Great little machine
Review by lilredweldingrod posted 09-03-2011 08:15 AM 16155 views 0 times favorited 15 comments Add to Favorites Watch
Great little machine No-picture-s No-picture-s Click the pictures to enlarge them
I’ve had this shaper for a little over 3years now. I bought this on a whim as I did not have a router table at the time. I never had the intention of using it as a shaper due to the cost of the cutters.
I found that if you want to use it as a router table, you have to install 5 spacers under the table to raise it up to work with router bits otherwise the bits are way to high to use. This is the hardest part of the assembly job. The cast Iron table is one heavy piece to handle and place the spacers and longer metric bolts.
The first time I used this was to cut a slot in a 48 inch 1×4 oak plank. I learned that if you don’t know what you are doing you get to have a permanently separated shoulder. Check. Yep I got that. It matches the left one I separated in a car roll over in 2005. Due to my lack of experience with shapers, I now have matching jacked up shoulders. BUT this is not the fault of the machine in any way.
After I recovered from my fear of this thing, I have found it to be a very useful tool in my shop. I love the cast Iron top as it makes very nice even cuts. The only thing I don’t care for is the stock fence. It has taken me a while to remedy the problem of the fence constantly loosening up and moving around the table. I now use two hardened metric bolts with hex heads that I tighten with my impact driver. Problem solved.
The 1 horse motor give more power that is actually needed and handles the 3 inch raised panel bits with ease, but at a very high rate of speed. I wish there was a speed control for this motor. I bought the router speed control from MLCS but then found out that the motor is not compatible with the speed control due to the capacitors in the motor.
I have lowered the stand 5 1/2 inches to be more compatible with my wheelchair and I use it as an out feed table for my table saw.
I needed a new nut for the collet. It was murder trying to get one from Harbor Freight. Fortunately this unit is identical to Grizzly’s 3/4 hp unit. Any thing in parts you need for this is available from Grizzly. Maybe I’ll paint this one Grizzly colors and order a new Grizz sticker. lol
So if any one is in the market for a router/shaper I highly recommend the Harbor Freight, or a Grizzly for that matter.
OK guys beat this double review of two manufactures and one machine. lol
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3221 days
15 comments so far
TopamaxSurvivor
18355 posts in 3791 days
#1 posted 09-03-2011 08:24 AM
Thanks for the heads up on the shoulder issue. I like mine flat and square the way they have always been ;-))
Are you saying this shaper takes router bits? Or did you have to modify it? 1/2” or both?
lilredweldingrod
#2 posted 09-03-2011 08:41 AM
Bob It comes with 1/4 and 1/2 inch colletes as well as the shapper spacers and shaft. You can use either, but you will have to wrestle the cast top to either add or remove the 1/2 spacers under the table.
View dustprocrastinator's profile
dustprocrastinator
76 posts in 2801 days
#3 posted 09-03-2011 02:23 PM
Seems like a solid machine, case in point your separated shoulder. Thanks for the double review.
View Joe Lyddon's profile
Joe Lyddon
10236 posts in 4167 days
#4 posted 09-03-2011 07:50 PM
Did that come from Harbor Frt… or am I thinking of something else?
Looks like a good machine…
Better than a Router?
lilredweldingrod
#5 posted 09-03-2011 09:18 PM
Yes Joe. I bought it at good ole Harbor Freight. They do have some good products, but you have to be careful.
Joe Lyddon
#6 posted 09-03-2011 10:02 PM
Shaper vs Router…
Pro’s:
Con’s:
Thanks.
View RichTes's profile
RichTes
11 posts in 3142 days
#7 posted 09-05-2011 12:28 AM
It looks like the small Delta/Rockwell shaper (cast iron top, 1/2” spindle). They were a pretty solid little machine.
TopamaxSurvivor
#8 posted 09-05-2011 02:10 AM
Rand, I googled your part number with Harbor Freight. I got three Harbor Freights near Pleasant Grove, CA instead of a shaper ;-)) I found it, but I decided I don’t use my routers enough to get one for $300. Not to mention, no room. Hope I get my router table added to my table saw one of these days ;-)
View WayneC's profile
WayneC
13765 posts in 4212 days
#9 posted 09-05-2011 02:21 AM
Hmmm. Pleasant Grove is about 15 minutes from my house in Northern, Ca. I think Rand is alot further south.
TopamaxSurvivor
#10 posted 09-05-2011 02:23 AM
Part # @ HF just happens to be thier zip code ;-)
lilredweldingrod
#11 posted 09-05-2011 09:00 AM
Bob, it is a very small package and I use it as much as i do my PC7815 in the Woodpecker PRL V2. It only needs floor space of 1 1/2 feet by 2 feet and a 110v plug in.
Wayne, I’m a lot further south. I’m 2 blocks form hell. lol
View helluvawreck's profile
helluvawreck
32051 posts in 2981 days
#12 posted 09-05-2011 03:30 PM
Nice looking little machine for a home shop. I don’t have any more room for anything else. I wish I could add 12 more feet to my shop and also a storage shed.
View Dustin's profile
Dustin
392 posts in 3565 days
#13 posted 11-24-2011 07:33 AM
I have a Shop Fox 3 hp shaper, two Shop Fox 2 hp shapers with power feeders, and I have a 1 hp Shop Fox shaper (exactly like this one). I use the 1hp shaper with router bits and it’s AWESOME. And then of course the 2 and 3 hp with shaper cutters. Each has it’s own specific job, each are wonderful machines.
Great review!
View macatlin1's profile
macatlin1
78 posts in 3058 days
#14 posted 11-16-2014 12:54 PM
I found out (the hard way) that the 1/2 collet is metric. The collet snaps into the collet nut and cutters should slip in and out freely, except the metric collet cannot open up to 1/2 inch when the collet is snapped in. Turns out the end of the collet is restrained by the collet nut. Forcing the nut down on a “loaded” collet will bugger up the snap flange and the collet will loosen after a short time. I purchased a replacement collet nut from Grizzly before I discovered this problem and then purchased a 1/2 inch collet (also from Grizzly) total was about $40. I had tried to machine the collet nut’s opening a bit larger but the hardened steel was too much for my hobby lathe. With the proper collet, now things work properly.
When I checked with Harbor Freight about ordering the collet nut the reply told me that they do not stock replacement parts. This is my main gripe with Harbor Freight, lack of replacement parts.
After downloading the Harbor Freight and Grizzly manuals and doing a side by side comparison I found that the HF shaper is a Grizzly down to the last nut bolt and screw.
I use my shaper table for pattern shaping for making model airplanes and it works great with out a lot of noise as compared to my Craftsman router. I did make my own fence system and I am still trying to develop a dust collection method.
Enjoy!
View Cobijones's profile
Cobijones
5 posts in 2371 days
#15 posted 10-25-2016 11:44 PM
Having to choose between a router and a shaper there is no comparison. I’d go with a shaper all the way. However, having said that they are not the same. A shaper is purpose built and designed as a table and will last a lifetime. You can replace the motor and it is reversible which makes it very flexible. Shapers are quiet compared to routers and having larger range of profiles and sizes available.
Routers on the other hand are designed to be handheld and portable. Routers are OK at just about everything but only really good at small profiles. And routers are LOUD! When you work in a shop every day seven days a week you’ll want a shaper. This little shaper is a bargain especially with a 20% off coupon at HF.
