Sweet!
Review by fladdy posted 841 days ago 1703 views 1 time favorited 14 comments Add to Favorites Watch
Sweet! No-picture-s No-picture-s Click the pictures to enlarge them
When I ordered this blade I wasn’t sure what to expect, other than it being better then the general, all-purpose blade I was using to cut some hard maple on my tablesaw. This was one of the lower priced blades from Rockler wen I was looking at Rip blades and easier to justify to my wife that I needed this blade. I just got the blade today and it worked great! To give you a little background, I have a Craftsman tablesaw that I upgraded with the V poly belt. Nothing special about it, and I’m cutting 15/16” hard maple on it. As soon as I turned on the saw and put the wood to the blade, it went through like butter. It was also advertised to leave a very smooth edge, which it did. It was a lot quieter then the other blade I was using and it didn’t leave any burn marks of any kind. It was almost as good as going thru a jointer. For the price of this blade, I was very happy with it. I would highly recommend this saw blade to anyone.
-- Fladdy
View fladdy's profile
fladdy
63 posts in 1209 days
14 comments so far
View Tyler's profile
Tyler
172 posts in 890 days
#1 posted 841 days ago
Just curious, how old is your craftsman table saw? Mine is probably mid-80s, but I wasn’t able to put a v-link belt on it because of the pulley size – did you replace the pulleys as well?
View Dusty56's profile
Dusty56
10720 posts in 1885 days
#2 posted 841 days ago
Tyler They make those belts in different sizes.
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View RobertT's profile
RobertT
44 posts in 978 days
#3 posted 841 days ago
I own the thin kerf version of this blade and it is my first choice also.
fladdy
#4 posted 841 days ago
Tyler my saw is from the mid 90’s or later I think. My dad gave it to me, nice huh! Dusty is right, the belts come apart in 1” pieces so you can take links off to get it to the correct. side.
-- Fladdy
View pintodeluxe's profile
pintodeluxe
1843 posts in 1010 days
#5 posted 840 days ago
Thanks for the review. I really like my Freud 50 tooth combination blade as well. Whenever I rip 2” thick leg stock, I think about getting a dedicated rip blade. It takes two passes with the combination blade, and even then you have to send it through the planer, or make another skim cut on the tablesaw to remove burn marks. The combination blade does great on hardwood up to 5/4” thick, plywood, and melamine, but thick leg stock is where it slows down a bit. Have you tried your rip blade on anything that thick?
Thanks again
Tyler
#6 posted 840 days ago
My issue is not length, but the width. The 1/2” version (I think) was too wide to sit in the pulley.
View jayman7's profile
jayman7
207 posts in 1702 days
#7 posted 840 days ago
I got the thin kerf of this blade and yes it’s amazing.
fladdy
#8 posted 840 days ago
Tyler, if you’re really interested in the v-link belt you might want to try http://www.mcmaster.com and see if they have a pulley that will replace your current one.
-- Fladdy
View David Craig's profile
David Craig
2128 posts in 1305 days
#9 posted 840 days ago
Tyler, V-links can be purchased in 3/8th as well. Not sure about your pulley width, but I do know they are not limited to just 1/2 inch these days.
David
Tyler
#10 posted 840 days ago
Thanks for the info everybody. I’m not sure what size my pulleys are, but its good to know options are out there.
Dusty56
#11 posted 839 days ago
Yes , my comment was referring to the various widths , not the length …obviously if you use a link belt , you can make it any length you want.
View mnpete's profile
mnpete
189 posts in 854 days
#12 posted 839 days ago
I’ve got this same blade and it cuts beautiful 1/8 inch groves with a clean, flat bottom. My Dad sent it to me to cut corner slots in boxes for keys/splines. I just used it recently for the grooves to recieve box bottoms and, temperatures permitting, I’ll be cutting those corner slots for splines this week. Here’s me using the blade.
http://secondwindworkshop.blogspot.com/2011/02/groovin-on-saturday-afternoon.html
Pete
-- Follow my woodworking adventures in The Second Wind Workshop, http://secondwindworkshop.blogspot.com/
View blockhead's profile
blockhead
1428 posts in 1505 days
#13 posted 839 days ago
I’ve had mine for about a year now and have cut lots of stock. It’s still super sharp and does an awesome job of ripping and cutting splines. This one offers plenty of bang for the buck.
-- Brad, Oregon- The things that come to those who wait, may be the things left by those who got there first.
View JimNEB's profile
JimNEB
219 posts in 1265 days
#14 posted 838 days ago
I can agree with the above posts on the Freud blade. I’ve been using it for about six months now and it does a fine job. I also have the full kerf combo blade which is also a good value.
-- Jim, Nebraska
