Out of the box review and initial impressions.
Review by dbhost posted 12-14-2010 08:59 PM 36084 views 1 time favorited 29 comments Add to Favorites Watch
Out of the box review and initial impressions. No-picture-s No-picture-s Click the pictures to enlarge them
A full review post use, and swapping blade to a proper blade are going to be in the works, but I figured I would post this up now to give you guys a heads up. I may just edit this review when I am ready, who knows?
This is NOT a usage, or long term review, this is just a fit and finish sort of thing. So if that is what you are interested in, read on…
I picked up a Chicago Electric #98194 on Friday with a coupon I have been sitting on for a few months that expired on Sunday, so it was a use it or lose it sort of thing. The coupon brought the price for this 12” sliding compound miter saw down to $109.99, and then throw the 2 year warranty on top of that, and taxes and I walked out the door for just a few cents over $140.00. If you are familiar with Miter Saw pricing these days, a B&D or Skil 10” non slider runs around $125.00 to $135.00 pre-tax, so for the price of of a cheap 10” non slider, you can get a cheap 12” slider, but is it worth it?
As you may, or may not know, the Chicago Electric Tools line, just like almost everything else at Harbor Freight, is just another Asian import line of tools, typically they are identical in all aspects save for coloration of plastics, stickers and / or paint / powder coatings as other brands on the market. Without giving up the who / where / why / when I can say that this miter saw, appears in all aspects aside from what I mentioned above to be identical to at least 3 other brands that I see in LJs shops… So I know this one gets around quite a bit. The 10” version gets a LOT of bad press, especially with the blade guard, but so far reviews on the 12” are favorable. The guard on mine, well it’s pretty basic, and seems functional enough. Time will tell when I go to replace the blade!
A few things worthy of note here. The packaging that Harbor Freight is using these days, especially the foam blocking material, is FAR superior and protective than the packaging I am used to from them. This thing was very secure in its box. Now with that said and out of the way, let’s get down to the nitty gritty.
Out of the box, it took me a minute to figure out how all the knobs, levers, buttons and other various controls worked. Checking with various squares, and drafting triangles finds that the fence / blade etc… are all dialed dead in from the factory, and that the stops at 22.5, 30, and 45 degrees are exactly where they are supposed to be, and that he blade tilt measurements are where they are supposed to be. No adjustments to the fence, or anything of that nature was needed.
The pointers for both rotate, and bevel adjustments were misadjusted, but easily brought into line with nothing more than a #2 Phillips screwdriver.
The throat plate on this saw is adjustable, which in this price range was a stunning find. I did not expect this, and am very happy that it is adjustable. I may still make a ZCTP for it, but at least this way, I am in no huge hurry…
There was no play in either the head assembly, or the arbor bearing, so the blade stays true throughout the lift / lowering cycle. And while not perfectly smooth, the slide action is on par with the much more expensive Ridgid and DeWalt sliders that were on display at Home Depot. (The only slider I have laid hands on that is perfectly smooth sliding is the Makita…)
Overall the saw looks solid, and well thought out. and the fit and finish where it matters is top notch. The castings fairly clean and well made, and finished reasonably well applied (looks like gray powder coating) However there are areas on this saw, that were obviously neglected in manufacturing, as there are some rough spots on the table, and the frame that are in non functional areas, that it looks like instead of cleanly machining the casting excess off, they must have just whacked it off with an angle grinder and called it good. Now whoever did this job does nice enough work, but you can tell there is a slightly irregular surface that looks very odd… I guess that is part of the trade off for the lowball price tag.
The routing for the power for the saw, as well as the battery compartment for the laser are both, well in the way of the lockout device for raising / lowering the head. A touch of fiddling with it and you can get them in a workable position, but it’s annoying that you have to do it.
The lock down mechanism for the table is simply a thread in rod, no quick release here. It is an obnoxiously crude design, but it functions so well it is hard to complain about it… Just twist the know counter clockwise to loosen, set your position, then turn clockwise to tighten. Very intuitive.
All of the control surfaces and plastics are well machined, and solidly cast. The handle feels good in the hand.
