Angle Checker
Review by Don W posted 611 days ago 1916 views 0 times favorited 10 comments Add to Favorites Watch
Angle Checker No-picture-s No-picture-s Click the pictures to enlarge them
I bought this angle checker being I was ordering a bunch of other stuff from Woodcraft. I’ve seen these almost everywhere so I figured it would be handy to have at my sharpening bench. Bottom line, it just doesn’t work. When you slide a plane blade in (even a thick iron) it goes into the hole cut at the end so the angle of the blade really doesn’t register. You can pull it back some and “eye ball” it, but if your going to eye ball it, you might as well just use a piece of wood.
Don’t waste your money.
I’m back to using this, and figure its the best way anyhow;
View Don W's profile
Don W
9967 posts in 739 days
10 comments so far
14860 posts in 2389 days
#1 posted 611 days ago
Chalk another one up to “It seemed like a good idea at the time.” :-)
View woodzy's profile
woodzy
412 posts in 850 days
#2 posted 611 days ago
I’ve seen those around. They do look handy, so i don’t blame you.
Actually it’s that steel protractor you have that i want.
I think you just saves a bunch of us $10.
-- Anthony
View Dan's profile
Dan
3480 posts in 1051 days
#3 posted 611 days ago
If your looking for something to help you better with finding bevel angles I would suggest checking out one of those digital angle cubes. A number of companies make them. I got mine through woodcraft and I want to say I only paid somewhere between 20 and 30 dollars for it.
I use mine to set the bevels on all of my irons and chisels and it works great for me. As long as you have it set on a level surface it will read out the exact angle for you. Its got magnets on it so I can place the cube on a plane iron then have my other two hands free to lock the iron in my eclipse jig once I am at the angle I want. Very helpful tool for sharpening. I wouldn’t be without it.
-- Dan - "Collector of Hand Planes"
View JSilverman's profile
JSilverman
79 posts in 784 days
#4 posted 611 days ago
I totally agree.
someone bought me one of those angle checkers many years ago… I had the same experience so now it lives on my pegboard and hasn’t been used in a long time…. it did look useful, just didn’t live up to expectations.
View CharlesAuguste's profile
CharlesAuguste
126 posts in 712 days
#5 posted 611 days ago
Yes i got one of those been collecting dust for ages…........
-- "the future's uncertain and the end is always near" J. Morrison
View Dusty56's profile
Dusty56
10524 posts in 1859 days
#6 posted 611 days ago
Thank you …I’m sure WoodCraft would take it back under their satisfaction guarantee.
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View wb8nbs's profile
wb8nbs
108 posts in 863 days
#7 posted 611 days ago
I bought the same gauge and had exactly the same experience. Think I got it from Rockler. It appears to be a Chinese copy of the Veritas gauge at http://www.veritastools.com/products/Page.aspx?p=118 that probably doesn’t work either. I note the gauge is useful for chisels which are generally a lot thicker than plane irons.
I also use the metal protractor as in the photo. It works OK for angles greater than 25 degrees but for lower angles the bar falls off the end. I also own a precision vernier protractor that is even worse at setting up small angles. I could make my own angle gauge out of plexiglass or aluminum. I have found that for small angles it is much easier to lay out a triangle with rise and run appropriate for the angle, than to use a protractor.
Never thought about using my Wixey gadget. I’ll try that.
-- The only difference between men and boys is the price of their toys.
View Arminius's profile
Arminius
219 posts in 1974 days
#8 posted 611 days ago
I have this one and have also used the Veritas one. I like them both, and use them frequently. It looks like that clone simply has slightly larger openings making it harder to register the angle. That said, I don’t normally use them for plane blades anyway, as wb notes above, I use it for chisels.
TopamaxSurvivor
13194 posts in 1847 days
#9 posted 608 days ago
Thanks for the tips. I have seen thouse and almost bought one ;-)
View JayPique's profile
JayPique
61 posts in 1459 days
#10 posted 602 days ago
I have one, and I used it today when I sharpened up some coworkers’ chisels at work. It’s a quick way to see the primary bevel so I can set up the Veritas honing guide I use. I pretty much have it near my stones at all times.
JP
