| Review by Vrtigo1 | posted 866 days ago | 3110 views | 2 times favorited | 15 comments | ![]() |
- Osborne EB-3 Miter Gauge
- Brand: Osborne | Category: Tablesaw Accessories
Just picked this up from Amazon last week and it arrived two days ago. Assembly took about 30 minutes and was straightforward. I especially like the adjustability of the bar that fits in the miter track. It was close right out of the box, but after adjusting it, there is literally zero play and it still slides like butter.
The abrasive that sticks to the face of the miter gauge really works. I cut a few test miters and the workpiece stayed exactly where I put it. The extendability is nice for cutting longer boards. It makes it go faster without having to attach you own extension. The miter accuracy is dead on. I cut four 45 degree angles to form a square, and everything fit beautifully.
After having used it for two days, I have two complaints, both minor ones. First, the sliding workpiece stop seems like it has a bit of play in it. If you but it against your workpiece and tighten it down, it seems like it can move about 1/32nd of an inch or so. I’ve been butting it against the workpiece, then pushing the top of the stop (the part where the locking screw is) toward the blade before tightening it, to try and take up the play.
The second complaint isn’t so much a complaint as it is an observation. When adjusting the miter angle, there’s a spring loaded button under the set screw for locking down the angle. When you press this button, it engages preset stops at common angles. If you release the button after finding your angle and then tighten the set screw, it seems like the angle setting can drift a bit. I’ve been keeping the button depressed while tightening the set screw. This causes the button to remain depressed, and probably shifted to the side a bit more than it’s designed to be as the angle is locked down. It works fine, but it doesn’t seem like this was the way it was designed to work.
All in all, for the price I’m very satisfied. There are other gauges that are less expensive, such as the Incra V27 which is about half the price, which are probably just as accurate. If you just need accurate angles, then that might be a better choice, but if you like the large non-slip face and extendable sliding stop, then this is a great choice.
15 comments so far
richgreer
home | projects | blog
4472 posts in 1270 days
#1 posted 866 days ago
I have this miter gauge and I am very happy with it. It is “dead on accurate”. If I have a complaint it is that it’s a little heavy.
bluesmarky
21 posts in 1112 days
#2 posted 866 days ago
Got one of these too & love it! Good enough for Norm, good enough for me.
-- bluesmarky..........................................."If you're here & I'm here, doesn't that make it our time?"
bigike
4021 posts in 1484 days
#3 posted 866 days ago
i found it for $120 on amazon that’s not a bad price. I’ll have mine in a few weeks. thanks for the review.
ChunkyC
849 posts in 1450 days
#4 posted 866 days ago
I got one last year. Best money I’ve spent in a very long time. My stop has play in it too. Mine moves as you tighten it up. I have to hold the stock against the stop very tightly as I tighten up the stop.
As for the angle drifting when tightening it up. This should not happen. Email Osborn, I’m sure they will might it right by you.
My complaint is with the extendable arm. I have to loosen both screws because the screw closest to the blade just catches the end of the rod. Does yours do this? Oh and that clamping a sacrificial fence to it is next to impossible.
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
lilredweldingrod
2493 posts in 1302 days
#5 posted 866 days ago
Yep, Norm said he liked it so I bought mine from him. No disappointments here.
And Yes Deke, you can have one too. You will be very happy I assure you.
Just keep the pivot screw tight. Right David? lol
Vrtigo1
420 posts in 1187 days
#6 posted 865 days ago
Chunky, yes mine does the same thing regarding the extendable arm. You could probably leave the knob closest to the blade a bit loose, but you’d want to check that it doesn’t get too lose from the vibration from the saw running.
MattinCincy
128 posts in 1349 days
#7 posted 865 days ago
I’ve had an Incra Miter 2000 for many years (the one that only adjusts over a 55 degree range) and have used it extensively for many things that require absolute accuracy. I recently bought the EB3 after reading many opinions here on LJ’s about how good it was because I wanted to be able to easily cut angles over +/- 45 degrees, which isn’t easy with my Miter 2000 (you have to basically disassemble the whole thing to convert it to work in the other miter slot on your saw, and then, because of a design flaw, you lose calibration when switching back). After setting up the EB3, I have to agree with Vrtigo – the spring loaded button doesn’t inspire confidence when setting preset angles, as the whole mechanism feels a bit “mushy” when tightening the locking screw. So I ran a few repeatability tests with a dial indicator to see how repeatable the presets were, and then did the same thing with my Miter 2000. Suprisingly, I was able to get the EB3 to repeat to within .003” – .004” when taking readings near the far end of the fence, but it took some concentration to use the same technique every time for holding the button down and tightening the screw. My Miter 2000, on the other hand, repeated within +/- .001 every time, without a fuss.
