Outstanding Saw for the Home Shop
Review by Chris posted 638 days ago 871 views 0 times favorited 3 comments Add to Favorites Watch
Outstanding Saw for the Home Shop No-picture-s No-picture-s Click the pictures to enlarge them
I have owned this saw for approx. two years now. In reality I would rate it at about 4.5 stars only due to a minor annoyance. I had been using a bench top Delta given to me by my father in-law for a few years and had become VERY frustrated with this kind of saw. In my search for a contractor style saw it came down to either the Powermatic or the General; I am glad I chose the General.
It was accurate right out of the box; I used a Master Plate / Master Guage setup to check the blade and fence alignment to the Miter slot; they were dead on. Even if they had not been the instructions provided with the saw walked you through the process easily. This saw has plenty of power to cut almost anything I ask. I have only had it bog down when cutting 10/4 Maple and my feed rate was a little fast. Combine this saw with a Forrest blade and it’s hard to beat for a home shop environment.
Oh.. I nearly forgot the annoyance. The hand wheel for the blade height adjustment will loosen up very easily.
Photo from the General International Website
-- Chris
View Chris 's profile
Chris
1470 posts in 890 days
3 comments so far
View Robb's profile
Robb
356 posts in 833 days
posted 625 days ago
Good review. I’ve heard nothing but good things from General tool owners. I’d never heard of them until after I bought my Jet tablesaw, or things might have been different. I was wondering, what hp is your saw?
-- Robb
Chris
posted 611 days ago
Robb,
It’s listed as 2HP
-- Chris
View JuniorJoiner's profile
JuniorJoiner
166 posts in 339 days
posted 333 days ago
hey chris, well i have this saw, and i think i have a lemon.i have had nothing but problems with the saw since i first purchased it. at first i had major burning issues. went through the whole gammit of fixes, new blade, blade stiffiner, miked the arbor, changed out the fence, removed the splitter. it turned out it was a fence drift problem, and i bought an after market fence that finally corrected it.
then , after about a year of use, the saw couldn’t be adjusted back to zero tilt. i thought it was strange since this is a tightly bolted stop, far out of reach. it was not gummed up or dirty, and it was still tight, but something had happened, and on the scale zero was now 1.5 degrees. after a day of adjusting back and forth and numerous test cuts. i remarked the scale to indicate what is now zero.(just couldn’t get the stop to adjust and stay put).
i also had a belt break on me during use. something i have never heard of happening on a saw that wasn’t 15 years old.
So, to remedy most of my problems, i have since bought a steel city bandsaw and use it alot more, it is less precise, but i expect that from a bandsaw.
-- Junior -Quality is never an accident-it is the reward for the effort involved.
