Great for honing, but doesn't replace stones and grinders
Review by Hawgnutz posted 279 days ago 397 views 0 times favorited 9 comments Add to Favorites
View Hawgnutz's profile
Hawgnutz
507 posts in 616 days
Great for honing, but doesn't replace stones and grinders No-picture-s No-picture-s Click the pictures to enlarge them
I love my Work Sharp! But it has limitations that you will have to work around. One major one is that it will not sharpen plane irons wider than two inches! When I tried to sharpen my iron from my #7, using their auxiliary sharpening fence, I inadvertantly added two extra angles. I then had to use my stones to correct these new angles.
When sharpening plane irons 2” and smaller, it does a good job, but you need to do the initial sharpening on a stone first, or be prepared to spend a lot of time and money with their sandpaper sharpening. But once the initial grind is established, this system is GREAT for repeatablity on your angles! Creating a micro bevel is as simple as clicking an adjuster to a new angle and grinding through the grits to get crisp micro bevel. This sharpener has made my block planes sing! And, oncde they lose their hone, it is a simple process to return them to sharpness! This has 4 angle settings, 20, 25, 30 and 35 degrees. These allow for precise, repeatable angles on your planes and chisels.
The ability to precisely flatten the back of your plane irons and chisels is one great feature of this tool! Another is its small footprint. That alows you to keep it on a side table/workbench for quick resharpening when needed.
You can find various 6” PSA aluminum oxide sandpaper at your local body shops in varying grits. Look for a hole punch that will punch the required center hole. I found a set on Ebay some years ago. I find that I only need to grind to 400 grit, then hone my iron or strop it on a piece of leather with jeweler’s rouge. Extra glass wheels are available for around $20, and a leather stropping wheel is available for $30. I already have a lot of lether scraps and some Barge cement, so I will be making my own stropping wheel with an extra glass wheel I have.
One of the realy neat things of this sharpening system is the slotted, see-through grinding wheels. I have not used these, but they say that it allows turners a way to see their tool’s edge as they sharpen them. Cool for turners!
I only gave it 4 stars due to its inability to sharpen plane irons wider than 2” but Work Sharp has said they will introduce, later this year, a jig that will allow the sharpening of these wider irons. I look forward to this, for sure!
God Bless,
Hawg
-- Saving barnwood from the scrapyards
9 comments so far
View trifern's profile
trifern
5049 posts in 307 days
posted 279 days ago
Thanks for the review, Hawg. I have been curious about this tool.
View Scott Bryan's profile (online now)
9950 posts in 362 days
posted 278 days ago
Hawg your review is on target. I have one of these and am happy with the sharpness of my chisels. I have tried stones and sandpaper but could never get the edge that I wanted. This tool produced a razor edge on my chisels and plane irons that make working with hand tools a pleasure.
Hawgnutz
posted 278 days ago
Yes, this tool will put a sharp,accurate and rpeatable grind on your chisels and plane irons. My block plane just sang along some pine and maple after my first use of it! My chisels, even my cheap ones, shaved wood in mortises and releifs I needed to make.
It would have taken me longer to haul out my stones, bevel guide and such than it took me to put that razor hone on my good irons.
God Bless,
Hawg
14323 posts in 940 days
posted 278 days ago
Great review.
-- Karson Southern Delaware karson_morrison@bigfoot.com †
View rikkor's profile
rikkor
8645 posts in 414 days
posted 278 days ago
I have one and I love it. It helps that I don’t have any planes with irons bigger than 2”.
-- Maplewood, MN
View brunob's profile
brunob
1391 posts in 709 days
posted 278 days ago
I use mine for my carving tools. I am “sharpening challenged” so this tool is a huge asset for me.
-- Bruce from Central New York
View king's profile
king
30 posts in 487 days
posted 182 days ago
After reading your review and afew other I bought the W/S3000 I am very happy with it so thanks alot.
-- franklinalbert@sbcglobal.net
6735 posts in 391 days
posted 181 days ago
Great review, thanks for sharing.
Hawgnutz
posted 181 days ago
As an addition, I can get replacement PSA sandpaper, in varying grits at my local auto paint shop. (I use the 80 grit to resurface used planes from swap meet or Ebay.) this rough grit also helps to put that initial grind on new or old chisels that have the wrong grind to start with.
God Bless,
Hawg
Bookmark And Share This Page