I have since boxed up my EB3 and it is sitting on the shelf waiting for me to make a decision about what to do with it. For many people, it works great, but I am a stickler for accuracy and prefer the Incra products. I’m probably going to look at a Miter1000 or Miter 3000.
-- Wag more, bark less.
WoodyG
31 posts in 1369 days
#8 posted 865 days ago
I have this same unit for about 2 yrs…I have had to adjust it one time….and it is easy to adjust and seems to stay but now my depress button is giving some kind of problem….sticking it is and lubrication hasn’t helped but it is still as accurate as it was when new. Yes, I would reccomend it but the extension arm is about useless and the bottom of the unit needs a good slick strip.
-- WoodyG
Lenny
1055 posts in 1723 days
#9 posted 865 days ago
Thanks for the post Vrtigo. Add me among the list of satisfied EB3 owners. Like bluesmarky for me it was a “good enough for Norm, good enough for me” proposition. My only issue was the abrasive tended to shed for awhile when I first got it. This left grit on my table saw (TS) that got dragged when I pushed the miter gauge. Since it was also a new TS I am not ashamed to say I shed a few tears at the scratches left behind. Another reviewer recommended hitting the abrasive with several swipes of your sanding belt eraser to loosen and remove the looser grit. WoodyG my gauge came with slick strip tape with an adhesive backing for mounting to the underside of the fence. If yours didn’t you might want to contact Osborne and tell them. They might send some to you. The owner (David, I think) used to be a LJ with a name of miterguy if I remember correctly. I don’t know if he still is. Again, nice review Vrtigo and good luck with your EB3.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
Scott Oldre
245 posts in 1627 days
#10 posted 865 days ago
I have the Incra 1000SE because it matches the color of my Incra TSLS-32 Fence and rails. Seriously, I always hear good things about the Osborne, but after reading these comments about fiddling with this and fiddling with that, I’ll stick with my Incra which has more than enough capacity and can be used in either slot. I also use it alot with the Incra EZ-slider. The Incra Gold is as good as Gold for me, but I’m glad to hear you like what you have as well. IF it works, don’t fix it.
-- Scott, Irmo SC
Lenny
#11 posted 865 days ago
FYI, the Osborne can also be used in either slot. You have to undo some hardware and swing the arm around but it is made to go in either slot.
roundguy
59 posts in 880 days
#12 posted 832 days ago
Had one for a few years now. Love it !
CyberDyneSystems
77 posts in 384 days
#13 posted 297 days ago
Just FYI,
Two points of interest:
1- The abrasive tape problem can be solved by using a different type of grip tape.
3M and others make a rubberized grip tape for use in showers etc, that does not have any abrasive material attached, instead it is a rubbery texture built into the tape material itself. Nothing to flake off, nothing to scratch table tops or material. I’ve had good luck using this as a less aggressive grip tape on pistol grips. Some of the pricey after market manufacturers of stick on grip enhancers for pistols are using the same thing, just die cutting it and charging 8X as much.
2- I just bought an Osborne from the Manufacturers website, and it’s on sale as of now ( August 24 2012) for just $109.00 with FREE Shipping. I’ve never even seen a used one go for that price.
http://www.osbornemfg.com/
P.S. I posted this info here as it was the latest of the reviews.
lepelerin
76 posts in 521 days
#14 posted 266 days ago
That was my Xmas gift last year. Phenomenal miter guide upgrade from the one that came with my Ridgid 4512. I love it. Would highly recommend it for the price and accuracy.
fzxtchr
14 posts in 1247 days
#15 posted 227 days ago
I recently purchased the Osborne gauge and have been quite happy with it. Whether I am using it on a Ridgid 2424 or on my portable Dewalt 744, I have been getting very accurate, clean cuts. As an example, I was cutting the end of a 1.25×1 inch board to a 29 degree angle and, once I added an auxiliary fence to the miter gauge, I had not troubles at all. I had no problems in clamping the fence to the gauge.
The cut:
The fence (Unfortunately, I have the saw packed away right now and don’t have a picture of it clamped to the gauge.)
