LOCKJAW 7CCS Self-Adjusting Locking Clamp
Review by Don Johnson posted 837 days ago 2308 views 0 times favorited 6 comments Add to Favorites Watch
LOCKJAW 7CCS Self-Adjusting Locking Clamp No-picture-s No-picture-s Click the pictures to enlarge them
Whilst viewing LJ’s Project page, some clamps popped up in the advertisement sidebar, so I decided to investigate. The blurb for the set of four clamps read as follows:
Offering much more than the traditional variety, this set of four LockJaw self-adjusting locking clamps are perfect for getting the job done. Versatile and easy to use, the clamps are great for any number of jobs, and the patented LockJaw locking mechanism means the jaws open and adjust automatically to any size object. The one-handed operation makes them easier to use, whether you’re grabbing something thick or thin.
The picture showed clamps similar to the one supplied with my Kreg Pocket Hole system, but I was intrigued by the self-adjusting system which claimed to obviate the fiddling about needed with the Kreg clamp or a Mole grip. They were being offered by QVC, a shopping channel not immediately associated with top quality tools, but the price including p/p was £26.03 – so I sent for a set.
The clamps DO work in the manner described, with the chosen pressure (or at least the force required to close the clamp) being the same for varying thickness of clamped material. In the picture below, the force to close the lower clamp holding the leg of the Joint Genie was the same whether or not the extra wooden spacer was added.
I must say, that getting the Kreg-type clamp set just right usually involved me in quite a few close/unclose/reset screw sequences, which this clamp does not require – once you have chosen the pressure you like, the clamp holds on any thickness without further adjustment. The actual adjuster is shown here:
I appreciate that the QVC ad appeared because I am in the UK, and I have no idea whether the clamps are available elsewhere, but for me, they do look as though they will be very useful – particularly with the Joint Genie. I could not find any reference to an earlier Review of these clamps, but if I missed it, my apologies for the repeat.
I have awarded only 4 stars, as one of the springs that control the ‘floating’ jaw was not correctly fitted. The clamp appears to have been designed so that the spring cannot fall off in use, but that prevented me getting it back – even tho’ as I previously worked for a company that made small springs, I consider that I have some expertise in this area (LOL). I will return the offending item using the included QVC returns details, so I expect it will be replaced without any problem.
-- Don, Somerset UK, http://www.donjohnson24.co.uk
View Don Johnson's profile
Don Johnson
538 posts in 978 days
6 comments so far
View AttainableApex's profile
AttainableApex
336 posts in 1030 days
#1 posted 837 days ago
hmmm cool
-- Ben L
View Wolffarmer's profile
Wolffarmer
373 posts in 1435 days
#2 posted 837 days ago
Hey thanks for the review. As a long time farmer/mechanical hack, i have always wondered how those types of vise grips work. I just never felt the need to get some different than what I know.
Randy
-- That was not wormy wood when I started working on it.
View D1st's profile
D1st
285 posts in 1237 days
#3 posted 836 days ago
Thanks for the info. I might have to try them some day.
-- http://www.furstwoodworks.com/
View woody57's profile
woody57
639 posts in 1625 days
#4 posted 836 days ago
Thanks for the review. I did not know that the amount of pressure could be adjusted on those. I might give them a try.
-- Emmett, from Georgia
Don Johnson
#5 posted 827 days ago
As a follow-up to the 4-star rating because one of the clamps had a spring misplaced, I did return the single offending item to QVC, and they DID send me a replacement – but a complete new set of 4 clamps! So I now have 7 !
If I could amend the original rating, I should perhaps award 6 stars !!!!
View therookie's profile
therookie
887 posts in 1025 days
#6 posted 827 days ago
-- http://aewoodworks.webs.com
