Excellent plane...
Review by speakerscott posted 09-16-2011 04:31 AM 3048 views 1 time favorited 2 comments Add to Favorites Watch
Excellent plane... No-picture-s No-picture-s Click the pictures to enlarge them
Pro’s
Awesome little plane, once adjusted it will do a very good job of planing flush in tight spaces or very detailed work.
Con’s
Somewhat tricky to get the blade into the plane after sharpening without nicking the corners.
Blade took a bit of work to get the machining marks out of it, and the base of the plane was slightly cupped, which required some lapping to get it flat.
If these sound minor, they are…once set up you’ll find yourself using this thing just to use it.
-- Scott, Austin-Texas...
View speakerscott's profile
speakerscott
47 posts in 3709 days
2 comments so far
View WayneC's profile
WayneC
13751 posts in 3968 days
#1 posted 09-16-2011 06:01 AM
Thanks for the review. What types of projects are you using them on?
speakerscott
#2 posted 09-16-2011 01:20 PM
I only bought the flat one. I built a staircase where I had to come back and add some Kreg pocket hole screws and plugs. I bought the cranked neck chisel and plane to help get those plugs flush with the existing finished wood. I don’t have enough room to use a flush cut saw or sand….so I was pretty stuck on how to do it.
Scott
