RAPIDAIR Compressed Air Piping System
Review by redryder posted 04-29-2011 07:54 AM 11148 views 5 times favorited 9 comments Add to Favorites Watch
RAPIDAIR Compressed Air Piping System RAPIDAIR Compressed Air Piping System No-picture-s Click the pictures to enlarge them
If you like compressed air plumbed into your shop, this might be for you. I saw the Rapidair compressed air piping system advertised in Woodcraft as a new product and thought it sounded interesting. I like and need to use compressed air in my woodshop for nail guns, air tools and cleaning. I have been working on a remodel and expansion to my shop and I was going to put in compressed air anyway so I thought I would give this a try. The Woodcraft price I paid was $139.99. You receive 100 feet of tubing and all the parts you need to install compressed air in your shop. I would highly recommend this setup to anyone who wants compressed air in thier shop. The real selling point for me was the ease and flexibility of the install. You can mount this in the walls liike electrical wire thru the studs as I did during my expansion or on the outside walls in a completed shop. The best part of this is you can have the air outlets EXACTLY where you want them. I looked at iron pipe with threaded ends and concluded that I could have the air roughly where I wanted them (exposed) or with this system I could have them exactly where I needed the air supply. I wanted the air to drop down above my table saw, at my miter saw and at the work benches. The connectors are all push fit. The plastic tubing is 150psi max and cuts like butter at whatever length you need. I was able to go into the overhead crawl space and drop the ceiling mounts exactly where I wanted them. There are no visible pipes to be seen. If your shop is finished and you can not get inside the walls, you can still run the tubing where you want it. The company provides everything you need including mounting clamps. All of the manifolds are aluminum. They allow you to have surface mount, ceiling mount or hidden mount. I needed a connector for my 30 gallon compressor that I wanted mounted in another room for sound supression and had to call thier customer support number. They were very courteous and helpful and sent the parts I needed right away. I like this because it is out of sight and exactly where I want it. I think you will too. Oh ya, I just found the same set up in the Northern Tool catalog for $99.99. Bad for me, good for you…........
-- mike...............
View redryder's profile
redryder
2393 posts in 3217 days
9 comments so far
View Chris 's profile
Chris
1879 posts in 4106 days
#1 posted 04-29-2011 07:01 PM
i too was wondering about this product. thanks for the review!
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View Bertha's profile
Bertha
13550 posts in 2808 days
#2 posted 04-29-2011 07:04 PM
I wish I had known about this before I put up my walls! I spent almost that much on a hose reel :(
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
601 posts in 3023 days
#3 posted 04-29-2011 07:38 PM
My son recently moved his motorcycle shop into a new building. I sent him this Review. This is what his response was:
“I talked to a few guys using that system for lower volume stuff with shorter runs and they are pretty happy. If you’re running stuff such as impact wrenches off of longer runs like 50’ then you really need the big pipe to keep the air moving. Remember that the further the distance the tool is from the air source the larger the hose/pipe needs to be. My longest run is around 100’ including the air hose from the compressor with lots of corners and sharp turns.”
Just a FYI
View rance's profile
rance
4261 posts in 3276 days
#4 posted 04-29-2011 07:51 PM
I think you could stick with the smaller hoses on long runs, but add a small propane-size tank on the far end as a pick-me-up.
redryder
#5 posted 04-30-2011 08:17 AM
A couple of shots that may help you….....
redryder
#6 posted 04-30-2011 08:18 AM
Another couple of shots that may help you decide if this is right for you….....
View bigike's profile
bigike
4054 posts in 3404 days
#7 posted 05-01-2011 12:44 AM
After reading your review I want one you can get them on ebay or a similar one anyway. THANKS for the review!
View Grandpa's profile
Grandpa
3261 posts in 2791 days
#8 posted 05-01-2011 05:39 AM
has anyone ever used PEX tubing? I have read that the compressor oil makes PVC brittle and you should use it but I have a friend that has used PVC on a 180 psi system for 20 or more years with no failures. Still bothers me. What about PEX?
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3298 days
#9 posted 05-01-2011 05:55 PM
Looks to be a good system. Rockler has the same system and add on kits 1/3 cheaper than woodcraft.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
