| Review by Jimi_C | posted 690 days ago | 2105 views | 0 times favorited | 16 comments | ![]() |
- Portamate Wood Rack
- Brand: Portamate | Category: Other
I just got done installing this and loading it up, so I thought I’d post a quick review. I saw Woodcraft had these on sale, and I was sick of having all my lumber on my basement floor, so I went and bought two. The instructions recommend a 4-6’ distance between racks, but I wanted to be able to store some shorter lumber on them so I spaced them every other stud, for ~ 32” and a total width of 8’. Each pair is rated at 100lbs per level, so this should give me the ability to hold 200lbs per level for longer boards.
Assembly was the most frustrating part. The racks simply slide down over the standards, and are held at each level with a set screw. The screw doesn’t attach the metal, the brace just rests on it via gravity. Those screws were the pain point – some of the holes were either not correctly drilled, or some of the screws were low quality because on 3 of them the threads actually folded over preventing the screw from grabbing and advancing. I had to take a file to the threads to remove the bent part, which was very frustrating. Once they were all assembled, attaching them to the wall was simple – just used three 1/4” x 4” hex-head lag bolts for each rack, making sure to hit the center of a stud (pre-drilled with a slightly undersized bit to prevent splitting). A spacer keeps the rack slightly off the wall, so there’s actually about 1.5” followed by 1/2” of drywall – leaving about 2” of lag bolt in the stud. I figure with three of them per upright, that should be plenty of grabbing power since I don’t actually plan on loading up 200lbs of wood per level.
The only downside is the fact that I got these racks for a recent Craigslist score (picture of my SUV loaded up). Unfortunately, the lumber I already had in my basement nearly filled it up! I could easily use two more sets, and I would definitely buy these again. If it weren’t for the issues with the set screws, I’d give this a 5/5, especially at just $40 per pair while on sale.
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
16 comments so far
thirdrail
home | projects | blog
13 posts in 835 days
#1 posted 690 days ago
Gee, that seems like a chancy system compared to the Rockler version I bought at full catalog of $30/pr. Take a look at http://www.rockler.com/product.cfm?page=25156&filter=39227&pn=39227
Bart
-- Third rail
Jimi_C
506 posts in 1406 days
#2 posted 690 days ago
Chancy how? The racks felt rock solid once they were attached to the wall, and the steel does not seem wimpy in any way. Also, that Rockler system only has 3 levels – the thing I liked about this one was that it had 6 levels.
John Daugherty
33 posts in 1607 days
#3 posted 689 days ago
I’ve got this same set from when it was branded triton. It’s been great. I’ve got it loaded to the gills without any problem.
Delta356
433 posts in 1025 days
#4 posted 689 days ago
Looks great, and a good deal, were is it made ????
Thanks, Michael Frey
Portland, OR
FREY WOODWORKING INC.
Jimi_C
#5 posted 689 days ago
@Delta356: China, unfortunately.
rodneyh
103 posts in 835 days
#6 posted 689 days ago
I’ve got 2 of these racks and 1 of the Rockler racks and love them both. I spaced mine 64” apart. For short boards, I covered 2 of the levels with long wide boards (that I know I won’t need anytime soon), and then put any short boards on top of them. You’d essentially double your space if you did that.
Bertha
13111 posts in 864 days
#7 posted 689 days ago
Actually, the Rocklers are a completely different system, offered by many makers. I’ve bought the heavy duty Lowes versions, as well as the Rocklers. Even with the setscrew issue, yours seems like a more stable design. If you’re worried about the setscrews holding power, you could always drill them out and place a peg/bolt. I think you did well.
Jimi_C
#8 posted 689 days ago
@rodneyh: you can’t really see it, but I’ve got a window to the right, so the spacing on mine worked out just about perfect. I did consider using some plywood on at least one level to make a solid shelf that extended out a bit further for the small offcuts I have all over the place though.
@Bertha: Yeah, I considered getting a tap and using bolts instead of the screws. I’m not real concerned about them though, as the screws went in well – it was just the lower part of the threads that seemed to have issues. There were at least 2 full turns left after I filed off the bad part.
devann
1718 posts in 863 days
#9 posted 689 days ago
Jimi, your lumber racks look nice but looking at the wall framing I can see where I would add some fasteners at the floor joist/stud connection. A lag screw there would help. Myself I went for the DIY version.
http://lumberjocks.com/topics/26255
Jimi_C
#10 posted 689 days ago
Yeah, the previous owner “finished” the basement (very loosely using that term – you can see he put in no kind of ceiling at all). I’m not too worried about that though, it would take a lot more force to shear those screws out than what I’m going to load onto these racks.
I did think about making my own – the Wood Whisperer just had a video on his build, but for $80 I didn’t think I could beat the cost of materials. It was easier just going with the pre-made system.
David Grimes
2114 posts in 810 days
#11 posted 688 days ago
I have these as well (and have reviewed them on this site) and luckily did not have any problem with the screws or any part of assembly. They are extremely sturdy.
@rodneyh, I did the exact same thing to hold all my shorts. lol great minds think alike.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
Jimi_C
#12 posted 688 days ago
@David I read your review, it was one of the things that convinced me to get this set :)
Bret
162 posts in 1665 days
#13 posted 688 days ago
I just unpacked my set at our new house and have been eyeing up what part of the garage will house the racks. I also loaded mine up pretty well without any issues whatsoever, and also did the long-board-to-support-shorter-boards trick, though if I had it do do again, I probably would find some cubbyhole-type thing to store offcuts and shorter pieces in.
Congrats!
-- Woodworking is easy as 3.14159265358979323846264338327950288419716939937510...
docholladay
1258 posts in 1230 days
#14 posted 686 days ago
I have this same lumber rack only with a different brand on it. I can’t remember which brand name is on mine, but they are the same thing. I have had mine for several years and have found it to be a very stable rack. Sometimes, I would like a little more vertical space between levels, but that is not a major problem.
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
Woodfix
291 posts in 1470 days
#15 posted 676 days ago
Looks like it worked out okay in the end. need something like that myself but will probably knock it up rather than buy a product. Of course the downside is it will probably take me 4 times longer to do.
-- Living is a constant gamble, life is about working the odds in your favour
View all comments »
