The squares I got were half accurate
Review by RandyMorter posted 781 days ago 1866 views 0 times favorited 8 comments Add to Favorites Watch
The squares I got were half accurate No-picture-s No-picture-s Click the pictures to enlarge them
I ordered these from Hartville Tool through Amazon. I thought the price and specs looked good and I wanted them for setting up my table and other saws. I was also drawn to them due to the wood box.
When I got them I held them up to each other to test them. The outsides of the blades all seem true – I couldn’t see any light between the blades of different squares. When I placed one square inside another to test the squareness and insides of the blades I could see varying degrees of light between the blades. One of the insides didn’t appear to be square to the inside of the blade. The others just didn’t appear to be true edges.
I had purchased a brand new Starrett C33H-12-4R at the same time and using it I seemed to verify the results. The Starrett showed the outside edges were square and true but the insides had issues.
So, I think the squares are half okay, resulting in the 3 stars.
Also, the box is nothing to be proud of but for the price it’s okay. It’s just not as good as some of the other things I have (Wood River forstner or MLCS router bit boxes for example).
As for Hartville Tool, they are great, willing to take the merchandise back without any issue and will reimburse shipping if they feel the product is defective. Can’t argue with that. I’m still debating on whether to bother since these WILL work for setting up blades and the different sizes are nice.
-- Randy Morter, Phoenix, AZ
View RandyMorter's profile
RandyMorter
226 posts in 859 days
8 comments so far
View Bertha's profile
Bertha
13111 posts in 862 days
#1 posted 781 days ago
Starrett wins again. I have a hard time sending tools back, even if they’re defective. It just feels like I’m losing tools!
View MrRon's profile
MrRon
1578 posts in 1412 days
#2 posted 781 days ago
I’m not 100% certain, but I believe engineering squares only have to be square on the outside.
View ratchet's profile
ratchet
1190 posts in 1955 days
#3 posted 781 days ago
Agreed, they are designed to be true on the outside only. But that said, it would be nice to have the inside correct as well. I wonder if you could file the insides true. Thanks for the review.
View DraftsmanRick's profile
DraftsmanRick
112 posts in 1229 days
#4 posted 781 days ago
Randy, I’ve got a couple of engineering squares i ordered from a mail order mag and they weren’t all that great either. I cant remember the name of them right now (maybe Zog) but it started with a “Z” i believe? They are also NOT square on either inside or out. Ron/Ratchet i didnt know that. You would think a square would be “square” on both sides.
Randy,
You can also check with this method to see if its square in case you dont know. Place the square on a straight edge of work, draw a perpendicular line, and then flip the square over and check it. If it lines up when the square is flipped, its square. Thats the easyist way to do it. I would send them back if you haven’t already. I know most everyone is feeling this econemy but personally i dont like spending my hard earned money on crap tools that dont perform. As Pat Warner the router guru says when it comes to layout tools: Close work, is guess work.
Thanks for your post and sharing with us.
-- Jesus was a carpenter
View Dusty56's profile
Dusty56
10513 posts in 1857 days
#5 posted 781 days ago
Does it say anywhere in their {Hartville Tool} sales ad / literature that the squares are only square on one side ?
Shouldn’t their salespeople let us know before we purchase them ?
They have the final say if the squares are defective or not ???
That doesn’t sound like “great customer service” to me : (
My Engineer squares from WoodCraft {GROZ} are square inside and out and came in a nice box as well : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
Dusty56
#6 posted 781 days ago
Two Possible April Fools comments above ? LOL
http://www.aloktools.com/precision_steelsquare.php
I couldn’t find anywhere online that states the Engineers squares are only square on the outside , but rather square and parallel inside and out was mentioned.
http://www.amazon.com/Piece-Engineers-Square-Set-Case/dp/B003A08PTU
RandyMorter
#7 posted 780 days ago
Thanks guys…
I’ve been trying to use them for a day before deciding whether to send them back.
This link is to the actual set I ordered. They say they’re parallel as well so I expected the inside to be square.
DraftsmanRick – Thanks for the instructions – I knew about that but I just measured them with my Starrett and saw a flaw that way so didn’t bother with the line test. On one of the insides it looks like it could be filed because there appears to be just a raised or thicker part near the handle. But I don’t want to file them – if I had a milling machine I might try it but I don’t trust my filing.
To be honest, they actually fit my needs nicely for setting up blades. I’ve been able to set up my table saw and I’ve checked and found my band saw isn’t square (I’d set it with my little Empire 6”). I’m still debating on them – Hartville has a Incra 5” square that looks nice and I’ve discussed exchanging this set for that but then I have just the one size. Those Groz squares pointed out by Dusty56 may actually be the ticket. But again, I don’t think I’ll actually be using the insides.
View lashing's profile
lashing
106 posts in 990 days
#8 posted 192 days ago
The reason this is so prevelant is most people have no real square reference not do actual work. Its like exercise machines at Walmart. They fall apart if you use them but they know the people buying them will simply never actually use them.
They can made perfectly accurate stuff in China and for less than an American product. They do have all the tooling and skill. They choose not to as they would rather sell 100000 squares and get 1000 back then sell 1000 actually good ones at a higher price point. I should rephrase that – the reailer actually takes the lost as China takes nothing back. The retailers simply work the projected returns into price. It all could stop if they simply refused to sell trash or people stopped buying it.
