Glad I picked this Drill Press
Review by tjackele posted 12-10-2010 03:23 AM 9887 views 1 time favorited 14 comments Add to Favorites Watch
Glad I picked this Drill Press No-picture-s No-picture-s Click the pictures to enlarge them
Anyone thinking of buying this drill press, should really do it if you have the cash. I have already benefited from the 6” quill while making my workbench. The angles are good, although I have only needed side to side angles, compound has not come up for me.
While it really should come with a fence, I had a router fence that I used and Rockler hold downs that fit perfectly in the slots provided in the table, same slots work great for the fence. When I need to take off the hold-downs, I can remove them from a bigger square opening toward the front of the table.
Changing speed was a big worry and it seems easy the tensioner makes for a tool free speed change.
I think the light and the laser are great too.
I am sure other options are good, but that 6” quill drove my choice.
My table old top drill press was failing, but since it is from my deceased father, it will remain and get refurbished and retain a place of honor in my shop. If anyone can tell me how to get the quill and spindle to work right again, I would appreciate your advice.
I added the picture, but it doesn’t seem to look right….
-- Tim Jackelen
View tjackele's profile
tjackele
24 posts in 3071 days
14 comments so far
View Delta356's profile
Delta356
463 posts in 3088 days
#1 posted 12-10-2010 05:16 AM
Congrats with your drill press. I saw that at my local ROCKLER and looks to be a great drill press.
The Wood workers table is a bounce…
Thanks, Michael Frey
Portland, OR
FREY WOODWORKING INC.
View jim C's profile
jim C
1472 posts in 3333 days
#2 posted 12-10-2010 02:37 PM
Tim,
Send or post pics of the old drill press. I might be able to give you some tips.
Jim
View Rick Boyett's profile
Rick Boyett
167 posts in 3447 days
#3 posted 12-10-2010 05:22 PM
I’ve been thinking of upgrading my DP350 to this drill press.
How well does the laser work for aiming? Is it dead on? What if you change the table height?
Thanks
tjackele
#4 posted 12-10-2010 06:38 PM
The laser adjusts with an allen wrench and is easy to access with a picture on both sides to indicate what moves the laser (two screws on each side). When the table top is raised or lowered, I need to adjust the laser a little, but only because it wobbles a little with turning the crank.
It actually is dead on and the instruction is good. Once set for a given table height, it doesn’t matter what the wood thickness is, or any support you may put under it, the laser is still dead on.
When I tested, I get the table height and placement right, then with the Forstner, or wood bit I Plan to use and press off, just mark the entry point on a scrap. I use that mark to align the lasers if needed. Less than two minutes to do and it stays right until I raise/lower the table.
-- Tim Jackelen
View Dusty56's profile
Dusty56
11830 posts in 3922 days
#5 posted 12-11-2010 03:27 AM
Are you saying that you readjust the laser every time instead of centering the table to the laser ?
tjackele
#6 posted 12-11-2010 06:48 AM
Actually, I only moved the table once, and the first time I did readjust the laser. Your point is right, though that you could just move the table and lock it down in position with the laser on and align the point of drill entry to the cross hairs.
I have not done it that way yet. Most of my boards have been the same thickness.
Also that first time, the laser had been aligned at the store, I did not assemble it and adjusted the cross hairs since it wasn’t right to me.
Your method sounds good to me.
-- Tim Jackelen
View roundguy's profile
roundguy
62 posts in 2919 days
#7 posted 03-28-2011 05:41 AM
I bought one of these on sale a few weeks ago. Setup was pretty simple.
I followed the manual for adjusting the lasers, and I am able to move the table to any height and the lasers are still properly aligned.
View rum's profile
rum
148 posts in 2820 days
#8 posted 05-03-2011 02:50 AM
Also just got one.
Pros:
  • 6” quill throw is a win
  • speed range is great (I had set a range of 200rpm on low end to something at least approaching 3000rpm on the upper end, as I do use both small and LARGE bits).
