| Review by mot | posted 682 days ago | 2582 views | 0 times favorited | 15 comments | ![]() |
- Incra Miter Express / Miter 1000SE
- Brand: Incra | Category: Tablesaw Accessories
I wanted to add to the mitre gauge posts. Wayne posted a photo tour of the Jessem System, and David posted initial impressions of the Kreg System.
The incra 1000SE is seen here in the Incra Miter Express sled. Both are available at Woodpeck.com You can see the kerf where the mitre sled straddles the blade in the tablesaw allowing for the cutoff piece to be coplanar with the workpiece. This decreases the chance of the saw flinging the cutoff piece back.
The Incra guage is adjutable in half degree incriments with detents every 5 degrees from +90 to -90 degrees.
The mitre bar is extendable for longer cross cutting applications by loosening a set screw and extending the bar.
The stop block is microajustable with both gross movement, and ultra fine movement for repeated cuts.
The mitre gauge easily moves to +/- 90 degrees and is stabilized in the sled with two set screws. These are not necessary but they are a nice addition. The mitre gauge moves forward or back in the sled in order to always be able to support the workpiece.
The sled has a hold down that slides along it’s entire width for stock of varying widths and thicknesses.
Here is a video of the operation of the sled:
What else is there to say. It’s a miter gauge, deathly accurate, very easy to use, convenient and I give it a “Great Purchase!” rating.
Cheers!
15 comments so far
home | projects | blog
3710 posts in 875 days
posted 682 days ago
Hi Tom;
Great product review here.
The product itself looks very well engineered.
But then, what else could we expect from Incra? (or you for that matter).
Thanks for taking the time to post this, I’m sure a lot of us will find it very helpful.
GaryK
9533 posts in 884 days
posted 682 days ago
Nice review! Sounds like you are very happy with it. I have a 3000 miter gauge and love it.
14159 posts in 1056 days
posted 681 days ago
nice review!!
Thos. Angle
4013 posts in 858 days
posted 680 days ago
Got one, like it a lot
-- Thos. Angle
mjpierson
77 posts in 889 days
posted 676 days ago
I have one and love it. Bought the whole get-up last year’s woodworkers show from Incra to replacethe standard issue Delta guage.. First project after I bought was a small piece that required very accurate angles (to avoid obvious gaps)....after using the Incra on that project…I was a fan forever.
-- Mike - Columbus, Ohio
cajunpen
5968 posts in 962 days
posted 675 days ago
Got the same set up Tom and it would be hard to find something that worked any better. It cuts any angle you want – dead on.
rikkor
11335 posts in 770 days
posted 675 days ago
Good video. I looked at one at a woodworking show, but I’d already topped my $ allotment for the day.
Bill
2561 posts in 1057 days
posted 675 days ago
Great job on the video Tom. It makes me want to take a look at this miter gauge for my work.
lynxsg
8 posts in 675 days
posted 674 days ago
Incra sells a combo … the 1000se miter guage, and the Incra Miter Express together at a better price.
I have just set mine up recently and agree that the cuts are very accurate. However, the ‘rulers’ they provide for length measurement are poor.
Many of us like to use the miter guage on the left. If you have a left tilt table saw, you will have to use the guage in the right hand slot (if using the fence). Why? Because the sled is set up to hold your miter gauge on the right side if you have a left tilt saw.
You can reassemble the fence on your 1000se for use on the left of the blade (without sled), but this takes time, is a nuisance, and the scale has to be set up again.
The sled and Incra miter guage works better for right tilt table saws for the reasons I’ve sighted. For a right tilt table saw, there is no need to disassemble and setup the miter guage for use in the left slot.
—Steve G.
-- Steve G., Kelowna, BC, Canada
Vagabondking
4 posts in 209 days
posted 197 days ago
Good review, I have the 1000se, now save the money for the express.
John
16910 posts in 473 days
posted 197 days ago
cool
JKC
4 posts in 123 days
posted 1 day ago
Hi, I’m interested in seeing the video. It seems to have been removed. Any possibility of emailing it?
mot
4903 posts in 932 days
posted 1 day ago
I’ll try and repost it. These videos were all hosted on Jumpcut which was bought by Yahoo and subsequently taken offline. I do have the initial raw video so I’ll try and update all the blog videos here.
Thanks for reading the blog!
WayneC
6012 posts in 993 days
posted 1 day ago
Rockler has the 1000 HD on sale from Nov 27 till Dec 4 for $99.99 USD. The regular price is $189.99.
JKC
4 posts in 123 days
posted 1 day ago
Thanks Mot, much appreciated!
