Wood Slicer
Review by CartersWhittling posted 610 days ago 4441 views 2 times favorited 29 comments Add to Favorites Watch
Wood Slicer No-picture-s No-picture-s Click the pictures to enlarge them
Hello. I just got a new Wood Slicer Resaw blade from Highland Woodworking. After reading the setup and description of the blade I put it in my bandsaw and used a scrap 8/4 piece of oak to set the drift angle. Then I put a 10” maple log through the saw. Here is some pictures of the log I cut. The right half was done with a resaw blade that I got with my bandsaw from the previous owner and the left half is with the wood slicer.
A little nicer I think.
I bought both a 1/2” wide and 3/4” blade. It cuts very smooth and quickly aswell. Its also so quiet that my sister in her bedroom directly above the garage could not hear it. For anyone looking for a good resaw blade look no further.
-- And whatsoever ye do, do it heartily, as to the Lord... Colossians 3:23
View CartersWhittling's profile
CartersWhittling
444 posts in 845 days
29 comments so far
View superstretch's profile
superstretch
1457 posts in 865 days
#1 posted 610 days ago
Nice. I’ve had my new blade on my porch for almost a week, since I’ve been sick and haven’t gotten the chance to install it.. Have you tested the 1/2” vs the 3/4”? What band saw do you have?
-- Dan, Rochester, NY
CartersWhittling
#2 posted 610 days ago
I have only tried the 3/4” I’m sure the 1/2” isn’t much different, but only guessing. I have a 16” Laguna bandsaw with a 2.5hp motor. If you go to my workshop you can see it.
superstretch
#3 posted 610 days ago
Sweet deal. I just scored a 16” Grizzly industrial that is a few years old and still running what looks like the original blade.. Definitely jealous of that Laguna tho.
View lashing's profile
lashing
106 posts in 992 days
#4 posted 610 days ago
I have been thinking of trying this blade for awhile but thought it was all hype. Thanks for the review and info.
View Eric_S's profile
Eric_S
1522 posts in 1367 days
#5 posted 610 days ago
A picture is worth a thousand words. Nice review. I used the woodslicer, then used the wolverine, and I didn’t like it so I went back to the woodslicer and couldn’t be happier. My favorite blade. I have a 103” 1/2” woodslicer for the G0555 14” with riser.
Lashing, it’s definitely not hype. It really does cut through wood like butter.
-- - Eric Indianapolis, IN
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6253 posts in 1606 days
#6 posted 609 days ago
The wood slicer is a great blade and does what it says it does, makes a beat up BS saw like a caddy.
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
View timber715's profile
timber715
60 posts in 1276 days
#7 posted 609 days ago
I have had a 3/4 and 1/2 wood slicer for a while. and from my impression the sharpness doesn’t hold very long. I have been cutting 11” mahogany boards. Though they seem to do a great job resawing, I just hope they would last longer.
-- timber715 - Manila, Philippines
View 000's profile
000
3352 posts in 788 days
#8 posted 609 days ago
How many pounds of tension are you able to put on it?
-- When the moderator chooses sides, his site sucks.
View ChunkyC's profile
ChunkyC
849 posts in 1426 days
#9 posted 608 days ago
Awesome review. Mine just shipped this week, it was on back order. I was hoping to get it for this weekend. Now I really can’t wait for the mail to get here.
thanks,
c
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
View twoblacklabs's profile
twoblacklabs
120 posts in 863 days
#10 posted 608 days ago
Great way to do a review. Simple, to the point and with PICS!
-- If You Haven't Got the Time to Do It Right, When Will You Find the Time to Do It Over?
View Pdub's profile
Pdub
827 posts in 1351 days
#11 posted 608 days ago
Have to remember this when its time to buy new blades. Thanks!
-- Paul, North Dakota, USAF Ret.
timber715
#12 posted 608 days ago
I cannot really be too sure how much tension is enough or measure it properly, but the Rikon has a gauge of tension. for 3/4 I tensioned it just enough to read 3/4 on the gauge. for the 1/2 I reached 5/8 on the gauge since it gave me the 1/8 to 1/4 deflection…
View 000's profile
000
#13 posted 608 days ago
The Rikon Gauge ought to be pretty decent.
At 3/4 you should be about 15 thousand pounds
At that tension, with a new blade, you ought not to have to compensate for drift, but rather to have the fence perfectly aligned with the blade. I suspect that if you have to tweak the fence then, it’s all in the guides holding the blade at a slight angle.
superstretch
#14 posted 607 days ago
I swapped to the 3/4” Wood Slicer blade today on my G1538. I could not believe how quiet it was or how gorgeous of a finish it left. I resawed a piece of maple (3” wide or so and 3’ long) in less than 10 seconds. The finish was better than what my old table saw left. I ran some 4.5” wide, 1/4” thick cedar lining through on its side and was able to resaw it into 3 pieces. This is the finish it left behind in this super-soft wood:
My hand as a reference:
timber715
#15 posted 607 days ago
I did compensate for the blade drift. and tweaked just about everything there is to tweak on the bs. bearing spacing, fence alignment (corresponding to blade drift), even checked the table for squareness (which it wasn’t) but was able to shim it a bit, checked tracking on both top and bottom wheels. Though I wasn’t able to check top wheel against the bottom wheel for squareness ( I don’t have a straight edge that is long enough).
I do love the blade (I have cleaned it twice also) but it does dull a bit fast. I would buy it again though, but will try another first.
showing 1 through 15 of 29 comments
