The Ooga Japanese rip saw
Review by llwynog posted 744 days ago 4111 views 2 times favorited 21 comments Add to Favorites Watch
The Ooga Japanese rip saw The Ooga Japanese rip saw No-picture-s Click the pictures to enlarge them
Japanese handsaws are quite popular nowadays so I thought I’d introduce those who may not be familiar, to a saw which I was offered last year.
It is an ooga saw (?? in Japanese, pronounced Oh-ga, it means literally “big saw”)
This saw was designed to rip logs into planks and, just like the western pit saw, has seen its use being reduced to almost nothing during the 20th century. It was the tool of choice from the 15th century to about 1950.
The Ooga saw is large and heavy, really impressive in its size and drastically different from what I have always seen so far. Mine was bought on a flea market and sharpened and set by a specialized craftsman.
To give you an idea, the saw I received is of average size : about 80cm in length (31”), the blade itself is 50cm (20”) long by 32cm (13”) high. Its weight is about 3Kg (6.6lbs)
The blade is hand forged with the characteristic tapering of the blade (blade is thicker near the teeth than near the top edge – which reduces the need for a large set of the teeth). You can also see that the teeth increase in size along the blade making for an easier cut in the beginning.
I had to replace the handle as the handle that came with mine was completely rotten and falling to bits. I shaped mine out of ash which is not the kind of wood that would have been traditionally used but which is what I had. I tried to keep the same dimension and fastening method.
Now for the usage, I tried it against a peach tree lumber which was lying around at my parent’s house and I have to say I was impressed. It took only about 1 hour to saw through the 9” thick trunk and I can say in honesty that about 60% of that time was actually spent in trying to find a proper way to hold the lumber while sawing it.
What really impressed me was how straight the cut was. I am usually a poor sawyer and tend to drift easily but with this saw, although I started at an angle, the sawcut remained perfectly straight. You could put a straight edge on the resulting face and it looked as flat as you could dream. Also, the surface was extremely smooth (it actually appears rougher in the pictures than it felt in real life), much smoother than what most bandsaws produce when resawing such a thickness. It really felt like the saw was working on its own, I was “merely” there to move it back and force
Here is a picture I took from this website where you can see a really impressive trick : 2 sawyers are resawing a large log. They are sawing with 2 saws, one from each side and are synchronizing their actions so that they can saw a log which may even be wider than the blade of their tools (it forms an X pattern when viewed from above). You will notice that they are holding their saw horizontally, which is a position I tried also when sawing through the peach tree. Actually, I started sawing vertically and switched to sawing horizontally in the middle and yet the saw cut was perfectly flat, rather amazing. Also, you will notice that they are really making the most of their saw’s length : the sawyer on the left has but the very tip of the saw remaining in the kerf at its outmost stage of the movement.
I advise you to check at the above website, it is all in Japanese but the pictures themselves are interesting enough.
Oh yes, I am also told that with these saws, you sometimes spend more time sharpening and setting the teeth than doing the actual sawing itself. I have heard that a skilled user will tune the saw by changing the set of the teeth (and sometimes the sharpening angle) to match different species of trees.
OK, most of you will probably not be able to run and buy this kind of saw at your local home depot but I hope you enjoyed this review anyway.
Oh yes and I don’t own a bandsaw nor a chainsaw so guess how I am going to rip that cherry tree at my brother’s house this summer…
-- Fabrice - "On est bien bête mais on sent bien quand on se fait mal" - my grandfather
View llwynog's profile
llwynog
231 posts in 749 days
21 comments so far
View WayneC's profile
WayneC
9596 posts in 2267 days
#1 posted 744 days ago
Thanks for posting this. Blake found a similar saw here in the US a while back. Here is his blog post. You may find it interesting.
http://lumberjocks.com/Blake/blog/8804
llwynog
#2 posted 744 days ago
Thanks for the link Wayne, I did not know there was already a post about it.
View Sodabowski's profile
Sodabowski
1812 posts in 1003 days
#3 posted 744 days ago
O_O !!!
-- Thomas - There is no such thing as a problem, there only are solutions.
llwynog
#4 posted 744 days ago
It looks like the Japanese characters in the name went down the drain. Funnily enough, they were displaying properly when I hit the preview button.
View b2rtch's profile
b2rtch
2955 posts in 1218 days
#5 posted 744 days ago
Very interesting, thank you.
Bert
-- Bert
View Bertha's profile
Bertha
13111 posts in 863 days
#6 posted 744 days ago
Supercool saw!
WayneC
#7 posted 744 days ago
I think you and Blake will have some common interests. He is a great guy. Hopefully he will wake up and post. : ^)
View woodklutz's profile
woodklutz
198 posts in 938 days
#8 posted 744 days ago
Wonderful blog. Thanks for teaching us about something so exotic.
-- honing my craft one mistake at a time.
View BTKS's profile
BTKS
1919 posts in 1634 days
#9 posted 744 days ago
Thanks for the review and link. Cool pics and some real skill involved. This type of ripping will make you get the most out of every piece of wood.
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View ward63's profile
ward63
167 posts in 1257 days
#10 posted 743 days ago
What a cool find!!! I’ve seen these around at mom & pop tool shops but have never been able to afford one.
I have a large ryoba that gets a lot of use and cuts really fast.
Great job on the handle too. I think ash is an excellent wood to use.
View Blake's profile
Blake
3421 posts in 2044 days
#11 posted 741 days ago
Good morning Wayne.
Nice saw and some interesting additional information from what I was able to gather. I love my saw but I’m content to let it hang on my wall. Bravo for actually using yours.
I like that ink block painting of the Japanese sawyer. Where did you find it?
-- Happy woodworking! http://www.blakeweber.us
llwynog
#12 posted 741 days ago
Hi Blake,
The woodblock print in the beginning is from the most famous ukiyo-e artist Hokusai (you know the famous prints with the mount Fuji you see everywhere, just search for ukiyo-e in google and your have 99% of chances that the first image that comes back is a print from Hokusai).
If you search for “大鋸” in google images, you will find several variations of this particular print. (it seems LJ forums do not use unicode for character encoding so I am afraid that the Japanese characters will be turned into question marks once again.)
llwynog
#13 posted 741 days ago
I stand corrected.
For some reason the Japanese characters got mangled in my post but are left intact in the comment. So you can just copy/paste this into your google images.
Bertha
#14 posted 741 days ago
Now I’ve got these saws on the brain. This will likely not go away until I purchase one. I really appreciate you posting this interesting saw and especially the glimpse of lore behind it.
llwynog
#15 posted 741 days ago
He he, I know how you feel, do you want me to talk to you about the yariganna (槍鉋), Japanese ancestor to the handplane (actually, I find it is a somewhat distant cousin to the drawknife). Although I am pretty sure I have no use for one, I can’t take it out of my mind since first read about it… I know that someday, on a flea market…
Here is a picture of some of them if you dare :
http://www2.odn.ne.jp/mandaraya/2b-yari.htm
You can see a craftsman using one further down the page.
