Porter Cable Dovetail Jig is Sturdy and Easy to Adjust.
Review by pintodeluxe posted 03-31-2011 03:00 AM 4628 views 3 times favorited 11 comments Add to Favorites Watch
Porter Cable Dovetail Jig is Sturdy and Easy to Adjust. No-picture-s No-picture-s Click the pictures to enlarge them
The 4210 dovetail jig is easy to use, and the template is thick aluminum. Most other jigs in the $100 price range seem flimsy or use plastic templates. I was impressed how large and heavy this jig is.
The included dovetail jig and bushing let you get right to work – no more trips to the specialty woodworking stores. The bit is carbide tipped, and very sharp. It is 1/2” shank and cuts effortlessly.
I found the jig in stock at Lowes.
By by 4th try I was cutting perfect dovetails. I only wasted about 6” of lumber before the joints looked good. There are fancier jigs out there, but this one is a really nice jig.
The only limitation with fixed-spacing templates is you need to build drawers at specific width for the best looking drawers. For perfect half-sockets, just build your drawers at 1” increments plus 1/4” ( ie: 3-1/4”, 4-1/4”, 5-1/4” etc. ). I am building custom furniture, so this was easy to design the drawer openings to fit these sizes.
Addendum: Every time I pull this jig out, I am amazed how easy and repeatable dovetails are. Half-blind dovetails are genius- one bit, one setup, one pass and you are done.
2nd Addendum: I have also used this jig with a larger 14 degree Rockler bit which produces better looking dovetails… http://lumberjocks.com/topics/40073
View pintodeluxe's profile
pintodeluxe
5816 posts in 3051 days
11 comments so far
View Chris Moellering's profile
Chris Moellering
227 posts in 2886 days
#1 posted 03-31-2011 02:31 PM
Looks like fun. Having just got a PC router for my birthday this year, I’d love to get one of these to go with it….
hmmm…Father’s Day is coming up…. ;-)
-- Grace & peace, Chris+
View Ken90712's profile
Ken90712
17614 posts in 3426 days
#2 posted 03-31-2011 03:16 PM
Nice review, One thing I don’t have that I have kicked around buying….. Thx
View TheOldTimer's profile
TheOldTimer
226 posts in 3323 days
#3 posted 03-31-2011 07:04 PM
I have the 4212 which comes with additional templates for thru dovetails and box joints. It also comes with all the bushings and bits. I really like my jig and for the money, it is well worth it. Took about two trys with initial set-up before I was cutting perfect dovetails. Just finished a seven drawer dresser and all the joints are perfect. When using baltic birch for the drawer case, I score the plywood with a utility knife before cutting thus avoiding any chip out in the plywood.
-- TheOldTimer,Chandler Arizona
TheOldTimer
#4 posted 04-01-2011 01:02 AM
Sorry guys: It is the 4216 that has all the attachments and templates. I guess I had a senior moment!!
View Branum's profile
Branum
54 posts in 3405 days
#5 posted 04-01-2011 01:04 AM
I too have the 4212. The reason I bought the PC jig vs the other brands is that I saw a video from PC that showed how to use just the template and some wood as spacers to be able to make infinite length dove tails (not limited to 12”). For the life of me I can’t find it now but I know it is out there.
Hey Oldey,
Can you explain the scoring with a utility knife a little more for me? I will be building many drawers this summer.
-- Branum
Branum
#6 posted 04-01-2011 01:07 AM
For any one thinking about using this jig, having 2 routers makes your life so much easier. You set one for your pins and one for your tails. This will shorten the time it takes to cut your pins and tails by 50-75%!!
-- Branum
View bvdon's profile
bvdon
502 posts in 3252 days
#7 posted 04-01-2011 04:41 AM
Branum… I think once you cut one board, you can then use that board as a template to score the other boards. That would be my guess ;)
View FrankyFiveAces's profile
FrankyFiveAces
13 posts in 2624 days
#8 posted 11-15-2011 01:49 AM
Looking into buying a new dovetail jig and the PC is at the top of the list. I have a 1/2” and 1/4” Craftsman routers, do I need to worry about bushing? Thanks.
-- "Never give a sucker an even break." -W.C. Fields
pintodeluxe
#9 posted 11-15-2011 02:17 AM
Franky-
You need a router that accepts a standard Porter Cable style bushing. I believe it is a 1-3/16” opening in the router. Any P.C. or Dewalt router should work. I am not sure what size opening your router has. It seems like Craftsman and Bosch use non-standard bushings, however there are often adapters available from the tool manufacturer.
Best of Luck
FrankyFiveAces
#10 posted 11-24-2011 05:18 PM
Apparently my Craftsman came with a PC style base, which will accept any type of PC bushings. Good to know. Thanks for the heads up, Pinto.
