Simple Green PRO HD excells at cleaning saw blades
Review by pintodeluxe posted 12-06-2010 09:46 PM 10494 views 5 times favorited 16 comments Add to Favorites Watch
Simple Green PRO HD excells at cleaning saw blades No-picture-s No-picture-s Click the pictures to enlarge them
I heard that soaking carbide tipped blades in simple green can leach carbide from the metal. I emailed simple green and a rep confirmed that the standard simple green should not be used to soak carbide tipped blades. He recommended two other simple green products that have no such problem:
1. Simple Green Pro HD
2. Simple Green Aircraft parts cleaner
I found the simple green Pro HD at my local Home Depot. It is the purple stuff and is sold in a 1 gallon concentrate for around $13. I gave it a try cleaning my Freud saw blades, and I was quite impressed. I had all the pitch and gum removed from my tablesaw blade, and dado set in under 10 minutes. Most of that was letting the blades soak. I lightly scrubbed with a brass brush, and all the deposits just melted.
After cleaning, I dry the blades with a paper towel and reinstall on the saw. I run the saw for a minute to finish drying the blade. The cleaner does not leave any residue.
Simple Green Purple. Go get some.
View pintodeluxe's profile
pintodeluxe
5820 posts in 3055 days
16 comments so far
View Viking's profile
Viking
880 posts in 3437 days
#1 posted 12-06-2010 09:54 PM
Thanks for the tip. This is great to know. I had heard the same about the standard Simple Green.
Did you use the SG Pro full strength?
Thanks for sharing
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
pintodeluxe
#2 posted 12-06-2010 09:57 PM
I diluted the cleaner 1:1 with water. I no longer dread cleaning blades.
Viking
#3 posted 12-06-2010 09:59 PM
Thanks! Going to HD on the way home today.
View Dusty56's profile
Dusty56
11830 posts in 3930 days
#4 posted 12-07-2010 12:00 AM
Does it smell like the regular product ?
Thanks for the info …I didn’t know that the original was bad for the carbide , not that I’ve used it for blade cleaning.
View GaryL's profile
GaryL
1099 posts in 3072 days
#5 posted 12-07-2010 12:43 AM
Thanks for info. Did not know that Simple Green was used for this.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View Dedvw's profile
Dedvw
176 posts in 3123 days
#6 posted 12-07-2010 06:33 AM
Awesome tip, thanks.
View ken_c's profile
ken_c
325 posts in 3404 days
#7 posted 12-07-2010 06:14 PM
I just cleaned mine, a sponge, a tooth brush and some dish soap and warm water…
pintodeluxe
#8 posted 12-07-2010 10:17 PM
Dusty –
I didn’t notice a particular odor with the Simple Green Pro HD.
cheers
View Howie's profile
Howie
2656 posts in 3165 days
#9 posted 12-08-2010 02:34 AM
Thanks for the tip. I use SG to clean some things with(good stuff) but I will get some purple for the saw blades.
-- Life is good.
View reggiek's profile
reggiek
2240 posts in 3512 days
#10 posted 12-08-2010 02:46 AM
Great tip….I had not thought of SG because of the problem on carbides. I’ll have to get some to how it works on router bits.
I use the SG regular as an ant killer/repellent around my house and shop – I get it mostly for cleaning….but found it to be a real ant deterrant (they hate the stuff – and won’t go near places it has been used)....and since it is non toxic….it can even be used on kitchen counters, food areas…etc.
View Splinterman's profile
Splinterman
23074 posts in 3603 days
#11 posted 12-08-2010 09:11 AM
Hey Reggiek,
Now thats a cool tip about SG and the ants….good one.
View daltxguy's profile
daltxguy
1373 posts in 4156 days
#12 posted 12-08-2010 12:38 PM
wood ashes also works really well
-- If you can't joint it, bead it!
View b2rtch's profile
b2rtch
4868 posts in 3290 days
#13 posted 12-08-2010 12:43 PM
I cannot stand the smell of the “normal” SG.
It makes me sick.
I have used pure ammonia, curiously enough I do not mind the smell of ammonia.
-- Bert
View Ken90712's profile
Ken90712
17616 posts in 3430 days
#14 posted 12-08-2010 07:18 PM
LOL my wife hates the smell as well. I like it. I’ll have to try this out. I have been using Krud Kutter from HD and it works great. But always on the look out for a good blade cleaner.
View Jesse's profile
Jesse
66 posts in 3460 days
#15 posted 12-16-2010 07:23 PM
I just tried this stuff a few nights ago. Worked amazing!
Thanks for the tip
-- Jesse, Hopewell Jct., NY