The included blade is a 60T General purpose blade. The carbide teeth appear well brazed, and everything looks solid enough, but the overall look and feel of the build quality, sharpening of the teeth etc… of this blade make me want to exchange it for a Freud 80T before I even fire the saw up…
The dust bag is completely pointless, the loose weave of this thing offers no filtration whatsoever. But that is not a concern for me. I either use the CMS outdoors, or hooked up with a hood to the dust collector…
Overall, I believe that swapping in a quality blade and just ignoring the funky machining in cosmetic areas, all the while just remembering that this saw cost me less than a non sliding 10” Ryobi, or B&D CMS, and I will be happy as a clam. All the function I want is there, and it all appears smooth. The moment of truth will come when I plug it in, and send it sailing on its maiden voyage across some 2×10s that I need to crosscut at a compound angle (odd piece of support decking for the hot water heater needs to be replaced…). I will most likely update my review then, and again in a few months to a year to at least give a reasonable term usage review of this tool.
*UPDATED 12/14/2010
I got an opportunity this evening to fire it up, and double, then triple check the saw. There is some good, and some really bad to report…
The good.
- The bevel stop at 0 is dead on perfect. No problem.
- The laser is dead on, with waste to the left of the blade, and is VERY bright contrary to most reviews. I seem to have gotten a bright laser…. I need to adjust this though. I like the waste on the right side of the blade…
- Something I didn’t mention in my initial review. It comes with a spare set of brushes. Something my more expensive machines make you pay extra for…
- The saw is no noisier than my B&D. That is until… Well we will get to that in a few lines…
The not so good but not terrible.
- The bevel stop at 45 degrees was off. It took a little bit of fiddling, and about 10 test cuts to get it dead on, but now, it’s dead on…
The absolutely awful.
- That blade. Now a low quality blade is NO surprise on any saw under $1,000.00. But just HOW bad this blade is will make your skin crawl. This thing relieves me permanently of ANY desire to EVER buy any bits or blades from Harbor Freight. I will have to grab a Freud Diablo D12980X and swap it over before I can write even a basic how this thing cuts. I think I would have been happier had Harbor Freight just left the blade out of the whole package…. This blade is every bit as bad as the Drill Master hole saws I got from them. ICK!
- Dust collection. We don’t need no stinking dust collection! Oh boy is DC on this thing rotten. Now I can’t compare it to other 12” sliders, but I CAN compare it to a couple of 10” non sliders. I think part of the problem is the slider design itself, so there is no feasable way to have some sort of ramp to direct dust and chunks (did I mention the lousy blade?) to the dust bag. The dust bag is EXTREMELY coarse, and for the most part useless. It filled up almost completely on the first cut, and the saw simply proceeded to spew dust from there. A shop vac hooked up to the port helps, but not enough. This thing REALLY needs to be used outside, or with a good dust hood and a full on dust collector… Now as most of us know, miter saws are lousy for dust collection, and this one is no exception. The only other 12” slider I have been around in action is the DeWalt at Woodcraft, and this seems no better, and aside from the lousy bag, not really worse. It’s pretty much middle of the road here.
All in all, so far anyway, I have bee pleasantly surprised by this saw. It has some areas that scream of excellent quality, and other areas that are oh so obvious that they took shortcuts making this thing. I think for the money paid, it will serve me admirably for a long time to come, and given a decent quality blade, I can learn to be happy with this machine, However, if I were wanting a buttery smooth no fuss miter saw out of the box, this would not have been on my short list. It’s not bad, but it’s nothing to brag about…
UPDATE 6/7/2012* I have owned and used this saw for a year and a half now, and as the miter saw is one of my most commonly used tools for cutting long stock to length, it gets a LOT of use… I have found this to be a valuable tool, but my star rating goes neither up, nor down. It does what I expect it to, and to be blunt, has been a MUCH better machine than can be reasonably expected for a 12” sliding miter saw that sells on sale for well under $150.00!
My continued use of this saw prompted me to build a dust hood that surrounds it. While connection to my DC is somewhat spotty in the location I have the saw (the hose is longer than I like…) the hood has been effective. Without the hood, a 2.5” shop vac hose on a rubber adapter works reasonably well. The OEM bag is a joke. If you can’t at least grab the junk with a shop vac, take the saw outside and just let it blow…
Once I got the fence set, it was dead square for a while, then it was no longer dead square. It seems the bolts that hold the fence down loosen up enough to allow the fence to move after a while. No thread locker on those babies… So a dab of thread locker, reset the fence, and I have been a year without having to reset the thing…
Likewise, one of the set screws on the pivot assembly had worked its way loose due to no thread locker. At this point, I fixed the issue, and went through the machine looking for loose fasteners, and dabbing thread locker on them prior to reassembly. So far so good…
Lastly, in case you have forgotten, this thing is a behemoth. An absolute beast. Mounted to the stock platform on my B&D Firestorm stand, the entire platform would move up and down about 3/4” while cycling the slide mechanism which would throw cut accuracy off. That is NOT a fault of the saw, but rather a design flaw of the B&D miter saw stand. I HATE having the saw on my big workbench full time, and I have a good idea how to fix the design flaw with the B&D stand… So I may just rig that back up and go with it… For several reasons. Not the least of which is the stand can fold up and the entire thing be hung on a wall.
