power source. Could you tell me what you used to make your inlays please ?
Toumar
3 posts in 78 days
posted 78 days ago
Hey Karson, thank you so much for your kind answer and help :)
Take care,
Toumar
