| Review by Dan Pleska | posted 635 days ago | 2480 views | 0 times favorited | 11 comments | ![]() |
- Steel City 17-Inch Drill Press
- Brand: Steel City | Category: Drill Presses
I was looking for a drill press with a long quill travel and found it in the Steel City 17” drill press. At 6” it has the longest quill travel that I could find in its price range. It was a little more expensive than the comparable models, but I got it at a show and with the $75 dollar rebate at the time it brought it to within dollars of the competition. With all other specifications being similar, the quill travel was what sold me.
It probably isn’t any secret why it looks like the Delta, since the guys that started Steel City used to work for Delta.
I wasn’t looking for a high dollar drill press with loads of features. I don’t change speeds very often, so the manual belt change was acceptable. The tilting table has a positive lock at 45 degrees in both directions, but the table can be rotated to 90 degrees. I used that feature to clamp the bow back for a Windsor chair and make a tenon of the ends with a tenon cutter. The 3/4 hp, 1725 rpm, motor has plenty of power. The 1/2” chuck mounted on a #2 Morse taper is removable and sometimes does double duty on my lathe.
All in all, I’m very satisfied with this drill press and recommend it.
-- Dan, West Virginia, http://www.danpleskaCreations.com
11 comments so far
Woodchuck1957
home | projects | blog
950 posts in 659 days
posted 635 days ago
Dan, from what I can tell the 17” Steel City drill press you bought is probably your best bang for the buck in a 17” drill press. They gotta be selling like hot cakes. I wouldn’t be a bit suprised if it is Steel City’s best selling machine.
Bruce
91 posts in 670 days
posted 634 days ago
Pretty cool, Dan. Have you had it long? Where, what show did you get it at? Check your email.
Lori
65 posts in 820 days
posted 628 days ago
I agree with you that the Steel City DP was a good deal. I did alot of research, I only wanted to buy a DP once. The Steel City had everything I could want for the best price. It came with a free laser, which I admit I wouldn’t have bought, but find to be a wonderful addition. I also don’t change speed often, so the manual belt changes are not really a big deal for me. Still I find the wide range of speeds available to be a great feature.
-- Lori
iannlb
11 posts in 675 days
posted 616 days ago
Good power, big, heavy and suprisingly well made laser.
-- Iannlb
timrowledge
27 posts in 428 days
posted 404 days ago
I got one last january; Midland Tools delivered it to my workshop door for me and the delivery guy even helped me unpack it. I love it. The long travel quill saves time when changing drills since I don’t have to keep moving the table up and down and realigning. It’s solid and quiet. The laser is amazingly useful and quite precise. All in all a real deal.
Don
25 posts in 245 days
posted 244 days ago
Does anyone owning the SC drill press have ANY complaints at all, or is this the perfect DP?
-- Don
Dan Pleska
109 posts in 856 days
posted 243 days ago
I wouldn’t say it is the perfect drill press by any means, but it is one of the best values for its price range.
Don
posted 240 days ago
Saturday I bought the Steel City. I THINK I’m pleased with it. The motor has a slight rumble and vibration to it prior to it stopping after I turn it off. The Steel City rep told me that is what it’s supposed to do. It is one circuit jumping to another so that the machine will easily turn on each time.
It also has a slight squeaking noise, which I followed to the turning of the motor shaft. I disconnected the rear belt and turned the pulley connected to the motor shaft by hand. The rep told me that should go away.
The belts also squeak, but he said that will stop as soon as they are worn in.
Did any of you experience these traits?
-- Don
Dan Pleska
posted 239 days ago
I think the vibration when stopping and the belt squeak (which stopped) were all I experienced.
Don
posted 239 days ago
Thanks, Dan. I feel better now.
-- Don
Don
posted 219 days ago
As a follow up, I very much like the SC drill press, and am now considering buying their 35905G table saw.
Incidentallly, their service is superb, especially when compared to Delta.
-- Don
