It's a Drill Press
Review by Chris posted 279 days ago 204 views 0 times favorited 0 comments Add to Favorites
View Chris 's profile
Chris
1261 posts in 531 days
It's a Drill Press No-picture-s No-picture-s Click the pictures to enlarge them
I was in need of a drill press and purchased this drill press on clearance. It performs as advertised; however there a couple of areas that are lacking.
The Good:
1) Spindle run out is almost non-existent
2) The speeds are easy to change
3) It seems to have plenty of torque for my needs
The Bad:
1) Even when “locked down” the table can wander laterally
2) The table height adjustment has a lot bit of play
3) Worst of all: The table deflects significantly even with moderate downward pressure
4) the depth stop might as well be made of tin foil. It bends so easily that it’s useless. Are there aftermarket items to replace this?
In retrospect I should have waited. This is and will be the last impulse machinery buy I ever make. I normally research and wait for the best price and time. I was wooed by the rock bottom price and did not end up with a quality machine.
Photo from the Shop Fox Website
-- Chris
0 comments so far
Bookmark And Share This Page
