Review of DELTA X5 6" Professional Jointer
Review by Delta356 posted 07-25-2011 09:40 PM 17471 views 1 time favorited 13 comments Add to Favorites Watch
Review of DELTA X5 6" Professional Jointer No-picture-s No-picture-s Click the pictures to enlarge them
After my little Craftsman 4” jointer died, circ 1951, I decided to up grade. I looked at a lot of brands and me being a big Delta fan I decided to go with there DeltaX5 6” professional jointer.
This machine comes in two boxes one contains the motor/stand, and other goodies. The other box has the jointer and fence system. Once again I have to deal with a heavy Delta box. The machine took about an hour to put together.. One thing that is nice is Delta already mounts the motor, and the bolts are loose so the woodworker can make any adjustments to motor.
One thing I might add is how quite this machine is. You could work all night with out waking anyone up.
This jointer is like the Porsche of jointers. Its got it’S class and a little blinnn…and the motor size is just right…
I bought this jointer at my local Woodcraft with 15% off..
The jointer put together.
The X5 logo, you can’t beat it.
The jointer comes with a nice set of white push blocks..
You can beat Dust collection, so Delta provides you with a Dust Chute. If you don’t like it can come off.
Depth handle. Really smooth, I like this better then the hand wheel types.
The Depth scale is very nice with two look sets and is very easy to read.
The jointer has a 6” quick release jointer head with 6” knives. (3 total)
The jointer is powered by a 1 hp fin and fan cooled inclosed motor. You can run this bad boy for a long time.
The switch is on a very well constructed support and is easy to turn on and off.
The Switch is a paddle switch which is very easy to turn on and off. 5 points for Delta…
Onto the Fence.
The Fence is mounted onto a rack and pinion system which is great. makes moving the fence easy, and smooth.
Move the little chrome lever and twist the black nob and the fence will move. Really nice Delta…
Away it goes.
The fence can be tilted 45 both back and front, with lifting this lever.
This little black lever is moved so the fence can tilt back 45.
Then with this nice chromed knob you can tilt the fence.
Other way…
As you can see this jointer can take anything you throw at it.
With the 46” long bed, long boards have no problems with support.
That is the end of the review.
This jointer was 98% trouble free.
I had a problem putting the cutter head guard on but was able to get it on and working.
Also the finish of the jointer was good, but the paint job was pealing in places, because of the oil.
I called Delta Machinery that day and they sent me a can of touch up paint and I got the paint the next day, no questions asked.
Thats why I buy Delta…
Whether you are a Pro, hobbyist, or DYI this jointer is a great jointer and will meet all your needs.
Thanks, Michael Frey
Portland, OR
FREY WOODWORKING INC.
View Delta356's profile
Delta356
463 posts in 3089 days
13 comments so far
View Tedstor's profile
Tedstor
1678 posts in 2867 days
#1 posted 07-25-2011 10:01 PM
That fence is sweet. I’m currently using the same type of 1950s Craftsman jointer. So you can see where I’d be jealous of that fence.
View DrDirt's profile
DrDirt
4526 posts in 3977 days
#2 posted 07-25-2011 10:04 PM
Congrats – that’s the one I have. Works like a champ.
Delta356
#3 posted 07-25-2011 10:05 PM
(Tedstor) My old jointer is the same onE you are using, its nice upgrade to the rack and pinion. The old one was not that bad for me….
Portland, OR
View Bertha's profile
Bertha
13551 posts in 2928 days
#4 posted 07-25-2011 10:06 PM
This is a very nice jointer. I looked hard at this before I got my Steel City (the deal was too good to pass up). Nice purchase, Michael!
View ajosephg's profile
ajosephg
1880 posts in 3796 days
#5 posted 07-26-2011 01:45 AM
Notice that the depth of cut goes up to 1/2 inch. Can you really cut that deep?
-- Joe
Delta356
#6 posted 07-26-2011 03:34 AM
(ajosephg) I could not agree more. I won’t even try it..
Portland, OR
View dustyal's profile
dustyal
1299 posts in 3710 days
#7 posted 07-26-2011 03:10 PM
Thanks for taking the time to photo, write and post. I appreciated your inclusion of the noise level… that can be one feature that separates the machines.
-- Al H. - small shop, small projects...
View scrabby's profile
scrabby
42 posts in 3421 days
#8 posted 07-26-2011 09:13 PM
I’ve had this same jointer for a year now – only jointer I’ve owned, but I’ve used several industrial jointers for comparison. Thie X5 handles maple boards, up to 6”, beautifully, and I often end up using the jointed face for finishing. I use paste wax every time I fire it up (only a couple times per month), which definitely help boards glide across with little effort.
Agree fully with the noise level – very pleasant low, whirring hum…reminds me of the Mazda RX-7 from my youth.
My only negative comment is with respect to dust / shavings collection with this unit. When jointing faces, why do all the shavings go onto the infeed side, and the collection port is below the outfeed table? I use a shop vac / cyclone system, which is picking up plenty of shavings too, but I find I’m wiping shavings before placing every board down. Has to be a way to collect shavings on the infeed side!
-- Jim, North Vancouver, BC
Delta356
#9 posted 07-26-2011 09:43 PM
(Scrabby), if you look into the shaving chute there is a metal defeleter on the in-feed side, which should make chips be collected easier, but I really have not done face jointing let. Thanks for the heads up.
Portland, OR
scrabby
#10 posted 07-26-2011 10:18 PM
Good tip – I’m going to take a look tonight to see if I’m somehow deflecting shavings the wrong way.
Delta356
#11 posted 07-31-2011 06:22 AM
Thank you all for commenting on my review. I hope I have written a good review and have informed all on this tool, form the dislikes to likes.
Portland, OR
View Dusty56's profile
Dusty56
11830 posts in 3923 days
#12 posted 08-26-2012 03:58 PM
”Notice that the depth of cut goes up to 1/2 inch. Can you really cut that deep?”
That depth is for rabbeting purposes , not normal face or edge jointing : )
View PPK's profile
PPK
1246 posts in 1044 days
#13 posted 03-22-2016 04:12 PM
I own this machine also. It has served me very well. When I purchased it new from my local tool store, I did have to exchange the fence, as it was bowed. However, the new one is good, and it is a good, solid, heavy machine. I just finally changed out the cutterhead blades the other week, and it works like new again! (Yes, it should have been done long ago…)
-- Pete
