| Review by Raymond | posted 877 days ago | 2350 views | 0 times favorited | 5 comments | ![]() |
- Harbor Freight Air File 1704
- Brand: Harbor Freight | Category: Files and Rasps
I recently purchased the Harbor Freight Air File. This thing works like a charm. A little heavy but works great, the online specs state 8.5 cfm, however the manual states 4.0 cfm. Harbor Freight is forever getting the specs wrong on there stuff. “Always check the manual, never rely on the online specs”. The files included are surprisingly of good quality. The tool requires the files to have a tang of ¼ inch. This little gem is very quiet, and no vibration. And for 17.99 again how could I go wrong.
From Harbor Freight Specs
There’s no faster, more efficient way to handle filing and small grinding jobs.
Air consumption: 8.5 CFM WRONG 4.0 is the correct CFM
Working pressure: 90 PSI
Runs quiet
Comes with flat cut, half-round, round, and triangular files
Ideal for light finishing operations on steel, cast iron, wood, and synthetics
Stroke: 23/64”
Speed: 3700 SPM
Air inlet: 1/4”
Hose size: 1/4”
Dimensions: 6-7/8”
Shipping Weight: 2.58 lbs.
-- Ray
5 comments so far
tomd
home | projects | blog
1310 posts in 1936 days
#1 posted 876 days ago
Thanks for the headsup, I think with your accessment I will buy one. Good review.
-- Tom D
knottysticks
253 posts in 1195 days
#2 posted 875 days ago
I don’t suppose one could use some kind of collet to allow one to use smaller files ? Thanks for the review .
-- Everyday above ground is a good day.
Raymond
665 posts in 1893 days
#3 posted 873 days ago
Funny you should mention that. I machined one over the weekend to accept 1/8 file tangs.
-- Ray
knottysticks
#4 posted 873 days ago
Thats just what I was wondering about , so you have a metal lathe or used some other method ? thanks .
Raymond
#5 posted 866 days ago
Yes I have an old Atlas Metal Lathe.
-- Ray
