Makita LCT209 12volt Drill/Driver Combo Kit
Review by Gord Graff posted 01-23-2011 03:17 PM 10401 views 1 time favorited 9 comments Add to Favorites Watch
Makita LCT209 12volt Drill/Driver Combo Kit No-picture-s No-picture-s Click the pictures to enlarge them
Makita LCT 209 Combo Kit:
Does size really matter? It does when you’re using a cordless drill or driver all day or when you find yourself working over your head or in tight spaces, like building or installing kitchen cabinets.
Makita recently introduced its 12 volt, LCT 209 12volt Combo Kit that includes the 3/8” Drill (model #FD02), the ¼” Impact Driver (model #DT01) and the battery charger (model #DC10WB) and what a combination it is. A versatile, light weight, well balanced combination that has plenty of power to tackle most applications.
I’ve used this combo kit extensively for the last few months and I’ve yet to come to a situation that either one of these tools wasn’t capable of handling. From building and installing cabinets to renovation framing, this combo kit has been able to handle it all.
The power to weight ratio of this combo is typical of what you would find in a Makita cordless tool, plenty of power in a well balance tool that’s a pleasure to use all day. Is this combo kit the answer to “all” cordless drill/driver applications, no……………..no one cordless tool will satisfy every application but this combo kit has exceeded my expatiations for a 12volt combo kit. The combo kit’s battery charger charges a completely dead battery to fully charged in 30 minutes and the drill and driver both have an onboard LED light that is a lot more handy than you would think it is.
Below you’ll find a short video of the combo kit in action. Driving a 2 ½” long # 8 deck screw into a piece of 2” x 3 ½” Beech without a pilot hole. First the impact driver drives this 2 1/2” screw and then the drill drives the same size screw into this slab of Beech. After that, I chucked a (somewhat dull) 3/8” brad point drill bit into the drill and bore a hole through the Beech, all with no effort.
The ease at which this combo kit handles these tasks and so much more is what still has be reaching for these tools every time I need a cordless drill or driver.
All the best
Gord
Model No: LCT209 Combo Kit Includes:
1/4” Cordless Impact Driver (DT01Z)
3/8” Cordless Driver Drill (FD02Z)
2 Ea. 12V (1.3Ah) Li-Ion Batteries BL1014 (195332-9)
Charger DC10WB (DC10WB)
Aluminum Carrying Case (823308-3)
Impact Driver (DT01Z) Specifications:
Battery……………………………………..12V (1.3 Ah) Li-Ion
Hex Shank…………………………………1/4”
No Load Speed………………………….0-2400 RPM
Impacts Per Minute…………………..0-3000 IPM
Maximum Torque………………………800 in. lbs. (90 Nm)
Overall Length…………………………..6 1/8” (155mm)
Net Weight………………………………..2.0lbs (0.9kg)
_
3/8” Cordless Driver Drill (FD02Z) Specifications:
Battery……………………….12V (1.3 Ah) Li-Ion
Capacities:
Steel………………………….3/8” (10mm)
Wood…………………………13/16” (21mm)
Maximum Torque……………200 in. lib. (22N m)
No Load Speed:
Low……………………………0-350 RPM
High……………………………0-1300 RPM
Overall Length………………..7 7/16” (180 mm)
Net Weight…………………….2.2 lbs (1.0 kg)
-- Informing & Inspiring Today’s Woodworkers: http://www.gordgraff.com
View Gord Graff's profile
Gord Graff
140 posts in 4130 days
9 comments so far
View milesmiles's profile
milesmiles
6 posts in 3504 days
#1 posted 01-23-2011 03:46 PM
Gord——-I appreciate your review and the time you spent preparing it and laying it out with complete specs. Video clip really helps as well. Did you do any shopping between the comparable Milwuakee kit? Thanks!
-- Miles
Gord Graff
#2 posted 01-23-2011 04:02 PM
Hello Miles,
Thanks for your kind words.
This review was a simple straight forward, stand alone review of what this combo kit was all about. I chose not to compare it to the many others that are out there in the marketplace today.
When I say that I’d been working with this combo kit for months, I should have said that I beat it up for the last several months…..................this kit took the abuse I gave it and came back for more. Great package on a small platform.
All the best
Gord
View ChrisForthofer's profile
ChrisForthofer
150 posts in 3303 days
#3 posted 01-23-2011 04:43 PM
Wow, those little tools have some grunt, I have the impact drivers 18V bigger brother and am constantly staggered by how much torque it puts out. The 12v was very impressive for its size I must say. When money starts growing on trees again I will possibly have to get both ;)
Chris.
-- -Director of slipshod craftsmanship and attention deficit woodworking
Gord Graff
#4 posted 01-23-2011 06:30 PM
Hi Chris,
I have owned a number of cordless drills/drivers over the years and this small combo kit just fits right into my hands and does everything I’ve asked it to do and more. Once again I say, a great package on a small platform.
All the best
Gord
View BTKS's profile
BTKS
1989 posts in 3700 days
#5 posted 01-23-2011 07:50 PM
Good review.
I’ve been more than pleased with every Makita tool I’ve purchased, corded and cordless.
BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View ND2ELK's profile
ND2ELK
13495 posts in 4010 days
#6 posted 01-23-2011 08:01 PM
I have a 4 piece Makita cordless kit and like them very much. Good tools!
-- Mc Bridge Cabinets, Iowa
View Drew's profile
Drew
350 posts in 3336 days
#7 posted 01-24-2011 05:42 PM
Pretty much the same thing as the Makita LCT203W 10.8-Volt kit.
They both appear to use the SAME 3 cell, 1.3ah battery. The LCT203W is rated at 10.8 volts, 3.6 votls per cell, while the LCT 209 that you are reviewing is rated at 4 volts. Which would be a ‘max/peak’ voltage.
I really think that other then the color and the chuck on the drill that these are the same drivers. All the stats are the same….
RPM, Torque, Impacts per minute and the amper/hours are all the same.
I bet the charger is the same too. DC10WB-vs-DC10WA
Not to take anything away from this set of drivers. I have the 10.8’s and use them everyday.
-- TruCraftFurniture.com
View Drew's profile
Drew
#8 posted 01-24-2011 05:44 PM
I should also add that Bosch’s 12 volt is the exact same thing as there 10.8 volt drill. Only difference is the sticker!
View JeremyM's profile
JeremyM
18 posts in 2914 days
#9 posted 01-29-2011 07:23 AM
I like how small these drill are now, there just great
-- Jeremy, http://projects-for-woodworking.com