You may have noticed I don’t talk about the laser guide all that much. That’s because I honestly don’t like those things. They are terribly innacurate and provide a false sense of proper setup. I did align mine just so that my machine was 100% properly setup, but I honestly never use it, and don’t care if it works or not…
Maybe one of these days I will upgrade to one of those Hitachi sliders that have the slides facing forward, but until then, this saw does what a 12” slider is supposed to do, and does it reasonably well. This machine is not one I have buyers remorse over by any means, but by the same token, this won’t go on my HF Gems list either.
View dbhost's profile
dbhost
5767 posts in 3468 days
29 comments so far
View NBeener's profile
NBeener
4816 posts in 3410 days
#1 posted 12-14-2010 10:00 PM
Excellent first impression report.
I wish you the best—both with the long-term use and performance of the saw, AND with the occasional LJ who seems to derive energy from moaning about those who buy foreign-made products ;-)
-- -- Neil
dbhost
#2 posted 12-14-2010 10:25 PM
I am so glad I didn’t have a mouth full of coffee when I read that…
View HokieMojo's profile
HokieMojo
2104 posts in 3964 days
#3 posted 12-14-2010 11:56 PM
I still wish you could have found a radial arm saw. I could use a refurbishing buddy as I go through my own, but I’m glad you like what you got.
dbhost
#4 posted 12-15-2010 02:40 AM
No problem. Actually I have been busy on the house… But sometimes I am not where I can do work on the house, so I type these things up… BTW. I am about to go up and update this thing…
Hokie…
I even went on to CL today to look at RAS’... No joy… The ones that are out there that are near me anyway, are either REALLY beat up, missing major components and more work than I want to get in to, OR they are too small (7.25” / 8” models…). And yes CharlieL I know this thing is HF crap. But it is functional crap and that is what I need… When I can afford US made stuff, then I will toss this thing aside. Honestly, I like this thing better than anything I have seen from Skil as far as miter saws, or table saws go… But that’s not saying much…
View Gofor's profile
Gofor
470 posts in 4023 days
#5 posted 12-15-2010 05:43 AM
Thank you for taking the time to do a review. I don’t think any of us really expect top quality at bargain prices, but it is good to see the good/bad of a bargain tool. Some need it once, or for one project. Some cannot afford better. It is good to see what you really get for that price to help when times are tough and dollars are short.
Reviews of DeWalt, Makita, Milwaukee, etc are readily available on the internet. Not too many comparing B & D, Firestorm, HF, etc. but probably more people on this forum use those than the mid-range.
Good job
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View ChuckC's profile
ChuckC
843 posts in 3171 days
#6 posted 12-15-2010 06:33 PM
Good luck with the saw. It probably wouldn’t hold up to professional use but for the hobbyist it should be fine. I am curious to see how those roller bearings will do over time.
View b2rtch's profile
b2rtch
4868 posts in 3284 days
#7 posted 12-15-2010 07:15 PM
SAW ( sorry, I had to do it!) you finally got it.
As you write m for the price it cannot be beaten.
I am satisfied with my 10”.
By the way you can find 20% discount coupon on the internet anytime you need one, just Google HF 20% off.
I really buy anything at HF with out 20% off coupon.
-- Bert
View Jim Bertelson's profile
Jim Bertelson
4256 posts in 3401 days
#8 posted 12-16-2010 12:33 AM
I suspect you will find a 12 inch miter saw, even though a cut below the best, better for you than a RAS. As noted before, you need portability, and that does not describe RAS’s, which can be a little touchy when it comes to maintaining calibration. I look pretty closely at my RAS at least once a week, and pull out the square if necessary. And I can’t remember the last time that RAS was moved even an inch. It works for me, but I don’t need portability, and I am used to the old saw.
I am sure you will resolve the DC issues with it, just as I am doing with the TS. Has anyone tried to dust proof a RAS? That is next on my list. My RAS leaks entirely too much…......er…....chips. The dust is pretty well controlled, but it sends out surface chips, especially from plywood.
Thanks for the review. Babying my left wrist, as noted before…...no shop time today.
