| Review by kshipp | posted 618 days ago | 799 views | 0 times favorited | 2 comments | ![]() |
- Cen-Tech 6-Inch Digital Caliper
- Brand: Cen-Tech | Category: Measuring Tools
I got these calipers about a year ago for some other projects but I have found myself using them many times for wood working. It’s great for checking setups on your tools and seeing exactly where a joint is not fitting.
As far as calipers go they are pretty standard but where they stand out is the price. These are on sale now at Harbor Freight for $16 and I think that is about what I paid for them a year ago. I know what you are thinking because I thought the same thing, “How can a $16 set of calipers from Harbor Freight be any good?” I got them because I figured I wasn’t building rocket ships so it didn’t matter a whole lot. But I checked them against some we have at work that cost 4 times as much and are calibrated regularly and they were extremely comparable. (I’m an industrial engineer, so I used valid statistical tools to check this. I left out the actual data because I can’t find it right now and I’ve found that not everyone find statistics as interesting as I do.)
Here are the stats from the Harbor Freight website:
- Accurate to 0.001”
- Resolution: 0.0005”
- Metric and SAE Display
- Fluid-resistant stainless steel frame, precision ground jaws
- On/Off switch with automatic shutoff
The only problem for woodworking is it measures in decimal instead of fractions. I have a drill index chart in my shop that gives me all the conversions so it’s not a big deal.
-- Kyle Shipp, Michigan, http://battleshipp.blogspot.com
2 comments so far
David A. P.
home | projects | blog
26 posts in 443 days
posted 172 days ago
Thanks for the review! Helpful for the woodworker on a limited budget (i.e., almost all of them :).
-- David A. P. -- Ars Arboris ("Art of the Tree") -- ArsArboris.com
15557 posts in 456 days
posted 172 days ago
Good Reveiw . I use mine all the time
