Cranked Trimming Chisel
Review by speakerscott posted 09-16-2011 04:43 AM 3534 views 0 times favorited 11 comments Add to Favorites Watch
Cranked Trimming Chisel No-picture-s No-picture-s Click the pictures to enlarge them
I got this to trim some pocket screw plugs.
Pro’s
Takes a good edge, beautiful steel.
Con’s
Umm…that cutting edge is no where close to square with the chisel. How the heck do I fix that? Maybe I just think of it as a cranked neck skew chisel?
-- Scott, Austin-Texas...
View speakerscott's profile
speakerscott
47 posts in 4040 days
11 comments so far
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3317 days
#1 posted 09-16-2011 07:29 AM
thank´s for the rewiew
what do you meen by that ” not Square with the cheisel ”
not that I will defend Hirsch/two cherry if they have made some junk
but it doesn´t look like them to make that
and when they call it the only parringcheisel you can use a mallet on
then I wonder even more
Dennis
speakerscott
#2 posted 09-16-2011 01:23 PM
The cutting edge is not at 90 degrees to the chisel, it is angled slightly like a skew chisel. There is a reason for the angle on the skew chisel…but in this case I think this is just an accident. I’ll try and take a picture to show it…but I have lousy camera skills, so that may take a while.
Dennisgrosen
#3 posted 09-16-2011 01:58 PM
as long as you dont have to make paparys as I have before I can sent them over the morsekey
then I don´t think you shuold complain ….. LOL
hit us with your pictures of art :-)
Dennis
View woodzy's profile
woodzy
418 posts in 2881 days
#4 posted 09-16-2011 02:36 PM
I’ve seen someone turn an old chisel in to a skew chisel.
I assume it would be the same process. Grind the chisel to the correct angle then regrind the face and bevel to your desired angle.
Quite the process, and one i would seek the hlelp of a professional or at least someone with experience.
But if they are new chisels and way off I would return them.
I now realize all chisels require a degree of work when you buy them new or even used, but somethimes it’s just more work than one has time for.
thanks for the review.
-- Anthony
speakerscott
#5 posted 09-16-2011 02:41 PM
Oh, I’ve re-ground chisels to angles, straightened them etc…the deal is, they are all flat backed chisels that I can reference on my Tormek. Not sure how to reference this thing since it won’t fit in a jig. Might have to carefully do it by hand.
Scott
Dennisgrosen
#6 posted 09-16-2011 02:55 PM
it shuold be possipble to do it with one of the smaller rolling jiigs on a stone or sandpaper
speakerscott
#7 posted 09-17-2011 01:27 PM
Dennis,
It might be with some of the fancier rolling jigs. I have a cheap one that came with my Norton stone 3-pack, and it won’t work. Oh well…I spent about 20 minutes very…very carefully trimming it up on my Tormek using one of the jig rests as a guide..not ideal but far better.
Scott
Dennisgrosen
#8 posted 09-17-2011 07:03 PM
sounds good :-)
I gess you have to make a block that fits the curve on the cheisel nest time it need a tuch up
and do it with sandpaper on glass I gess that wuold be easyer
I think I ask dieter smidt´s tools in germany next time I buy something at him
to hear what he recoment will be the best way I know he has connection to
the factory ….. some just got to know the best way to tackle this cheisel
take care
Dennis
View JayPique's profile
JayPique
61 posts in 3490 days
#9 posted 09-30-2011 03:14 AM
I’ve had one of these chisels, and they are indeed fussy to sharpen square. But the bigger frustration for me was that the curved nature of the blade makes for a somewhat short flat spot, and this in turn makes it easy for it to rock. I prefer the Crown style crank-knecks that are flat all along the blade.
JP
Dennisgrosen
#10 posted 09-30-2011 05:35 PM
JP I don´t know if you are aware of they are made for timber work and not for fine pairing work
Dennis
View rance's profile
rance
4266 posts in 3362 days
#11 posted 09-30-2011 05:52 PM
Rough them with a belt sander. Then hone on a stone.