  • love the table, so much better than my old metal worker round style for wood (plus its shiny w/ some paste wax). The tilt feature is very easy and handy. The indexing pin on the side<->side tilt to get back to 90 is also well thought out.
  • run out at the taper when turned by hand = 0 (literally, I had to check several times to make sure I had indicator contact)
  • run out fully extended 0.5/1000 (turning by hand)
  • also measured while running at 170rpm (lowest), ~0.5/1000 at the top and ~2.5/1000 at full extension
  • belt changing/tension system. Every mentions easy of changing belts, but you also get perfect belt tension for free, this was an unexpected benefit that I like a lot.
  • depth stop adjusters, these are some of the easiest I’ve used/seen. I also really like the “depth dial”, its not 100% accurate, but for 99% of what I do its perfect.
Cons:
  • front pulley was ~3/1000 out of round (luckily the floating belt tension makes this a non-issue)
  • MT2 taper, I’d have preferred to get a machine with an MT3 taper, but fit and finish reports on the delta won
  • Chuck is just ok, but all factory chucks are mediocre so consider that neutral
Competition on my short list:
  • Dayton (grainger) 20” (5PHC4)
  • Jet JDP-20MF
  • general 75-260
  • palmgren 80174/80172
I actually spec compared about 25 drill presses (on 10 objective and a handful of subjective criteria) and narrowed it down to that short list (I can’t remember quite why but the steel city manual change pulley press was just on the other side of the top 5 line).
If I could have gotten my hands on it first, I might have gone with the Dayton/grainger, the specs were definitely “better” (or at least substantially beefier) and the price is competitive. Unfortunately there are none local and I was uncomfortable with out seeing it and being unable to find any user reports. The other three look like great DP’s as well, a few things lined up and this one looked like the winner so I went for it.
Overall quite happy, a great press.
View thiel's profile
thiel
394 posts in 3526 days
#9 posted 10-12-2011 11:01 PM
Is it crazy top heavy? Thinking about this press but worry that it could crush a small country if tipped over…
-- --Thiel
View Ken90712's profile
Ken90712
17614 posts in 3423 days
#10 posted 11-25-2011 08:27 PM
Great review I have this and the powermatic in mind
tjackele
#11 posted 11-28-2011 09:03 PM
Thanks to rum, you seem a lot more thorough and analytical in your pick than I was, nice work!
Thiel,
I am able to move it myself by tipping it and did not lose control so far. It did not get away from me. I sure want to put it on wheels, but it hasn’t moved in quite a while so that will have to wait.
For ken90712,
I think you would be happy with either one. What convinced me was the 6” travel on the Delta. I would imagine the electronic speed control with the Powermatic would be a big help too, so it is a question more of what is top of your list.
I have used it a lot for the rocking chair designed by Scott Morrison and it worked great for the angles including vertical for the holes in the legs and other angles for the headrest. Still happy after all this time and use.
-- Tim Jackelen
View yowzor's profile
yowzor
2 posts in 3331 days
#12 posted 12-20-2011 07:28 AM
any thoughts about the jet 15” drill press either bench top or floor model. From reading the reviews it seems that the floor models are more versatile, but a little heavier?
View Holt's profile
Holt
280 posts in 2863 days
#13 posted 06-23-2013 10:03 PM
I’ve also got this drill press. If you mount the base to a piece of plywood per the instructions, it’s very stable. After assembly but before I attached the plywood, it seemed pretty top heavy to me, I would have been nervous about using it without the plywood…
-- ...Specialization is for insects.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2344 days
#14 posted 06-23-2013 11:36 PM
I also have one of these, and even in a mobile base, I’m not worried about it falling over.
I chose it over the PM2800 for two reasons. Nothing I saw or felt on the PM during in-person comparisons made it worth the extra money, and I prefer the simplicity of a belt drive. I’ve never drilled a hole where I absolutely HAD to have a speed between what was available on the pulleys on the 900L.
