| Review by StevePWL | posted 674 days ago | 2969 views | 0 times favorited | 18 comments | ![]() |
- Grex Headless Pinners Models P635 1-3/8
- Brand: Grex | Category: Pneumatic Nailers
I purchased this gun in late Dec 07. I do a lot of trim on furniture and was sick of filling brad nail holes and not getting a good stain match. I had tried and returned a few other less expensive nailers so I wasn’t sure what to expect with the Grex. For the money ($199), I hoped it would be a good tool. After using it over the past few weeks, I am extremely pleased. I use the full 1 3/8” pin and they sink cleanly into the pine and poplar I generally use. The pin holes are very small and easy to fill. The trigger safety takes some getting used to but worth it. As there’s no safety at the nose, it will shoot pins into the air so you have to be careful. I would highly recommend this tool. It is expensive but has already saved me a lot of time and aggravation. Especially with power tools, you get what you pay for in most cases.
-- Steve, Massachusetts, www.petsweloved.com
18 comments so far
rikkor
home | projects | blog
11335 posts in 767 days
posted 673 days ago
Pin nailers are great in certain applications. I have one and find it very useful, too. (Not a Grex, however)
14156 posts in 1053 days
posted 673 days ago
shooting into the air… other types has to be pressed against something first, right?
Good thing the trigger has an awkward safety feature
mrtrim
1698 posts in 773 days
posted 673 days ago
what guage is this gun ? i actually prefer the trigger saftey . i have it on my 23 ga, pinner and wish all my pinners had it . i have to pin returns on very small mouldings and with a nose saftey , by the time i apply enough pressure to push the saftey down ive mialigned the piece
StevePWL
15 posts in 692 days
posted 673 days ago
Hi mrtrim,
The Grex is a 23 ga pinner. I like not having the nose safety so you don’t get that misalignment problem. The nose guard is very good too and prevents dimpling, even in soft pine.
Steve
John Gray
1751 posts in 778 days
posted 673 days ago
Yet another “must have” tool…...good review. Does this tool buying thing ever end? ;>) Hope not!
From an admitted tool junkie.
mrtrim
posted 673 days ago
thanks for the info steve
dalec
580 posts in 781 days
posted 673 days ago
Thanks for the review. I know one LJ who wrote several months ago who purchased the Grex and was not so pleased with the Grex. I recall the Grex was not driving the pins in properly. Some of the discussion suggested it may have had to do with the quality of the pins being used.
What brand pins have you been using?
Dalec
dennis mitchell
3789 posts in 1207 days
posted 673 days ago
That would be my gun. I’ve used it with short pins and love it. Pine to pine it would probably do the two inch pins. Building cabinets and counter tops it just does not cut it. Will not shoot into particle board very well. Knowing what I know I’d get the 1 3/8 inch model and forget about the longer pinned model.
StevePWL
posted 673 days ago
dalec, I use the Grex pins and haven’t had a problem so far.
dennis mitchell
posted 673 days ago
Those are grex pins in my gun also.
timmytimmy
12 posts in 638 days
posted 637 days ago
I just bought the Grex 645 this weekend and love it! Alot of money but as with moost tools, worth every penny. Feels very well made.
-- timmytimmy
DaveH
372 posts in 671 days
posted 611 days ago
I use an Air Locker pinner (about $50). The only problem I have with it is the nose safety gets in the way when shooting in tight spaces. Other than that, and the occasional pin that does not go where you want it (has a tendency to follow the grain alot) it’s worked just fine. If I purchased another, it would not have a nose safety. I would not bother trying to shoot pins longer that 1 3/16” unless the wood is extremely soft and straight grained.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
Ryan Shervill
238 posts in 705 days
posted 611 days ago
Dennis, what PSI are you running your gun at? Something doesn’t compute.
I’m in the middle of doing an extensive review for the one I won in the challenge…..Just got some more nails to test further, but I can say that my gun at 90 PSI will drive 2” nails into oak, 1” nails into cocobolo, and shorts into….and some people are going to cring at this….3/4” aluminum plate. Hey, I like to REALLY test the tools I review :)
Stay tuned for my full report in the next week or so, but I have to say I am extremely impressed with what this pinner will do :)
-- If you can't set a good example, at least serve as a horrible warning... www.rarewoodcreations.com
dennis mitchell
posted 611 days ago
I’ve run it as high as 110. After I quit trying to shoot on face frames or counter top edging I’m a little happier with it, but that is why I bought it. Has a tendancy to curl up between the alder and the particle board. Any sanding exposes the head. I love the way it feels. I would really like to try their staple gun. When I shoot 1/2 pins I grab it and leave my portacable in the trailer. I did have to replace the piston to get it to work, so I might just have one that was made on a friday.
JCAT
2 posts in 198 days
posted 198 days ago
Dennis and I have had conversation about his issues and we replaced a driver piston assembly for him. We also have found that increasing air pressure to 110 – 115 when fastening in harder woods improves driver life.
We want any who has any issue to please give us a “heads up,” for us to help resolve.
-- Jerry, So Cal
JCAT
2 posts in 198 days
posted 198 days ago
Oh…. one other suggestion… when using any tool with a chisal point, if possible, “cut” the grain….don’t “split” the grain….. the fastener will less likely travel out the side….. not 100% so don’t put your hand in the way.
-- Jerry, So Cal
16684 posts in 470 days
posted 198 days ago
I have had one since early o8 does a great job shoots nails up to 2” that you hardly see the nail hole.
cabinetmaster
8498 posts in 451 days
posted 198 days ago
We use one with the 2” pins for putting up molding and it works great. Even in the hardest of woods.
