Craftsman Professional series #315.218290 Tablesaw with folding stand.
Review by Dadoo posted 322 days ago 2076 views 0 times favorited 10 comments Add to Favorites
View Dadoo's profile
Dadoo
1557 posts in 530 days
Craftsman Professional series #315.218290 Tablesaw with folding stand. Craftsman Professional series #315.218290 Tablesaw with folding stand. Craftsman Professional series #315.218290 Tablesaw with folding stand. Click the pictures to enlarge them
This is my personal review of my Craftsman saw listed above. I work out of a two car garage that I need to park two vehicles in, so I need a saw that is light and portable, and that leaves a small footprint when stored. About a year ago I literally burned up my old Rockwell tablesaw and went on the hunt for a new one. Brands like Bosch, Makita and Rigid weren’t readily available to see, touch and examine…and Sears had this one “on sale” for $350.00. There was a Dewalt saw next to it that I did compare to. The salesman told me (maybe it was his sales pitch) that this model was designed by former Delta engineers trying to create a more compact and portable saw. I was also checking out the other saws too and he didn’t offer any “pitch” towards those.
I like this saw. When stored it sticks out 2’ from the wall and weighs 110 lbs. The wheels are hard rubber and the stand works with ease, unfolding with one toe. When set up, the saw is very stable on this stand. There are adjustable leveling feet too.The motor runs on 120vac at 15 amps and developes a no-load speed of 4800/min. The blade arbor is 5/8” and uses a 10” blade. It is also driven by 2 belts. I have ripped several lengths of maple (using a Freud Diablo blade) with no slowing noted. It is quite powerful. The blade is enclosed into a cast aluminum shroud that has a 2 1/2” exaust port on the rear for shopvac hookup.
The Pros: What impressed me the most is that all the accessories and jigs are built in. This saw will cut 30” to the left or right of the blade. It will cut panels up to 22” wide on the miter sled. It will cut compound miters. The fence has a sight window that has remained accurate since I originally set the unit up. The router table and miter sled can be used on either side of the blade and come off very easily, without tools. Blade changeing is simple with the two wrenches provided. One of these slides into a groove, locking the arbor, allowing for one handed blade changes. It also has a rack and pinion gearing which allow for easy blade height and angle adjustments. The fence is held by friction clamps and I haven’t had it move at all. There are other accessories that clamp to this fence allowing it’s use for the router table as well. There is a switchable outlet on the right side which allows the power switching of the router too. The riving knife, anti-kickback pawls and blade guard are easily changed by loosening two nuts behind the blade. The wrenches are provided. There is a storage area on the left side for extra blades and the provided wrenches. The instruction book is very through and includes mechanical diagrams and parts lists for the entire unit. It’s also made in Taiwan…now noted for it’s better quality control today.
The Cons: (1)Setting the saw up (out of the box) takes a little patience, but once set, it stays right on. Like I previously stated, the friction clamps need to be adjusted so that they clamp tightly. I was routing a dado in a board and ended up with a crooked groove because the router table had moved, not the fence! (2)The switch is located under and to the right. You have to “look” to find it. (3)The provided blade is a 36 tooth carbide unit from China. I haven’t used it yet. I might never. (4)The table surface is coated with a teflon type paint. Although slippery, is can be scratched. (5)Accessories like a zero clearance throat plate are listed, but unavailable. (6) The accessory power outlet has only one outlet, either for the saw motor or for the router motor. I’d like to see two outlets so that I can switch on the shopvac as well. (7) And this is the worst! This saw fits easily into the back of my son’s truck! Guess I harbor some reservations about my baby (saw, not son) leaving the shop!
I would recommend this unit to anyone with a small shop or storage problems. I would also recommend it for jobsite contracting, but abusive employees can damage it easily.
10 comments so far
View Bill's profile
Bill
2524 posts in 701 days
posted 322 days ago
Nice review Dadoo. It looks like you found something that fits your needs and does it job.
View Tomcat1066's profile
Tomcat1066
621 posts in 336 days
posted 322 days ago
Nice review Dadoo. I looked at one of these this past weekend on the Sears showroom floor and it looked like a pile of dog pooh. I guess this one I saw might have been just abused by people playing with it.
I’ll have to give it a second look.
-- "Give me your poor tools, your tired steel, your huddled masses of rust." Yep, I ripped off the Statue of Liberty. That's how I roll!
2898 posts in 519 days
posted 321 days ago
Great Review Dadoo;
These saws definitely fill a need. My jobsite saw is the Bosch unit, and I am very happy with it. I can’t imagine being on a job without a saw of these types.
In fact I have a 4” jointer and a 12” planner I can take to sites when needed. We are able to make pretty much everything on site when needed.
Being able to have precision tools at the job sure makes things easier.
Very well written review!
View Muddler's profile
Muddler
30 posts in 641 days
posted 320 days ago
nice review, Dadoo.
the saw is actually the legacy of the Ryobi BT3100. The BT3100 was originally sold for $300 with a stationary stand, and the accessory kit sold for $100 and included the router table add-ons (the fence, guard/d/c port, inserts for the bit hole), a standard miter slot insert, zero clearance and dado inserts for the blade, clamp for the miter table, and crappy wheel add ons to make the stationary stand a little more mobile. A year or so before Ryobi discontinued the saw, Sears starting selling it with most of the accessories and the mobile base for $450 as the model you bought. If you are looking for parts, the BT3100 parts are interchangable if you can find them. Check out www.bt3central.com for more info on the saw – there’s actually a cult following if you can believe it!
-- ...straight lines or tight lines, either will make me happy! Muddler
View Mark A. DeCou's profile
Mark A. DeCou
1365 posts in 945 days
posted 320 days ago
good review. I’m glad that you like this saw. I had previously given up an anything that had the Craftsman brand on it. Glad it is working out for you and meets your needs. Nice review.
-- Mark DeCou - Kansas Flint Hill's Artisan
View rikkor's profile
rikkor
8645 posts in 414 days
posted 320 days ago
I’m with Mark. Craftsman has really let me down lately. I am glad your luck is different. Thanks for the review.
-- Maplewood, MN
View IgotWood's profile
IgotWood
18 posts in 498 days
posted 318 days ago
You put cars in your garage?! I never thought of that…
-- Jeremy, Austin Texas- A bad day in the shop beats a good day at work
View dieselman's profile
dieselman
5 posts in 217 days
posted 212 days ago
I have a bro inlaw that has 30yrs in remodel trade, he still has his Craftsman table saw
from 20 yrs ago,1st 10 yrs Dewalt. Chet said he would buy a older model Craftsman
rehab it,and have the best saw around. Also said that a table saw is like a house,the
better the foundation the better the saw will be,also he gave good marks for Ryobi products.
Dieselhammer
-- DIESELHAMMER
View jake's profile
jake
4 posts in 243 days
posted 180 days ago
For anyone interesting in this saw, check out BT3central.com. It is a version of the Ryobi 3100 that was really popular and has a huge following-with their own website. Lots of good information there as well but people are dedicated to that saw. For years I used a Ryobi 3100 (basically this saw with different stand) and made many nice pieces of furniture. Moved up to the Sears Zipcode saw and now love it but keep the 3100 as the cast iron table of the new saw certainly wont let it be portable like the 3100. The line the Sears guy said about Delta guys was actually referring to the new hybrids they sell (zip code series) as Orion is a division of Steel City- the company that had old Delta guys break away and form the company.
6735 posts in 391 days
posted 180 days ago
Great review Dadoo.
Bookmark And Share This Page