Jim
-- Jim, Anchorage Alaska
View StumpyNubs's profile
StumpyNubs
7689 posts in 3037 days
#9 posted 12-18-2010 04:51 PM
Jim Bertelson- The dust collection problem with a RAS is simple if you only use the arm in the 90 degree position. Just build a box behind it big enough for the blade carriage to fit inside when it’s behind the fence and hook up a good dust collector. If you want angled cuts use jigs to position the board at the angle rather than moving the arm.
I use a RAS instead of a Miter saw because I have one and my grandfather was partial to one back when they were the only thing around. Maybe I’ll go through mine with HokieMojo?
Hokie- What RAS do you have? Mine is a B&D/Dewalt Powershop from the early 70’s before they started cheaping them out.
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
Jim Bertelson
#10 posted 12-18-2010 05:22 PM
Thanks Jim Hamilton. I have actually already done that. I made it many years ago….......I used the central vacuuming system to collect the dust until I got my Delta DC system. But it still scatters chips, especially from plywood. But it is a marked improvement over no DC. So I think I will try to hook up some tubing to the DC attachment on the guard, and make acrylic side guards instead of using the cheap ones that it came with…...you can see the box just behind the red saw blade, and the inadequate lateral guards…...
.......I haven’t made an angle jig for it yet, but I intend to do it. I also am attached to my saw, and love it as a 90 deg crosscut specialist. Note fence and stop I made for it. I do not measure for most crosscuts, just use the ruler and the stop. Really speeds things up and increases accuracy…...........here is the link to the fence description…......
http://lumberjocks.com/jbertelson/blog/11296
Thanks for stopping by, and thanks for your comments. Seems we think alike when it comes to RAS’s
Jim
dbhost
#11 posted 12-18-2010 08:29 PM
You are right on that Barry, at least with certain tools. That is why when I got my clamps, I literally picked through the entire stack and grabbed only the ones that didn’t have obvious defects.
I do seem to do fairly well with HF, but I totally understand that there are folks that get duds… I have had a few…
I don’t know however that paying more for a particular brand name is going to guarantee you will get a top quality item right off the bad. Read the threads on Delta, Powermatic, and Laguna lately and all I have to say is at least Harbor Freight makes up for it with decent customer service…
StumpyNubs
#12 posted 12-18-2010 11:13 PM
Jim- I made my box so that the sides go all the way up to the fence and that made a difference, also the top goes all the way wut is hinged wo that it will rise if I raise the height of the saw arm. If the dust collector is on I get very few chips from the box alone. I don’t even need a hose hooked to the dust gaurd like some people do.
I do admit I get some dust against the fence, but that’s unavoidable unless you have a big gap where the blade passes through because all the chips fly from the bottom of the blade.
Looks like you have a Craftsman. maybe it’s different from my Dewalt/B&D
Jim Bertelson
#13 posted 12-19-2010 02:21 AM
Jim Hamilton
Hadn’t even thought of moving the box closer to the fence, and a hinged top sounds good. I will do that first to see if that is all I have to do. I think I will make some acrylic guards, although the inside one may end up being a little skimpy.
Got to get the TS DC done first, it is a real problem, although already improved.
Thanks for the suggestions…......
Jim
dbhost
#14 posted 12-30-2010 06:59 AM
UPDATED 12/29/2010. I have pulled the OEM 12” blade, and inspected it. There is some very obvious flaws in this blade, that for some reason kept themselves behind the aluminum of the blade shroud when I looked at it originally. There are no less than 10 teeth where the carbide is, well simply not attached or ground right. I have replaced the blade with a Freud Diablo D1280XH 12” 80T blade and am as happy as can possibly be. The hatchet job finish of the cuts is smooth as butter. I am a bit amazed at some of the reviews that mentioned that the owners had trouble getting the blade guard on when swapping the blade. If you follow the procedure in the manual, it goes off and on very easily. I guess some folks lack mechanical aptitude or something…
No this isn’t the new fancy Bosch. But it IS a far cry nicer than anything else in my price range… I just now need to get dust collection in it squared away and I will be set…
b2rtch
#15 posted 12-30-2010 01:02 PM
“I am a bit amazed at some of the reviews that mentioned that the owners had trouble getting the blade guard on when swapping the blade. If you follow the procedure in the manual, it goes off and on very easily. I guess some folks lack mechanical aptitude or something…”
Remember I use a 10” and the design of the whole saw has been changed about 2 years ago.
To change the blade with the new design is a piece of cake that was to the cake in the past.
I use a 60teeth blade and I too get nice cuts.
-- Bert
showing 1 through 15 of 29 comments
