So much more than a "laminate trimmer on steriods".
Review by Gord Graff posted 04-23-2011 07:55 PM 15268 views 8 times favorited 31 comments Add to Favorites Watch
So much more than a "laminate trimmer on steriods". So much more than a "laminate trimmer on steriods". So much more than a "laminate trimmer on steriods". Click the pictures to enlarge them
Hi All.
If you’re in the market for a compact router kit that’s loaded with features, you owe it to yourself to check out DeWalt's new DWP611PK.
This compact router kit easily exceeded my expectations for a compact router kit of this size and price range, read on and find out why.
The Motor:
The 7amp, 1 1/4HP soft-start variable speed motor delivers plenty of power for a myriad of routing tasks and the full-time electronic feedback maintains motor speed throughout every cut I’ve made with this router. And speaking of motor speeds; this router’s variable speeds, range from 16,000rpm to 27,000rpm and are easily adjusted by turning the speed dial conveniently located right above the on/off switch. The clear rubber protected on/off switch was a little difficult to use in the beginning because it is shielded in the motor housing but the benefits of not inadvertently turning the router on when handling it or the fact that dust and debris will not enter the electronics through this area are benefits that I can appreciate. The aluminium body is well machined and the electronics are housed in DeWalt’s tough ABS plastic.
The dual LED lights located on either side of the router’s spindle do an excellent job of illuminating the area being routed. Along with the clear polycarbonate sub base, visibility was greatly enhanced when I was using this router for inlay work, edge work and cutting mortises. The LEDs are an idea that is long overdue and very much appreciated when using this router, they are a feature that is definitely here to stay.
The large, low pressure spindle lock button is easy to engage, making single wrench bit changes an easy task. There are 12 shaft lock detents on the spindle making for faster spindle lock ups and quicker bit changes. The extended 1/4” collet is a full 7/8” long and has a total of 8 slots cut into it maximizing surface contact with the router bit shank providing a tighter grip on the bit and less vibration in use.
The Fixed Base:
Installing the motor into the fixed base is a simple matter of aligning one of the two slots that are cut into the motor housing with the registration pins found on the inside surface of the fixed base and sliding the motor into the base. Engaging the large black depth adjustment ring with a resounding “snap” and clamping down the motor locking lever rounds out the installation. A completely tool-less operation which takes mere seconds. Removing the motor from the fixed base is equally as easy. Unlock the locking lever, squeeze the spring loaded release tabs on the depth adjustment ring and the motor slides effortlessly out of the fixed base.
The fixed base allows up to 1 1/2” of depth travel using the large adjustment ring and coupled with the yellow fine adjustment ring, facilitating depth changes to within 1/64”, it’s easy to quickly “dial in” and fine tune depth adjustments. The fixed base has a raised textured surface machined into it which provides a positive, slip-free grip on the router’s body. A real nice safety feature when working in a dusty environment. I found the fixed base to be very stable in use with its extended (4”x4 3/4”) clear polycarbonate base which provides greater work surface contact for improved stability and control. The bit opening in the sub base is 1 7/16”, which is large enough to handle the router bits used with this router.
The Plunge Base:
Installing the motor in the plunge base requires the removal of the depth adjustment ring on the motor, lining up the registration pins located on the inside surface of the plunge base with the slot in the motor body and sliding the motor into the base. The motor bottoms out with a resounding “thud” and you’re there. Actually, there is a small lip in the plunge base that the motor bottoms out on that creates that thud. Lock the locking lever on the back of the plunge base and you’re ready to route.
The footprint of the plunge base is a large 4 3/8”x5 3/4” which provides stability when performing various routing operations and the sub base has been made to accept universal (1 3/16”) template guides, commonly referred to as Porter Cable style template guides.
The plunge base travels very smoothly and effortlessly through its 2” of plunge travel on firm but not, stiff springs. The large, easy to locate plunge lock lever operates well and doesn’t require much hand movement off of the router’s handle to engage or release it. The plunge lock lever is exactly where it should be and locks the router firmly in place when engaged. Although this router doesn’t come with adjustable handles, I never found myself wanting to change their position. The placement of these handles make it easy to manipulate the router and the moulded rubber handles provide a comfortable and secure grip even when my hands are covered in sawdust.
Another nice feature of this router is that the base has been designed with two flat sides instead of a completely round base or a single flat sided base. I can use either flat side of this router base to ride up against a straight edge when the need calls for it. It’s one of those features you don’t realize you need until the day that you need it.
Plunge depths are controlled by a 5 position rotating turret stop (4 fixed & 1 adjustable) and there is a 2” depth scale that features 1/32” increments located at the top of the plunge base housing for referencing plunging operations. There is also a micro adjustment feature on the plunge adjustment rod located at the bottom of the adjustment rod nearest the turret stop. The bottom knurled portion of this rod can be turned clockwise or counter clockwise to “dial in” that very precise adjustment frequently needed.
The Final Word:
The DeWalt DWP611PK was once described to me by a fellow woodworker and friend as being “nothing more than a laminate trimmer on steroids”, he has since changed his opinion of this router after he borrowed mine for the weekend. This feature packed router is the only router I now reach for when doing light to medium duty work. It’s a powerful, versatile and user friendly router that has exceeded my expectations of a compact router kit the first day I used it and it continues to impress me every time I use it.
