| Review by kansas | posted 799 days ago | 2299 views | 1 time favorited | 6 comments | ![]() |
- Ridgid 16 Gallon ProVac Model WD 1851
- Brand: Ridgid | Category: Dust Collection
I just purchased this Ridgid 16 gallon Wet/Dry Vac. The model is a WD 1851 and I got it at Home Depot for $160. I’m upgrading (I hope) from an older ShopVac I had that’s at death’s door. This machine seems very nice so far. Nice power cord length and cord seems to stay cool when running. The switch is right up front and very easy to operate. The included hose and accessories aren’t bad either. The motor is rated for 12 amps but you won’t find that on the packaging anywhere. They try to sell you that it makes 6.5 HP. That is just marketing bs but anyway, the power seems decent. It also acts as a blower by switching the hose to the outlet port. This feature seems like it may be as valuable as the vacuum for cleaning up the shop. My old vac didn’t do that so I didn’t know what I was missing. It rolls on the floor well. I also purchased the orange upgraded hose. It’s 3 feet longer and I’d hoped it would be less stiff. It is also smaller diameter than the hose that comes with the vac. After seeing the larger diameter included hose I’m not sure the “upgraded hose” was worth the $36 bucks. The adapters were all included but they are just that—adapters and I put the wrong ones on the first time—not realizing these things are not intended to come back off. If you buy the orange hose, be sure the adapters are correct before you push them on! The last thing I’ll note is the quiet operation. This thing seems to be extremely quiet compared to others I’ve used.
6 comments so far
richgreer
home | projects | blog
4474 posts in 1239 days
#1 posted 798 days ago
Thank you for the review. Of course the 6.5 hp is bs. I wish manufacturers would stop doing that. Amp draw is your best measure of power.
For me, the last comment was the most interesting. I have yet to see a shop vac that was acceptably quiet. I may have to check this out.
Mike67
60 posts in 1501 days
#2 posted 798 days ago
I have once size down – its a great vac. The upgraded hose is really nice for hooking up to sanders and other hand-held tools. The bigger black hose is nice for general clean up. If you want a quieter vac you probably need to get into something like a Fein.
dbhost
4748 posts in 1397 days
#3 posted 798 days ago
I have the 12 gallon model and love it except for one issue, that makes me REALLY want the 16 gallon model, and that is the ability to use collection bags. I sometimes use my vac without my Thien for cleaning up the car and use in the house, and collector bags would be nice to keep the HEPA filter clean…
NH_Hermit
334 posts in 1261 days
#4 posted 797 days ago
Yup, I love mine too. Don’t attempt to vacuum up water with a dirty dust clogged filter though, like I did (or tried to do) – what a mess!
-- John from Horse Shoe
kosta
946 posts in 1519 days
#5 posted 797 days ago
Yeah you have to change the filter out to a foam filter. I have done that before and it actually works pretty good for cleaning up water
-- kosta Virginia Beach, VA http://www.kostasworkshop.blogspot.com/
POGO
15 posts in 1049 days
#6 posted 796 days ago
I purchased this vacuum about 6 months back after having researched many different manufactures and models. Notwithstanding all of the advertising claims on HP, I found the best measure is Air Flow (CFM) which is directly proportional to the current (Amp) rating of the motor.
My primary use of this vacuum is in conjunction with the Oneda Dust Deputy for High CFM particle collection. The vacuum is used as an alternative to my shop dust collection system, which is good for high volume but does not have the suction pressure that the shop vacuums are designed to produce. I keep checking the WD 1851 for material buildup and to my amazement only a light layer pf dust particles collected after many hours of use.
In my opinion this vacuum has many of the features of the high end units without the high cost of ownership.
-- Arvid, Spring Texas
