"Bucket Head" Vacuum
Review by FJPetruso posted 02-13-2011 09:57 PM 14769 views 0 times favorited 5 comments Add to Favorites Watch
"Bucket Head" Vacuum "Bucket Head" Vacuum "Bucket Head" Vacuum Click the pictures to enlarge them
I found this Bucket Head Vacuum on display at Home Depot a while back & decided to give it a try. Heck… It’s only 20 bucks & uses an ordinary 5 gallon plastic bucket for collection of dust & chips. (I just happen to have acquired a couple of plastic buckets that have the same rim dimensions but hold about 7-1/2 gsllons & are several inches taller.) There’s no doubt that it’s a cheap vacuum but it works well. The filter is a simple pouch over the suction side of the vacuum motor in the bucket held on with a large rubber band. Both easily replaceable. The vacuum has a hose about 1-1/4” in diameter & 4 feet long & no accessories. But that’s OK. All I want it for is a vacuum to put with a woodworking tool that I don’t want to run my dust collector to. It’s cheaper to buy this set-up than it is to run 4” hose, blast gates & adapters! I plan on purchasing one or two more for the same reason. If you only have a small hobby shop or just want to keep the better half from griping at you for using her good vacuum for shop work & for only $20 & easy set-up… I gave it four stars because when you consider the price & what it’s used for… It does the job great!
-- Frank, Florissant, Missouri "The New Show-Me Woodshop"
View FJPetruso's profile
FJPetruso
326 posts in 3614 days
5 comments so far
View dbhost's profile
dbhost
5686 posts in 3136 days
#1 posted 02-14-2011 03:10 AM
Is there any way to upgrade the filtration in this thing?
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
FJPetruso
#2 posted 02-14-2011 04:01 AM
I was going to make another filter bag out of an old cloth dust collector bag. I suppose you could take measurements & try & match a pleated paper style filter & adapt it.
View twokidsnosleep's profile
twokidsnosleep
1106 posts in 2878 days
#3 posted 02-14-2011 05:50 AM
I crapped out one of these within a month using it for a small downdraft box
Hope yours holds out better
-- Scott "Some days you are the big dog, some days you are the fire hydrant"
View Robert Kennedy's profile
Robert Kennedy
1 post in 3228 days
#4 posted 02-19-2011 07:48 AM
I understand it not having a long life span….its $20bucks….how loud are they? do they scream like a shopvac or did we get lucky and have little noise with little suction….I am thinking about using one on a portable chopsaw…I have a battery op dewalt vac on it now…..Id like it back in my truck were it was purchased for!
-- Bob Retreat design Camano Island, wa.
FJPetruso
#5 posted 02-19-2011 09:42 PM
It doesn’t make as much noise as my craftsman shop vac, but it’s close to the same noise level. But it’s easy to set up & like you said… It’s $20 bucks!