Specifications
Amps 7.0Amps
HP 1.25HP
No Load Speed 16,000 – 27,000rpm
Collet Diameter 1/4”
Plunge Stroke 2”
Depth Stop 5
Base Dimension 4” (standard),4 3/8” x 5 3/4” (plunge)”
Spindle Lock 12 Position
Tool Weight 4.1 (fixed) , 6.2 (plunge)lbs
Street Price $200.00
3 Year Limited Warranty
-- Informing & Inspiring Today’s Woodworkers: http://www.gordgraff.com
View Gord Graff's profile
Gord Graff
140 posts in 3890 days
31 comments so far
View GuyK's profile
GuyK
356 posts in 4075 days
#1 posted 04-23-2011 10:34 PM
Great review. I have been looking at this for the farm shop, this video seals the deal. thanks
-- Guy Kroll www.thelandsathillsidefarms.org
Gord Graff
#2 posted 04-23-2011 10:50 PM
Hello Guy,
Let me know if you have any questions, I’ll help you out the best I can.
All the best
Gord
View GuyK's profile
GuyK
#3 posted 04-23-2011 11:25 PM
Thank you Gord, when I get it I will let you know. Also will let you know my thoughts on it. Everything I have read and seen so far, it looks like a winner to me.
View sandhill's profile
sandhill
2128 posts in 3919 days
#4 posted 04-23-2011 11:34 PM
Good review Gord. I have a ridgid R2401 which I thought was very nice but I like the bells and whistles Dewalt put on this one. Got to have it. Thanks
3809 posts in 4017 days
#5 posted 04-24-2011 12:34 AM
Gord is it available in Canada?
Last time I checked it was not going to be imported here. Buying it would complicate a warranty.
I was kind of bummed out with Dewalt for this decision.
I guess with the shrinking economy in the US the Canadian dollar is looking pretty pretty pretty good to them now.
Gord Graff
#6 posted 04-24-2011 12:43 AM
Hi Bob,
Yes, it’s available in Canada.
I just checked the DeWalt site and they list a bunch of stores in my neck of the woods that carry them.
Try checking here.
All the best
Gord
#7 posted 04-24-2011 01:30 AM
Thanks Gord. I tried that before I POSTED AND ONLY GOT A NUMBER OF US VENDORS.
They generally try to ship UPS and that entails addtional Brokerage and shipping costs.
The warrantee is toast if you have a problem.
There is no way I will pay a premium to deal with Dewalt. I want the same deal as all their other customers.
Somehow, they just don’t get it.
View Moron's profile
Moron
5032 posts in 3889 days
#8 posted 04-24-2011 02:04 AM
cool, but I needed sun glasses to keep the reflection from yer head, outta my eyes.
Great review
View john's profile
john
2370 posts in 4377 days
#9 posted 04-24-2011 02:26 AM
I,m impressed ! Now i want one !
Gord do you know the price range for this router roughly ?
-- John in Belgrave (Website) http://www.extremebirdhouse.com , https://www.facebook.com/groups/extremebirdhouses/
View bigike's profile
bigike
4052 posts in 3284 days
#10 posted 04-24-2011 03:06 AM
great review!
View thiel's profile
thiel
387 posts in 3288 days
#11 posted 04-24-2011 07:06 AM
Great review. I have this router and I agree that it’s super. So versatile and easy to use. A really nice size in your hands, with enough oomph to do quite a lot. I’d even recommend it as a “first router” for people just starting out… .
-- Laziness minus Apathy equals Efficiency
Gord Graff
#12 posted 04-24-2011 02:04 PM
Hi All,
Thanks for your kind words, glad you liked the review.
As far as my shiny head is concerned…................... I don’t like wearing hats so I suppose I could rub my head with sawdust to keep the reflection down. :) :) :)
Street price of this kit is around $200.00 Canadian and as for availability, I’ll check into that.
And theil you’re absolutely right, it would make a great “first router”.
All the best
Gord
27250 posts in 3817 days
#13 posted 04-24-2011 02:14 PM
Gord, this a a well produced video (as always I might add) that covered the router pretty well. I have been considering getting a laminate trimmer and have always been a DeWalt fan. This one looks like a tool that I might have to add to my tool collection.
View Yupa4242's profile
Yupa4242
116 posts in 2596 days
#14 posted 04-24-2011 03:19 PM
Thank you for the review It helped me feel a tad better about my recent router order of the DW618PK Kit I ordered 2 weeks back. I would like to hope the 618 has many if not all the same features. I however am disgusted to find out all orderers for the 618 have been backorderd until late June. None of the big box stores or lumberyard stock these kits except around Christmas. I originally saw my 618 in Fine Woodworkings Tool 2010 Guide and was convienced the DeWalt product is a solid product as I already own some cordless units that like you said resist breaks from the impact plastic housings.
-- "If the Universe is Infinite, Then all dreams are real."
View Tedstor's profile
Tedstor
1643 posts in 2628 days
#15 posted 04-24-2011 03:22 PM
Gord,
Thanks for taking the time to write a great review. I put a lot of stock into this type of info before spending my hard earned money.
Questions: Would you say this type of router completely takes the place of a laminate trimmer (and posseses the ability to do a whole lot more)? I’m pretty close to pulling the trigger on a laminate trimmer, but might hold out for a compact router instead. Any reason to have both??
I already have a fixed and plunge router. In your opinion, would I be better off supplementing them with a $90 laminate trimmer? Or is the Dewalt revolutionary enough to warrant the extra $100? I’m definitely tempted to buy the compact router after this review.
Sorry if these questions were answered in the video. I have no speakers. LOL
showing 1 through 15 of 31 comments
