| Review by plantek | posted 756 days ago | 3679 views | 0 times favorited | 8 comments | ![]() |
- JessEm Router Lift II
- Brand: JessEm | Category: Router Accessories
I had been shopping around for a router lift for some time now and would drop when seeing the prices. Then I came across this: http://www.jessem.com/Router_Lift_II.html . I’ve had it for a couple months now and have been able to give a good once over. It is my first and only router lift I have ever used so I cannot compare it to another (hence the 4 stars). But I can say it is fantastic. It has changed my whole table router world for the better.
Being in the metal fab business for the length of time that I was, I can say this is very well made and sturdy.
They have a few different models available. The model I bought starts at half the cost of the other brands I was seeing.
If your looking for a lift this is well worth the consideration…
-- If you want it and it's within reason... It's on it's way!
8 comments so far
BilltheDiver
home | projects | blog
170 posts in 1058 days
#1 posted 755 days ago
I agree! I mounted mine in my tablesaw wing and it has entirely changed my router table work. I can work more accurately and setup much more quickly and easily. It really makes the router table more versatile.
-- "Measure twice, cut once, count fingers"
Billp
716 posts in 2372 days
#2 posted 754 days ago
I just put mine in yesterday, it works great and for around $150.00 you can’t beat it. I just installed a Incra LS Positioner a couple of weeks ago. The combination of the two really makes you feel like finally you have control.
-- Billp
Ritty
63 posts in 969 days
#3 posted 754 days ago
i have a porter cable 691 its only a 13/4 hosre do u think it woulfd work with that type of router? ive also been looking for one and this would be great and thx for the post
plantek
276 posts in 971 days
#4 posted 754 days ago
Ritty,
I have a Porter Cable 690 in mine and it works great!!!
richgreer
4474 posts in 1247 days
#5 posted 753 days ago
I’m one of those who didn’t think he would ever want or need a router lift – - until I bought one. It gives you such precise control. Raising or lowering the bit 1/1000” or less is doable and that is just what you need sometimes. Like Billp I use it with the Incra LS positioning system for the ultimate in precise control.
I can’t speak about the JessEm since I own a Woodpecker. However, I write to endorse the general concept of using a router lift.
reggiek
2238 posts in 1442 days
#6 posted 753 days ago
I have 2 router tables….one I built and one that is a TS extension. I have this lift on my shop built table – it is an offset Incra table with the Incra LS router positioner and jig fence (great tool by the way – there are several reviews of the system on LJ’s – so I won’t go any deeper into it).
The TS extension table is from MLCS and will have a motor lift as soon as they ship me one – around May 17th (I was one of the first that went on backorder for the motor lifts). I have some friends that already have the motor lifts and they are really jazzed….they make great mortisers and are really easy to do stopped profiles and Dados on the router.
The only complaint I have against this Jessem lift is that the tool for removing the insert plates….the Y shaped tool….is a micron too wide and you have to wiggle and jack around to get it into the holes for mounting the plates…..this is a minor irritation but one nonetheless.
Ritty
#7 posted 752 days ago
ok thx plantek i thought that maybe the size of the moter were different
TheHarr
102 posts in 1711 days
#8 posted 367 days ago
I picked up the same router lift over 2 years ago and finally made my router table. I like everything about it, especially the price. Here is a link to my blog showing the construction of the router table (part 1) and the adjustable fence (part 2).
http://lumberjocks.com/TheHarr/blog/30088
http://lumberjocks.com/TheHarr/blog/30099
-- The wood is good.
