| Review by Craftsman on the lake | posted 608 days ago | 2760 views | 2 times favorited | 10 comments | ![]() |
- Rockler Cove Cutting Table Saw Jig
- Brand: Rockler | Category: Other
For the production of architraves in my house I recently decided to pick up a cove cutting jig on sale at rockler. This is a video review of the product. I’ll let the video speak and not repeat everything here. If it works for me it can work for anyone. Thanks for watching.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://gagnerwebsite.com/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
10 comments so far
Jimi_C
home | projects | blog
506 posts in 1406 days
#1 posted 608 days ago
I make raised panel doors on my tablesaw the same way, and it’s not that bad as long as you do them all at once. That is, run all the pieces through at the set height, raise the blade, and then repeat. 8 passes and you’re through 1/2” of wood, so it goes pretty quick once you get in a rhythm. The hard part is cleaning up the curve afterwards – the saw blade leaves a pretty rough surface, even if you go pretty slow.
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
Dusty56
10516 posts in 1859 days
#2 posted 608 days ago
Hi Dan , Excellent video and review of your new toy : )
What type of blade / how many teeth , do they recommend to use ?
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
27262 posts in 1993 days
#3 posted 608 days ago
This is a nice review, Daniel. I have looked at these and been considering getting one. Your review was certainly helpful.
2022 posts in 1609 days
#4 posted 607 days ago
Dusty, there is no recommendation for teeth on the blade. I’d imagine that the more the better. I have at times, put in a 7 1/2” blade in my 10” table saw from time to time when I haven’t needed the blade height and found that the smaller blade gives the motor a better mechanical advantage. Of course one would be limited to a narrower cove but if I ever do some smaller coves I might do that again.
Jimi_c, Good idea about the door panels. And yes the blade does leave narrow horizontal striations in the wood. A scraper seems to handle that well tough and mentioned in the directions of the rockler jig it said to do a very light pass on the last one. That seemed to help a bit. I also made a mirror image curved sanding block and wrapped it with 36 grit sandpaper. That seemed to take off the saw marks really fast. Then to the scraping and final incremented sanding.
Dusty56
#5 posted 607 days ago
Thanks for the info , Dan….I hope to see the end results installed : )
Have a great weekend !
Len
#6 posted 607 days ago
Well, actually Dusty…. I finished them today. No poly’d yet though. You can see the cove in the bottom half of the top arch. The very top is a double ogee stacked one atop the other. I’ll post it as a finished project later. I also used the Rockler fluting jig for the side moldings. I’ll get something on that later. It also works pretty nicely.
Dusty56
#7 posted 607 days ago
That looks awesome , Dan ! Million dollar window moldings , for sure. Thank you : )
#8 posted 607 days ago
Cessna, the snowblower? It’s almost time!
ArtistryinWood
82 posts in 1858 days
#9 posted 607 days ago
Nice job Daniel,
CMT has a crown molding set with a cove cutting head, Supposed to cut smoother than a TS blade, A bit pricey though $153.30 on Amazon.
http://www.cmtutensili.com/show_items.asp?pars=RIC~235.ric~2~2~3
Andrew
-- It seem's to me i could live my life, a lot better than i think i am. Andrew, Midland, Ont.
#10 posted 605 days ago
yes Artistry I see them on Amazon. A bit pricy but I’ll bet it does a nice job. Sort of a router bit for the table saw. The whole crown molding kid is over $300!
