| Review by David Grimes | posted 600 days ago | 2077 views | 0 times favorited | 8 comments | ![]() |
- Galbert Caliper (The Turner's Tape Measure)
- Brand: Galbert | Category: Lathes
I know, I know I just started turning. But when I saw this I knew it was the way to go (since spindles and legs are my goal) and I knew I’d need to stop and measure diameter lot of times on each one.
I almost got one of the double calipers, but they require one hand to hold and the other to measure the outboard end. This is easily one handed and you read the diameter, lay it down and keep on going.
It has already told me that I am highly accurate, but not smooth or fast yet…
Yep… 3/4 of an inch
inch and 1/8 here…
inch and 1/2 here…
TOO EASY !!!
It is built like a troop carrier (not frail) and is easy to calibrate. It was $86.50 shipped. I love it already.
The web site is at: http://www.petergalbertchairmaker.com/galbertcaliper.html
Be sure and watch the videos. This guy can turn very quickly and accurately for sure.
5 Stars only because they don’t have 6 available.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
8 comments so far
philip marcou
home | projects | blog
263 posts in 763 days
#1 posted 600 days ago
That is cheating and you should have mastered the “correct” way before buying that item. The correct way is to turn a minimum of 10000 spindles first, without that item. (;)
So now how are you going to remember all the different diameters ?? Does that item talk? (;)
But it does look like a good item to have….
David Grimes
2114 posts in 805 days
#2 posted 600 days ago
ah, Philip… good to hear from you. I’ll let you in on a secret. It indeed does not talk, but I have a great echo in my cavernous garage, so I just call them out in order from left to right and retrieve the information from the airwaves as needed. ;=)
Seriously, I’m thinking an erasable “story stick” will be the thing to have / make. I’ll figure out something, unless a good cyber (or other) friend tells me a better way.
rance
3855 posts in 1326 days
#3 posted 600 days ago
I’m glad you like it. I drooled all over my computer screen when they first came out. I even designed it up in SketchUp with plans to build my own. It never happened(yet). I guess I got over it. Maybe one day though. :)
David Kirtley
1250 posts in 1164 days
#4 posted 600 days ago
If you want reusable, just paint a stick with gloss enamel and use dry erase markers. Go with a cheap yardstick and you can use the other side for measuring.
David Grimes
#5 posted 600 days ago
That’s much too logical and easy… how ‘bout maybe a 48” locking contour gauge with dry erase magnetic base ?
michelletwo
1765 posts in 1181 days
#6 posted 600 days ago
we old folks had something just as accurate years ago..open end wrenches…totally reuseable & can be used for what they were designed to do too! But glad you like what you bought…enjoy turning
-- We call the destruction of replaceable human made items vandalism, while the destruction of irreplaceable natural resources is called development.
Scott Oldre
216 posts in 1597 days
#7 posted 600 days ago
I’m envious. I still get nervous using a caliper while with the spindle spinning. I do use the open end wrench method a lot and that works very well, but there are times when you need something a little thinner than a 1/4” to get into the fine work. I’m sure this would work well for that, but still a little pricey for me. I’m saving my pennies for a 16” Longworth chuck from Woodline. That’s something I definitely need and would save a ton of time on the bowl bottom cleanup.
-- Scott, Irmo SC
David Grimes
#8 posted 595 days ago
michelletwo, What for and how do you use open end wrenches ?
