Whiteside Router Inlay Kit
Review by pintodeluxe posted 07-02-2011 07:36 AM 7180 views 0 times favorited 5 comments Add to Favorites Watch
Whiteside Router Inlay Kit Whiteside Router Inlay Kit Whiteside Router Inlay Kit Click the pictures to enlarge them
I could not be more satisfied with this inlay kit from Whiteside. I have read the complaints about other brands, how they are tough to center. Rest assured, the Whiteside comes with a 1/4” centering pin. The bit is a standard 1/4” shank – no reducer sleeve to mess with. The bit is a solid carbide down spiral cutter. It is sharp and cuts cleanly in oak and walnut. The bit also comes with a protective case – a nice touch.
I have read reviews of other brands that the removable bushing is too tight or ill-fitting – not with the Whiteside- it has a good snug fit but not too tight. And how did the inlay fit? Perfectly.
Squaring the inside corners of a butterfly inlay with a chisel takes only a moment. Then lightly glue and tap into place.
I used a clear plastic template for the butterfly pattern (not included with the Whiteside kit)
Cheers!
View pintodeluxe's profile
pintodeluxe
5726 posts in 2869 days
5 comments so far
View bigike's profile
bigike
4052 posts in 3344 days
#1 posted 07-02-2011 08:24 PM
Hey thanks for the review I have one of the other brands and it works great for me I have no problem with them at all I do have two different brands cuz the other one was very cheap in price and the 1/8” bit was much longer than the other so I use the shorter bit for smaller less depth inlays and the other for bigger inlays with more depth.
View gfadvm's profile
gfadvm
14940 posts in 2746 days
#2 posted 07-03-2011 04:01 AM
How much does this kit cost? Where did you buy it?Where did you get the template for your bowties?Sorry for all the ? but Ive been trying to do bowties without much success.
pintodeluxe
#3 posted 07-03-2011 08:47 PM
The kit cost $32 becuase of the cost of solid carbide. I believe it to be better than the $19 kits with high-speed steel bits. It also comes with a centering pin, while some kits do not. The template is 1/4” clear plastic, which included several bowtie sizes, and costs $20. I prefer the factory made templates because I just can’t match the accuracy of a CNC machine. I would consider making a custom template for an irregular inlay such as a leaf or cougar track. Both the kit and template were purched at Woodcraft, however are available online as well.
Best of luck
pintodeluxe
#4 posted 10-04-2012 06:12 PM
Update: after a year of use and dozens of inlays later… the bit is still sharp and the kit works great.
Here is an inlay I used on a recent mirror frame.
A butterfly on a dining table :
gfadvm
#5 posted 10-05-2012 12:41 AM
Well, I broke down and bought the Whiteside router kit, template, and the universl base plate as my router wouldn’t accept the inserts. Kind of pricy but they all work as advertized.
