Needs more refinement
Review by funchuck posted 682 days ago 1822 views 0 times favorited 6 comments Add to Favorites Watch
Needs more refinement No-picture-s No-picture-s Click the pictures to enlarge them
I already have the Veritas wheel marking gauge w/ micro adjust, but I wanted another marking gauge because oftentimes, I wanted to save my settings, but with only 1 marking gauge, I couldn’t. I found this at Lee Valley for $20 and it was 2 marking gauges in 1, so I figured it was a good deal.
One unexpectedly nice thing about this gauge is that it will not roll off your bench. I have had my large (and more expensive!) wheel marking roll off my bench before, and the cutter got damaged. The pocket marking gauge won’t roll, so I like that feature.
The cutter is also very good quality, and it is small enough that you can carry in your pocket and keep it handy.
The smaller fence doesn’t bother me either. So far, I have not felt a need to have a bigger fence, actually.
But, I have found that you have to really tighten the gauge down, otherwise when you are marking your piece, the fence will slip and you lose your setting. This has gotten me several times, and I end up having errant marks on my piece, which doesn’t look good at all. I have never had this problem with the more expensive Veritas wheel marking gauge, they are very easy to lock down and they don’t budge when they’ve been locked down.
The other issue I have is that the fence is very loose so when you are trying to set the fence, you have to be very careful, otherwise, when you are locking down the fence, the fence might move slightly. With the bigger Veritas wheel marking gauge, the fence doesn’t slide so loosely, so it is easy to lock it down without having it shift around.
It is still a usable tool, but I can’t give this tool more than 2 stars. The larger Veritas wheel marking gauge is a lot better.
-- Charles from California
View funchuck's profile
funchuck
99 posts in 1254 days
6 comments so far
View Dennisgrosen's profile
Dennisgrosen
10851 posts in 1312 days
#1 posted 682 days ago
thank“s for the rewiew
hope they will take care of it … fast
Dennis
View Dusty56's profile
Dusty56
10720 posts in 1885 days
#2 posted 682 days ago
Have you contacted the company with your issues / dissatisfaction with their tool ?
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View David Grimes's profile
David Grimes
2065 posts in 836 days
#3 posted 682 days ago
Good review. I’m needing some of these, so glad to get a heads up.
Probably little they can do without making it “larger”... maybe improve the knurled knobs for torque (a tiny “t” or “L”, perhaps), increase the thread diameter for greater surface contact with the tiny shaft, but keep the threads fine if they aren’t already. That’s about all they could do IMO.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View ChuckM's profile
ChuckM
460 posts in 1863 days
#4 posted 681 days ago
I have this gauge and, like 3fingerpat, have not experienced the problems you reported. It’s possible that despite the strict QC process Veritas has, your gauge has a defect. Please contact the Customer Service and they will quickly resolve your concerns if the tool is in fact defective,
Given the small size, it’s also possible that too much lateral force could cause one of the problems you encountered. The larger one which I have used, I believe, has a larger screw and hence better grip for the fence.
Those who have used the larger gauges need to “relearn” how to use this smaller cousin in terms of applying force, adjusting the fence, etc. As a suggestion, whether with the large or small gauge. scribing with gentle force in the first one or two passes is preferable.
-- The time I enjoy wasting is not time wasted
View JasonD's profile
JasonD
167 posts in 1058 days
#5 posted 681 days ago
I’ve got the same problems with mine. I used coarse sand paper around the shank. It helped some, but didn’t fix the problem entirely.
Thanks for the “relearning” tip, ChuckM. Next time I use it, I’ll try to use a lighter touch to see if that helps.
View lashing's profile
lashing
104 posts in 1018 days
#6 posted 679 days ago
Lee Valley sells some really good stuff and unfortunately they also sell the same really cheap crap items others do. The good this is they will take it back without issue. I do wish they would decide whether they are a premium goods or a dollar store. Perhaps its what they have to do to make the bottom line, I dont know.
