Perfect in every way.
Review by woodklutz posted 698 days ago 1583 views 0 times favorited 11 comments Add to Favorites Watch
Perfect in every way. No-picture-s No-picture-s Click the pictures to enlarge them
This blade is great for cutting box joints and dados. I prefer the 1/4 inch cut, the 3/8 inch is seems not as controlled (it is) but I still stick to 1/4. I tried this in a crosscut and a rip cut, both cuts were excellent. I was just too lazy to change my blade for 4 cuts. I believe that for the price $65 at Amazon it is the best bargain out there.
A purist would probably use this set for dados or box joint cutting only, but I a true woodklutz ripped 24” that was as good as you could get.
-- honing my craft one mistake at a time.
View woodklutz's profile
woodklutz
197 posts in 934 days
11 comments so far
View cranesgonewild's profile
cranesgonewild
344 posts in 1074 days
#1 posted 698 days ago
Good to know.
The latest Woodsmith magazine just did an article on box joints and they also mentioned this blade.
Apparently it makes a nice squared off cut.
I might get one of these.
Thanks for your input.
-- I'm a Fungi --
View gfadvm's profile
gfadvm
6611 posts in 856 days
#2 posted 698 days ago
I have the same set but paid $95 for mine! DAMN! But I do love them {much better than my previous dado set}.
View bluejazz's profile
bluejazz
50 posts in 953 days
#3 posted 698 days ago
Just don’t do what I did when you buy this set. First make sure your saw can handle an 8” inch dado set. My Craftsman saw was not up to it and I had to return the set to get a 6 inch dado set.
-- I'm 56. In my mind, I'm 26. Until I do something physical; then I'm 66.
View helluvawreck's profile
helluvawreck
10348 posts in 1032 days
#4 posted 697 days ago
Thanks for the tip.
View Paul Stoops's profile
Paul Stoops
273 posts in 727 days
#5 posted 697 days ago
I have this set as well. I have found it to be very useful for dados as well as box joints. I would highly recommend it. I think I paid around $90 a few years ago, so the $65 is a real steal.
-- Paul, Auburn, WA
View skippyland's profile
skippyland
158 posts in 857 days
#6 posted 697 days ago
I’ve had my set for quite a while now, and have found it to be very reliable…$65 is a great price. I liked the quality so much that I took the plunge for Freud’s dial a width 8” dado set…pricey, but worth every penney!
-- Skip from Batavia, purveyor of fine and exotic sawdust & chips.
View AaronK's profile
AaronK
1365 posts in 1630 days
#7 posted 697 days ago
i have this set too. I use it mostly for dados on my little benchtop table saw. very good quality cuts – those blades are sharp!
View RexMcKinnon's profile
RexMcKinnon
2590 posts in 1361 days
#8 posted 696 days ago
I have the Freud 8” dado set and I was curious what is the difference between this set and their standard dado set. The blades look the same. Did this some with special spacers for the box joint? Does it have less chippers and shimms than the dado set? Just wondering if you have one set do you in essence also have the other?
-- If all you have is a hammer, everything looks like a nail!
AaronK
#9 posted 696 days ago
there are only 2 blades with this. the teeth are set just right so that when the blades are faced “in” the blade width combines to 1/4” and when they face “out” they combine to 3/8”. There are no chippers and shims – this is meant to simplify things and was so designed for box joints.
RexMcKinnon
#10 posted 683 days ago
Cool, thanks.
View Don Clark's profile
Don Clark
21 posts in 683 days
#11 posted 674 days ago
I picked this up from Amazon for 65 as well. It makes super clean cuts – so nice not to have to chisel out the dados after cutting.
-- Don, www.happybungalow.com
